Question about Linksys SRW224G4 24-Port Ethernet Switch
VLAN Problem i have a 1 zyxel modem connected to 1 D-Link DI-604 Router connected to 1 Linksys SRW224G4 Switch and the 2 D-Link DES-1024 Switch are connected to SRW. All computers are connected to the 2 DES-1024 switch. I want to configure 2 vlan, VLAN1 & VLAN2. The DES-1024 port 1 connected to port e2 on SRW and thats my vlan1. the another DES-1024 is connected to port e3 which is vlan2. The Router is connected to port e1. How can i configure the SRW VLAN to not to see each vlan, for example the VLAN1 cannot see all computers that connected to VLAN2 and same with the VLAN2 also can't see the VLAN1, this is for security reason for example VLAN1 is for Accounting Dept and VLAN2 is for Admin so they won't see file sharing to the other VLAN. Can I do this to my SRW224G4 Switch. Please help!
2 Suggested Answers
SOURCE: i've created 5 vlan on srw224g4 switch on 5 ports
are all the VLANs in the same subnet?
If Not,Can you ping the router?
IF So, you need to configure NAT for all subnets.
Posted on Feb 10, 2010
How to create vlan with linksys srw224g4
Login to the built-in web-server interface, and use the interface to add specific ports to a specific VLAN.
Jan 24, 2011 | Linksys SRW224G4 24-Port Ethernet Switch
I have linksys srw224g4 layer 2 switch how can i create trunk port in this switch
Log into the web management of the switch.
Go to settings --> Vlan Tabb
Under the VLAN click on the VLAN and you can see the ports .
Click on the trunk box under the switch port which you want to make as trunk.
Jan 10, 2011 | Linksys SRW224G4 24-Port Ethernet Switch
I have a Linksys SRW224G4 connected to a Netgear DG834 ADSL 2 modem 4 port router. It seems to drop the connection every 5 minutes or so. I've checked all the ethernet cables with a tester to ensure no...
The linksys may be assigning IP addresses that conflict with the router. Usually you need to disable Dynamic IP assignment in downstream routers and switches.
Sep 27, 2010 | Linksys SRW224G4 24-Port Ethernet Switch
DI-604 url 192.168.0.1 will not take me to the setup for the rout
Sounds like they both are getting the same IP address. Remove the x-box and see if you can log into the router. You may have to power cycle it. Once on, log into the router and make sure that DHCP is configured. Then attach the x-box and it should get a seperate IP address
Jun 22, 2009 | D-Link DI-604 - 4-Port Broadband Router [...
Modem and d link
Hello there,
Your internet connection should be setup properly in order for the router to give connectivity to both your computer.
You must contact your ISP and ask them for the IP's and put it in the router.
Apr 05, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
D Link 604 will not connect to internet
Hi Goldy,
The 604 should setup easily. Make sure you have it set to automatically get IP if you are using Cable, and for PPPOE if you are using DSL.
Once you have it setup. Shut down everything. Plug in the modem, wait 2 min. This allows the modem to get the info it needs from your ISP. Then bootup the 604. Wait 2 min, for it to get the info it needs from the modem, then boot up your computers.
Got to start>run and type in CMD. In the black box that opens, type in IPCONFIG. Your IP listed should be 192.168.x.x. THe X's can be any number from 1 to 253. If the IP is 169.xxx.x.x, you are not getting data from the 604. Check your firewalls, expecially if you are using a third party one, like Norton.
Jan 06, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Linksys SRW224G4 24-Port Ethernet Switch Logo
75 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
