Question about Dell 948 All-In-One InkJet Printer
When I scan it comes out all black
When I use the scan mode to copy a letter, photo, or anything else, it comes out all black. This also happens if I try using the copy mode.
Is this caused by a lamp inside that may have burned out? If so, is it replaceable, where can I obtain a new bulb, and how can I locate/replace the defective light?
Thank you!
Susan M.
  • Dell Master
  • 5,568 Answers
The lamp in your scanner is defunct and the replacement of these varies greatly and may not be a DIY job depending on the amount of work to access the guts of the scanner. You need to contact Dell to obtain the part number for the lamp and perhaps order it through them; check your owner's guide for the 800 number.
Posted on Sep 09, 2009
Black line down page when in COPY mode on MFC-240C
You need to poiwer cycle after cleaning as the scanner only calibrates during power up. If all is clean, even the white bar over the small glass assembly, and you power cycle the machine and it's still there, you will need a new scan assembly.
Nov 24, 2009 | Brother Multi-Function Center MFC-240C...
It won't print black, the cartrige is new
I can get it to do sortof bubble-letters if I convert to a jpg or png or gif first, but the behavior here with my X4650 is very similar in that it won't do black at all from Word or web-browsers.
Oct 15, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
My black is really faded, when I print a test page by pushing photo and copy, however when I do a print head allignment the black for the allignment paper is sharp and deap, whats going on? Ive tried to...
The PHOTO mode is for printing grayscale photographs. Printed letters using PHOTO mode may appear faint because PHOTO mode is optimized for halftones. See if there is a TEXT or LETTER print mode, and try printing on that setting. If printed letters are still faint, you may have to go into ADVANCED PRINTER PREFERENCES, and see if the TONER SAVE mode is on. If it is, turn TONER SAVE off. Also, try changing the DPI image density, or try other adjustments in the ADVANCED PRINTER PREFERENCES MODE.
Aug 21, 2008 | Kodak Office Equipment & Supplies
2nd request - Dell 962 All-in-one Printer - from glass top
ok..start by removing the printer from your printer panel.
then go here for fresh drivers(not the CD version)
reinstall
hook up printer
see how it works
Mar 17, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell No. 962 (All-In-One Printer)
you need to go to your printer settings and make sure it is set as the default printer for everything. Make sure it is also set as your default scanner. you may also try lightening the image with the lighter/darker setting on the machine. if this continues, you may want to see if a section of the light is burnt out. this wiill cause darkness on scan & copies but not printing from the c drive. Make sure the machine is lighting up completely when is scans or copies. If part of the lighting is burnt out it will be a fix or replace situation.
Mar 05, 2008 | Dell 962 Photo All-In-One InkJet Printer
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Scaning.
first you try with install driver cd software and then select the prefence and choose the target where do want to go the scan file.
Sep 22, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Colour problem with printer
After you scan it, do you immediately print it in an image format or do you use word? If you use word i might have a tip that might help.
Before printing, click File>print>click on "Properties" and check that the grayscale printing box isn't marked, if it is unmark it and it'll print in colour.
Also anything is that, when you're scanning. After previewing your scanned piece, double check the mode, either magazine (which is in colour), Black and white or outline (i think)
That's all i have for now.
Sep 09, 2006 | Canon PIXMA MP130 All-In-One InkJet...
Dell 948 All-In-One InkJet Printer Logo
101 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
