Question about Refrigerators
Welbuilt Refridgerator (old) - Which way is coldest - 0 or 6?
Temp control dial goes from 0 to 6, with a red defrost button in the middle. But no indication of which way is warmer, which is colder.
This fridge is used for sodas at work, and since I defrosted it Friday it's been freezing our stock! I forgot to write down the setting before defrosting!!!
Please help ASAP!
  • 308 Answers
Most controls work with the highest number being the coldest. Keep in mind that once you adjust that setting you should allow 24 hr for the refrigerator to "equalize" to it new set temp. Hope this helps
Posted on Sep 09, 2009
I want to replace faulty freezer thermostat in whirlpool side by side fridge mod ed22dqxew01 --am having trouble removing cover for freezer-refridgerator control dials. I removed two screws in rear of
First question why are you replacing the freezer thermostat? Do you have an ice build up on the rear wall of the freezer? This build up if you do have it is not due to the thermostat control for the freezer. It is termed as a defrost issue due to a fault condition being present in the defrost thermostat, the defrost heater, or the defrost timer or adaptive control depending on which type of refrigerator you have. I will await your reply as to why you are replacing the control thermostat and if you do have any ice up condition before posting further how to solve this situation. I await your reply
Thank you
Rick
Jan 01, 2012 | Refrigerators
The lights are still on when the refridgerator doors are open, but the refridgerator and freezer are not cold and the Power on/off button is not lit. What do I do?
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 09, 2011 | KitchenAid Superba Architect KSCS25INSS...
My refridgerator quit working; however the freezer is. The alarm noise goes off every few minutes but usually only goes off if the doors are not shut tightly/ I've made sure the doors are shut with no...
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 08, 2011 | Kenmore 19.7 cu. ft. Bottom Freezer...
Freezer gets cold but Fridge does not. All vents are open, dials are correct and vacumed coils underneath front of fridge. Fridge door seems to be closed properly. Kenmore Refridgerator is 4 years old.
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 07, 2011 | Kenmore Side by Side Refrigerator
How do I make refridgerator colder....dial is one through 7... is # 1 coldest or #7
1 is the warmest
7 is the coldest
one thing to check is the condenser coil in the bottom behind the grill below the door..remove that grill and clean all the dust from it
when setting the controls nothing happens quickly it takes up to 24 hours to achive the lower temp it was set at
GENE
Aug 27, 2011 | Amana Refrigerators
My freezer isn't reachintg the coldest temperatures and the food is defrosting. I can hear that it the motor is running. What can I do? the temperature dial is set to Max.
Have these temp control dial be check.
If it is defective it's either defrosting- no ice or freezer is full of ice.
Check if you can or call a service technician to do that.
I hope I help you to your fridge problem.
Jun 28, 2011 | Refrigerators
We have a refridgerator, about 2-3 years old, Model #ED5JHEXTB00. Side by side freezer, refridgerator that is not cooling as much as it should in the refer part. I'm not sure of the temp, but milk goes...
if your noticing frost on the back wall you have a defrost problem and need to address it immediatley before u get warm in freezer and refrigerator sides remeber that a refrigerator is just a cold air duct from the freezer.... defrost heater bimetal defrost thermostat ot timer defrost control is bad ...
Feb 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our compact refrigerator doesn't get very cold,
One is the coldest. Post a model number and I may can help more. If it's a manual defrost then defrost it. If it's auto defrost- If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 11, 2009 | Refrigerators
Deforst mechanism
you need to have a defrost or the freezer will not work unplugging the time clock then the compressor will not work. Tom
Jun 18, 2009 | Freezers
Refrigerators Logo
303 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
