Dell Inspiron E 1405 says Invalid IP address 0.0.0.0 when i try to get on network at school using ethernet, also says someone else is using this address, how ever at home using the same ethernet port it hooks up okay
  • jsapj Sep 09, 2009
    I'm sorry, I should of said what I've already tried. This is my neices laptop she use at collage,this,is the only place this problem comes up. I've tried your suggestion already,it did'nt help. I also uninstalled the Brodcom adapter and let WinXP find and reinstall drivers, did'nt work{have'nt tired new drivers yet,will this afternoon}. Also tried new cable and moving it to her roommates connection, same results.
    I've also looked at the Registry key:
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\DHCP DependOnService
    for SYMTDI enrty as stated on Microsofts website{I know it had Norton Anti-virus on machine when it was new,her brother uninstalled it and put on McAfee}.
    turned off all firewalls, did'nt help.
    my acer laptop connects right off .
    Sorry agin, totaly my fault for wasting your time,I do appreciate your help, thanks agin. sp
    Scholar:
  • 156 Answers
Go ahead and type a command says ipconfig /renew in CMD Window.
Posted on Sep 09, 2009
Two routers, two WAN links
easy...
CODE
!R1
interface GigabitEthernet 0/0
ip address 172.16.1.1 255.255.255.252
ip ospf network point-to-point
bandwidth 100000 ! Makes OSPF think its 100Mbps
interface GigabitEthernet 0/1
ip address 172.16.2.1 255.255.255.252
bandwidth 10000 ! Makes OSPF think its 10Mbps
router ospf 10
network 172.16.1.1 0.0.0.0 area 0
network 172.16.2.1 0.0.0.0 area 0
network 10.1.1.1 0.0.0.0 area 0
passive-interface GigabitEthernet0/0/0
!R2
ip address 172.16.1.2 255.255.255.252
ip address 172.16.2.2 255.255.255.252
router ospf 10
network 172.16.1.2 0.0.0.0 area 0
network 172.16.2.2 0.0.0.0 area 0
network 10.1.2.1 0.0.0.0 area 0
This will make your wireless link preferred, if the link fails the OSPF adjacency will fail and routing will fallback to the other link.
You should ideally have some /32 loopback interfaces so the router will use this as the OSPF RID, or manually set the RID under the OSPF process.
More discussion about this you can see http://www.router-switch.com/forum/showTopicDetails/11/490
Apr 12, 2013 | Cisco Computers & Internet
My newly purchased dell inspiron 560 will not connect to the network due to "an invalid ip address". 10 other computers are working fine on the network. Any solutions?
You will need to manually configure the IP for your Local Network Connection: right click on the notification icon, go to Properties, double click Internet protocol version 4 (TCP/IPv4) Or click properties, click Use the following IP address and input the correct data according with the settings in your network - change just the IP first.
Jun 26, 2011 | Dell Inspiron 560 Desktop Computer (Intel...
Ethernet port not reading my modem for my dell inspiron 8600
make sure that your tcp/ip networking is set to 'Obtain IP address automatically'.
Power modem first , then laptop. Make sure that you are using the right cable for connection between modem and comp.
Mar 12, 2009 | Dell Inspiron 8600 Notebook
Dell inspiron E1505 cannot connect to internet
A hardware error usualy indicated a bad network cable or a bad network card. Have you tried using a different Cable?
Mar 04, 2009 | Dell Inspiron 1501 Notebook
Dell Laptop is not pulling IP address
Connect it directly to the modem with the ethernet cable first...Windows will configure the Dell...then the wireless should work.
Feb 27, 2009 | Dell Inspiron 6000 Notebook
Invalid ip address
Hi there try this first look for your network connections and right click on it and select repair this connection and select ok and see what happnes it should repair the connection and give you a aquirring network address if not try to move the laptop to a different area and see if you get a better signal ok
Feb 16, 2009 | Dell Inspiron 9300 PC Notebook
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
Acquiring Network Address
reset the modem and the wireless router by powering them off for 30-60 seconds, then plug power back in. Wait a minute or so for the devices to reset then go to the PC and try to connect again
Good luck
Jan 26, 2009 | Dell Inspiron 2200 Notebook
I am trying to connect to the wireless in my new apartment. I have entered my network and password and that has worked fine. However, under Wireless Network Connection Status (i can get there by clicking...
On the Support tab - what does it say the "Address Type" ?
If its DHCP then check that on the TCP/IP properties;
If on "automatic IP address" then it wont take any entered IP address.
Do not put any IP address.
Check that "Obtain an IP address automatically" is checked and also "Obtain DNS server address automatically" is also checked. On wireless network tab check "Use Windows to configure my wireless network settings".
On preferred network check that your wireless network is there, if not add it and move it up
Reset Dell 1720dn network address to get back access to it?
Please have a look if you have Dell 1700 series laser printer. Please follow the instruction bellow to reset printer to factory default: 1. Power Off the Printer from the back switch from the back 2. Open Front cover 3. Hold Down “Continue” & “Cancel” button while turning printer on
se http://digg.com/hardware/How_to_Reset_Dell_1700_1700dn_1710_1710dn_1720_1720
Regards Anders.Thornberg.Qnetcom.se
Dec 28, 2008 | Dell 1720dn Laser Printer
Computers & Internet Logo
203 people viewed this question
David Payne
David Payne
