Question about QSC RMX-850 POWER AMPLIFIER Car Audio Amplifier
Erratic signal coming from potentiometers
Causes speakers to kick in & out
  • stevieharrel Oct 09, 2009
    Sprayed volume switches with a good electrical contact cleaner and solved the problem.
    Problem Solver:
  • 14 Answers
Something is probably blown
Posted on Sep 09, 2009
Im trying to fix a p38 1999 wabcoD abs traction failure prpblem, live data for the abs sensors signal all round are the same and goes up and down with road speed.the wheel speed os&ns rear,up
Erratic signals come from the speed sensors(all that I found). At the sensors by the tires/CV axles. When I tear them apart (the bearings) they have fine metal around them. The causes the erratic signals. As you said, they seem normal at most points. But you have to watch and see where(the signal) they jump. Could be 2 MPH or 20 MPH. Replace that wheel bearing.
Oct 29, 2014 | Cars & Trucks
My precor elliptical keeps giving me error44
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Jun 26, 2014 | Precor EFX 546i Elliptical Version 4
9.31 precor error 26 and loud noise
Precor Error Code 26 Error Code: 26 Manufacturer: Precor
Model: All Models
Error Description: Error 26, Motor Pulse Width Incorrect - Observation of the speed sensor signal and verification the signal from the speed sensor is appropriate for the requested speed. If an incorrect or erratic speed sensor signal is detected the error appears. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Incorrect gap between the speed sensor and the speed sensor target.
  3. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  4. Damaged speed sensor target.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  3. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if
Jan 25, 2014 | Dmm Vision Fitness T9500 Treadmill
Precor treadmill err26
Model: All Models
Recommended Action:
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if necessary.
Dec 16, 2013 | Exercise & Fitness
Error 44
Corrective Action
Nov 27, 2013 | Precor Exercise & Fitness
Precor 9.45 err 26
Model: All Models
Recommended Action:
Feb 04, 2013 | Precor Exercise & Fitness
C956i Precor is displaying Error code 44 ?
Corrective Action
May 30, 2012 | Precor C956i Treadmills with HR /...
Speed error 26
Model: All Models
Recommended Action:
May 18, 2011 | Precor 923 LowImpact Treadmill
I have a C956 treadmill. I am getting error code 44, can you tell me what that means?
Corrective Action
Jan 04, 2011 | Precor C956 Treadmill with Cardio Theater...
Erratic volume
Either the potentiometer which sits behind the user knob has got a broken track or it is full of debris
You can buy a tin of Servisol switch cleaner (or similar, make sure it has a lubricant in it and that propellant does not harm plastics) take off the knob and give it a good squirt where the spindle of the potentiometer enters the cabinet
Give the spindle a few full rotations and another dose of cleaner , then give it a try
It is best if you take a cover off and apply the cleaner direct to the potentiometer
Jul 01, 2009 | Creative Labs I-Trigue L3500 Computer...
QSC RMX-850 POWER AMPLIFIER Car Audio Amplifier Logo
74 people viewed this question
Top QSC Car Audio & Video Experts
xxxxxx xxx
Are you a QSC Car Audio and Video Expert? Answer questions, earn points and help others
