Asrock K7VM3 Motherboard
Problem for Asrock K7VM3 Motherboard
I cannot install driver sound software
By mahmoodshaa on Sep 09, 2009
dear sir, i cannot install sound driver software ..while the installation sound driver ,its indicating '' first enable bios setup.''.so its cannot install....so what i want bios setup? where i want set?
Comments:
Sep 09, 2009
- Dear Sir,The error or information is writing below ''VIA AC97 Audio Chipset is not enabled on this system ! Please enable it first on the BIOS then run this setup again.''...Kindly read and reply immedialy..
Solution #1
posted on Sep 09, 2009
Somewhat Helpful)
g-z4
Rank: Master
Rating: 89%, 11 votes
have you tired installing this in the administrative programs / computer management? this should tell you if youre sound driver is working correctly also if it isnt it will tell you what the error code is, please post that
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 10, 2009
Not Rated)
midhungbabu
Rank: Wiz
Rating: 74%, 39 votes
I had the exact same problem and I spent the whole day searching for a solution. I found one that apparently works.
You need to build a new image of the XP installation disk that contains
Those can be downloaded here : http://h20000.www2.hp.com/...
Once you have downloaded the file, extract it somewhere on your PC and make note of the location.
Then you'll need to follow this procedure to add the drivers to your original XP setup disk.
http://lifehacker.com/...
You'll need a tool called nLite to do that. Don't worry about adding sp3, you can simply add the driver (that's when you'll need to point to the folder where you extracted the file above).
At the end of the process you will have a new iso file that you need to burn. I'm using the new install CD I created as I speak and it seems to work.
Hope this helps and that it'll work for you too.
Was this helpful?
Yes
No
Popular Solutions for Asrock K7VM3 Motherboard
Questions and Unsolved Problems for Asrock K7VM3 Motherboard
Do you recommend Asrock K7VM3 Motherboard?
Answer
Answer
i want drivers of f5rlseries
Answer
Hi, the driver for the device is installed and up-todate but Windows Vista outputs an error that the... (More)
Answer
open medion akoya E7330 pc case
Answer
dont know the correct jumper settings for my e machin.es t6534 monitor doesnt read as on. please... (More)
Describe your Motherboards problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
