Question about AEG Microwave Ovens
My built in AEG electrolux microwave has started arcing (only 3 years old) and the flexible plate covering the stirrer appears to hve a tear in it - what can I do? I live in Northumberland, UK.
  • 5,603 Answers
The plate should be an insulator and NOT causing the arcing.
Arcing is caused by EITHER not having enough food load with moisture content, OR using containers that have METAL in them INCLUDING bowls with metallic decorations or silvery/gold painting.
Posted on Sep 09, 2009
When i use the microwave it makes a very loud coughing and spluttering noise and there is a flashing of lights inside. It also smells of smoke. Any help greatly appreciated. I live Bristol, England if they...
proceed according. God bless youIf you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
If your microwave has a shelf in it, and you do not use it, keep it out. If one of the shelf supports breaks or comes out, the microwave will arc where the support was. You will have to sand the spot down, paint with appliance paint and re-install support. If the shelf shifts on the support and touches the side it will arc.
Your magnetron waveguide will either come out of the top, or side of the oven cavity. Some will have a stirrer in it(mostly top waveguides) with a panel over, or just a cardboard type cover over it. Over time, the stirrer cover can become warped from the heat which will expose the stirrer's metal shaft which will then cause sparking. These covers and stirrers come in a kit and can be replaced from inside the oven cavity.
Your cover over a side waveguide is coated with a substance on it, and overtime this coating can come off from the heat and moisture in the microwave. These waveguide covers are very easy to replace from inside the oven cavity. Touch up any paint that may have chipped or come off because of the arcing.
If your waveguide cover and/or stirrer are all OK, then the spark is coming from your magnetron. The antenna on your magnetrom has overheated and burned, sending the microwaves out at the wrong angle. If you catch this microwave oven repair early enough, you can usually get by with just replacing the magnetron. If the arcing has caused servere damage inside the waveguide, you will need a new microwave. Waveguides are not replaceable and most you can barely see into them, let alone sand and re-paint. In this case of microwave oven repair, when you remove the magnetron, you will see the burned antenna, or your magnetron will fail the test below.
Apr 04, 2013 | Samsung CE1031B Microwave Oven
Kenmore microwave is sparking when you it start and then goes to pause
see this steps and fix it. God bless you
see the guide for test the magenetron and another component.
Oct 03, 2012 | Kenmore Microwave Ovens
Sparks when starting then goes to pause mode
see this next steps. God bless you
My LG/Dometic MICROWAVE sparks inside the cooking area when turned on
see the next steps and follow with common sense: God bless you
Microwave is arcing If you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
Jul 26, 2012 | Microwave Ovens
My microwave just started to arc. Is the waveguide cover the metal piece inside the oven? Should I try to remove it to clean both sides with steel wool?
No the wave guide is usually a porous material that almost looks like a light colored cardboard piece. Sound as if the stirrer plate is waht you are seeing. Make sure M/W is clean inside completly. Any build up of grease can cause this. Also make sure to check for chipped areas and if there are use an appliance touch up to cover the bare metal areas. A good cleaning will usually take care of the arcing tho.
Feb 07, 2010 | Microwave Ovens
The microwave starts, then stops after a few seconds, and smells
Remove the cover after pulling the power plug. Check the transformer and large capacitor for signs of overheating. If they look ok, then remove the sheet metal wave-guide from the area where the energy enters the cooking cavity. Under the wave guide is a fan-like device called a stirrer that has a plastic bearing. This stirrer bearing is commonly arced over (when the oven is operated with nothing to heat in it). Usually the bearing looks good, but has arced internally. Replace the stirrer as a unit. The machine can be operated with the case off and a cup of water for a load, but keep you hands clear. Look for smoke.
Sep 07, 2009 | Panasonic NN-H504WF Microwave Oven
2 month old microwave is arcing in the centre under the plate?
You just need to remove the stirrer cover from time to time to clean off any accumulated grease from it and the parts behind it.
And be sure to clean up any spills quickly.
Your owner's manual should cover that.
If for some reason you do not have your owner's manual, please reply back with your brand and model number so we can help you find it.
Mar 04, 2009 | Microwave Ovens
Neff microwave h7871 arcing
This antenna is called the stirrer here in the US. Its purpose is to stir the microwaves to ensure even cooking.
The cover is usually made of plastic, as opposed to ceramic, and it keeps grease and food particles off the stirrer to protect it from arcing, which can damage the surfaces and the magnetron.
The stirrer, stirrer cover and the area around it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available in appliance parts stores and hardware stores.
Also, the stirrer will arc if it is not turning when the oven is cooking. That may mean a bad stirrer motor.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron and stirrer.
You can download Neff manuals here.
Even if you don't find your exact model, they should all have contact info for Neff in case you need to call them to get spares / parts.
Dec 13, 2008 | Neff H7871 Convection/Microwave Oven
Microwave issue
It could be a bad motor. You really need to connect it to power to fully test it. It may also be that the stirrer is binding.
Oct 23, 2007 | Microwave Ovens
Microwave oven defective
It's actually a stirrer. Its purpose is to scatter the microwaves to ensure even cooking, similar to the way a turntable does in other models. Having a stirrer instead of a turntable allows for a bigger dish.
The sparking is usually caused by deposits or grease or food debiris which heat, reheat and arc.
If the oven is used very long without the cover, that debris and grease can get onto the magnetron and ruin it.
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Aug 30, 2007 | Jenn-Air JMV8208AAS Microwave Oven
Microwave Ovens Logo
289 people viewed this question
Top AEG Microwave Ovens Experts
William Miller
William Miller
Kazim ERGUNEY
Kazim ERGUNEY
Raj Patel
Are you an AEG Microwave Oven Expert? Answer questions, earn points and help others
