Question about Craftsman Garden
Overhaul brushwacker model 636.796234 - Craftsman Garden
Need operators manual to remove brushcutter blade
Hi mine has a hole behind the blade that you put a screwdriver in then turn the blade till it goes in to an aligning hole then it's screws off
Sep 27, 2017 | Craftsman Garden
Craftmans brushwacker 32cc, won't start
First remove plug,if bad replace,Check air filter,if dirty,replace,dump gas-oil mixture and replace with fresh batch.
Apr 25, 2017 | Garden
99 gmc Sierra it does not go reverse but it does go forward. I want to know its the transmission or can fix something else.
overhaul the transmission. the shell wasn't hardened correctly in the 98-02 models. will give you a lot of trouble in the future. you would be best off overhauling it for a little cash now rather than fix everything that goes wrong in the future. an overhaul will cost you around $1500. but that's better than the $5000 you'll put into it fixing it piece by piece.
Dec 15, 2011 | 2000 GMC New Sierra 1500
I put a new carburetor on my craftsman model 358.795200 brushwacker; it idles ok but when i pull the throttle lever it stalls?
you will need to adjust the carburetor, I would use a 1/8 of a turn at a time, I am assuming the spark is new,also. Hope this helped Tim
May 22, 2011 | Garden
Brushwacker dies after starting. how do you flush the fuel line?
I'm not sure of the equipment you are refering to. If it is a 4 cylce motor you disconnect the line from the tank, remove the fuel filter, then remove the line from the carburetor. If you have compressed air, blow through the line. Be carefull and point he line in a safe direction, junk will fly out of the line. Clean the fuel tank befor yoou reconnect, then reinstall lines and a new fuel filter.
Nov 07, 2010 | Sears Garden
I have a motorguide electric motor model # st 200 made in 1991 it is a perfect trolling motor but gears #1 &#2 are gone.This a superb little motor for fishing just the right speed on small lakes.I'm...
How about selling your friend's old Motor to me for some $ . I don't care about the "gone gears" as I 'am converting a gas Brushwacker 37.7cc, to a boat motor. Charles Craver 336 254 9276 quietus.charles@gmail.com.
Aug 27, 2010 | MotorGuide Standard Motor Replacement...
My Brushwacker has a broken pull start rope (model 358.795800). I figure that it shouldn't be too hard to repair it, but I would like to find a manual for repair.
Good luck on finding a manual. You can get the exploded parts drawing off of the sears parts website! I have a 32cc model 358.791580 and the pull rope broke. The pull rope assembly is located inside of the motor housing. I am having trouble removing the clutch assembly since there is no key way or screw holding it to the shaft. Does anyone know if it is threaded on?
Feb 20, 2010 | Craftsman Garden
Carb not working
Dont need new carb!!!! Just need to clean that one with solvent. the floats are sticking up allowing fuel to flow. Pull it off then pull it apart and clean it with solvent for an hour. Or spray and wipe it several times with carb cleaner.
Jun 23, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
363 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
