Question about Vivitar ViviCam 5385 Digital Camera
When I turn my camera on everything is black, like the lens cover is on. Everything else seems to be working fine.
  • 149 Answers
PROBLEM IN SHUTTER FPCB
Posted on Sep 09, 2009
When I turn the camera on and look through the viewfinder, it's black. Also, if I flip open the little screen, it is black. It does show the little icons, but it's as if the lens cover is still on (which...
I have the exact same problem.
It started with the recurring "change batteries" problem - which was solved by using non-rechargeable batteries.
Now everything is working fine except there seems to be no light coming through the lense. Everything except reviewing mode is black and all my pictures are completely black. I dont know where the problem is. Could be the ccd. Might take this to the camera shop but im expecting it will cost over $100 to fix... any help?
Jan 13, 2011 | Canon PowerShot S2 IS Digital Camera
I have a JVC Everio GZ-mg20. It plays back fine, but in record mode the picture is black. It records audio, but video is black - as if the lens cover is on, but it's not. Does this just require a firmware...
I'm afraid that this is a fault. Your ccd, the image sensor, is either not working or has become disconnected. Everything else seems to be working, but the camera is blind.
Hopefully you can get this fixed under warranty. Otherwise it may be too expensive to be worthwhile.
Dec 04, 2010 | JVC Everio GZ-MG20 Camcorder
Fuji A220 Camera fell lens was extended and popped off. everything seems to work fine nothing appears broken. How do I pop the lens back on?
my fuji a220 shutdown when i turn it on while memory card is inside
if the problem in memory card i tried in pc and it works excellently
Jul 20, 2010 | FUJIFILM A220 Digital Camera
The screen is black. And pictures turn out black.
Hi there your lcd screen is fine but the Chances or damaged are lens or sensor of lens or circuitbord disconnect from the lens sensor. All cases you need to visit service center. Thanks.
Apr 04, 2010 | Samsung Digimax D53 Digital Camera
Black screen when recording and only audio
are you sure your lens cover is off the lens? if the cover was on the lens you would only see black and it would still record audio
Aug 06, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Lens & screen show black instead of item to be shot.
You need to go into the menu function to turn the screen on (this feature saves the batterys)
Dec 08, 2008 | Cameras
Sony Cybershot Lens Stuck inside!!!
I have the exact same problem with my Cyber-shot; the lens is stuck inside. After trying everything to loosen it (like wedging a razor knife between the sections, even dropping it or banging it against a book, etc) non of which I recommend, I finally got it open by PUSHING on the black telescoping section surrounding the lens itself. For some reason, this worked!
Nov 18, 2008 | Cameras
Lens (lens cover?) only opens halfway
Hmm, this has happened to me too now. And just like the previous two posters it happened to me once before, but after switching it on and off a couple of times it corrected itself.
Now, about a month later, it has happened again. And this time it doesn't seem like it's going to open fully any more. Out of interest how long have others had their camera before this happened? How many photos had they taken?
Bobster
Jul 15, 2008 | Fuji FinePix F10 Digital Camera
Lens
No live view or black pictures, but readable menus means a bad CCD or less likely, possible shutter on cameras equipped with one (more scarce on newer digitals)
Apr 22, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Black screen when I turn the camera on
You could be suffering from a frozen Iris. This is the part of the lens which varies the amount of light entering the camera. Or the lens cover may not be opening when you switch on. Have you tried pushing the middle button of the 3 which run vertically on the rear of the camera below the mode switch. I had one on my bench a few weeks back which had an intermittent black screen. It started of as black and when I stripped it, cleaned all contacts and put it back together it the flashed on and off. I then stripped it again and went over every cable associated with the lens, CCD and video board checking them for breaks and recleaning them and bingo, everything came good. I have another 72 at the moment with a similar problem, I fixed the same way but got left with lines running across the picture. P72's aren't the best cameras picture wise and are close to the most troublesome, at least around here. For any of the above faults I'd recommend a visit to your local tech. Good luck. BMW
Jun 26, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Vivitar ViviCam 5385 Digital Camera Logo
37 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
