Question about 3d Rose Londons Times Funny Cow Cartoons - Cow Country Club - Golf - Light Switch C
1986 gas club car weak spark replaced coil still same
Spark strong then weak or hot replaced coil same problem, starts then next time may not start check and very weak spark.
    Sergeant:
  • 384 Answers
How do you know that the spark is weak?
Replace spark plug.
Check spark plug wire for leaks.
Replace fuel.
Clean points and reset.
If there is a battery check that it is at 12.5 during starting.
Posted on Sep 09, 2009
Golfcart cranks but not starting.
Before doing anything, make sure that the timing and valves are properly adjusted. THEN, you need to check the ignition system and the fuel delivery systems for proper operation.You need spark and fuel delivery for that puppy to run. Did you check the ignition coil to make sure it is good? Are you getting a strong spark at the plug? Did you try starter fluid? Is new carb properly adjusted?
Feb 23, 2017 | Cars & Trucks
1986 ford club wagon xlt in line 6 300. Doesn't fire. Has spark, getting gas, repaired broken wire going to the module. Put coil and different distributor in. Wondering if it could be in the ignition...
If it has spark and is getting gas then there is no reason why it should not start. How do you know it is getting gas?? Have you tried using wd40 directly into the carb/intake to see if it will try to fire up?
Mar 26, 2011 | Ford Club Cars & Trucks
It start then stops running
Have you checked to see if it has a good strong spark? Remove plug, put back on coil wire, put end of spark plug next to the engine head bolts. Then turn the motor over a few times and watch the spark plug to see if a good strong jumps across from plug to engine head bolt or other metal surface.
If you have bad spark, change plug. If it is still weak spark, check the coils.
If spark is good, then you have a fuel problem. Likely gummed up and sticking floats in the carberator that will have to be pulled off and apart and soaked in solvent or other cleaner for an hour.
Another possiblility but not as common is a faulty kill or power switch which can be tested with an ohm meter.
Check fuel filter and fuel lines.
Jul 22, 2010 | Honda 2500 PSI Gas Pressure Washer
97 dodge pickup with 5.2 I have strong spark out
If you have a strong spark at the coil and plugs are not then it sounds like plug wires. They can degrade over time.
Mar 15, 2010 | 1997 Dodge Ram 1500 Club Cab
I have a 1993 GMC jimmy. it has spark and it is getting gas from the fuel pump and filter. and i checked all the fuses, but it will not start.
How strong is the spark it needs to blue in color, if it's orange or yellow in color it's too weak replace the coil.
Jan 20, 2010 | 1993 Chevrolet S-10 Blazer
Takes a long time to start,when started it putts.
distributer cap and button are weak it sounds like
put the screw driver in the spark plug boot. close to a ground
make sure its not aluminum.
turn the engine over when its somewhat dark
look for the intensity of the spark.
if the sparks bright then its strong IE if the sparks not strong means its the coil that needs to be replaced.or the wires
More then likely its the cap button or plug wires..
if there is any cracks in the wires they will leak power out.. making it use more gas to make it run.
May 29, 2009 | 1995 Buick LeSabre
RX7 with 13b engine is hard to start, idles fine, dies on accel.
problem like this on garden tractor ,was weak coil ,-when engine at low manifold pressure[idle] spark could jump gap and fire cylinder ,higher pressure /under load-wouldn't fire...check color of spark -orange,yellow ,white spark=weak, blue spark is stronge,
Mar 22, 2009 | 1984 Mazda RX-7
3d Rose Londons Times Funny Cow Cartoons - Cow Country Club - Golf - Light Switch C Logo
837 people viewed this question
Top 3d Rose Electrical Supplies Experts
Ronald Prier
Scott Jelt
Scott Jelt
Are you a 3d Rose Electrical Supply Expert? Answer questions, earn points and help others
