Question about Hamilton Beach Steam Storm 14560 Iron
Exact temperatures for iron settings - Hamilton Beach Steam Storm 14560 Iron
  • 43 Answers
This depend on the fabric being ironed
Posted on Sep 18, 2009
Steam iron not steaming was working ok one min then no steam
If the temperature dial is not set high enough, or the thermostat is faulty and setting the cut-off temperature too low, some steam irons will fill up their steam chamber in their soleplates completely with water and stop steaming, until the temperature returns above what's needed to continously generate steam.
Nov 26, 2017 | Irons
Why does my iron contantly beep and no steam?
Hi Mary,
Check to see that your iron is set at a temperatures suitable for steam generation. Beeps are a usual signal to notify you that your iron is plugged and switched on but the temperature setting is low and cannot generate steam.
Oct 05, 2014 | Irons
Steam is escaping from underneath the iron, how to fix this?
Household irons can drip and spit out liquid water from the holes in the metal sole plate instead of producing steam if you have set the temperature too low. The obvious remedy is to increase the temperature, but this setting is not appropriate for all types of fabric. For example, the highest setting is generally recommended for removing wrinkles from cotton garments, and the lowest setting is generally safe for silk garments. Using the iron and its steam functions as the manufacturer intended can reduce or eliminate dripping. If that doesn't solve your problem, consider additional steam iron troubleshooting.
May 16, 2014 | Rowenta Irons
Why light blinks then goes off when switch is still in the on position
The thermostat in the iron controls the temperature of the iron. The red light indicates when the power applied to heat the iron which is set by the temperature dial on the iron. When it reaches the correct temperature the thermostat turn off the power and that is when the red light switches off.
Jan 15, 2012 | Irons
Iron producing lots of water
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 18, 2010 | Philips GC 8220 Iron
My Tefal iron stop steam GV 8150
Hello :
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Tefal Irons
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
Apr 21, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
My husband threw away the opereating instructions for our iron.
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
Nov 23, 2008 | Euro-Pro Shark GI490 Iron
Information
Chooses the temperature.
Being general, usually the higher the number the higher the temperature.
Check your garment for the correct temperature and the instructions for iron for the exact temperatures represented.
Hope it helps
R.
Jan 01, 2008 | Irons
Steam Iron
Try setting the thermostat to a little less than maximum
Sep 14, 2007 | Irons
Hamilton Beach Steam Storm 14560 Iron Logo
202 people viewed this question
Top Hamilton Beach Irons Experts
Jim Thurston
Andrew Taylor
Andrew Taylor
richie46
Are you a Hamilton Beach Iron Expert? Answer questions, earn points and help others
