Question about Homelite Garden
Blower starts but will not increase power when throttle is increased
  • 124 Answers
This is as simple as it gets. If the carb is 10 years old and has not
been rebuilt in the past 2 or 3 years it will need to be rebuilt or
replaced. The average life of the diaphragms is about 2 to 3 years,
If your carb has limiters which will only allow the adjustment
screws to turn about 1/2 turn, you will likely not get any relief from
adjusting the carb. You will have to take the unit to a local dealer
for help. Most likely you will need to replace or rebuild the carb.
The problem is that you most likely will not have a Homelite dealer
in your area. If you can not find help in your area try Southern
Supply Co. Their number is 205-833-2525 and they have anything
you will need for Homelite products and they will ship anywhere.
Ask for Jason. I hope this helps.
Posted on Sep 14, 2009
4 Suggested Answers
  • 68 Answers
SOURCE: blower wont run at full throttle
Start with the spark plug it is the easiest.
But sounds like the carbourator is dirty, Probably fouled with old gas varnish. When it is idling give it a little throttle, flip the choke on and then full throttle. If it goes full throttle and doesn't conk out, it is a fuel issue.
Good Luck
Posted on Dec 11, 2008
  • 229 Answers
SOURCE: Leaf blower does not respond when increasing throttle and engines
Unit is either having trouble picking up enough fuel or muffler is plugged. First disassemble the muffler and check that the flame arrestor screen is not clogged. Clean as needed. Cost, $0. Check fuel pickup line from fuel tank to carbureator for cracks. Replace if brittle or cracked. Next would be to check the diaphram in the carbureator. Even a small hole or crack can cause this problem.
Posted on Mar 31, 2010
SOURCE: loss of power leaf blower - gas
Had the similar problem- start with removing the exhaust intake plate 1st--- clogs with super fine dust initially then larger particles... Mine was completely clogged- cleaned er' out now she blows like the wind!
Posted on Jun 11, 2011
Cuts out when I increase the throttle
Blocked fuel injector in the carb, usually gunk in bottom of tank gets pulled through into carb so idle jet is ok but when you give it the beans the main injector is blocked and the idle jet isn\'t enough to produce increased power demand, ends up just sucking in air only.
also timing, leads, coil. check plug too. Red.
Apr 04, 2014 | 2011 Derbi Senda DRD 125 R
Throttle will not work
Most likely the cable linkage from had control to throttle has came off. reattach or adjust it.
Nov 08, 2013 | Husqvarna 502cc Back Pack Blower HVH 350BT
Low power
Check the spark arrester if fitted has not blocked with carbon,it should be fixed the the muffler outlet, or the exhaust port itself is not blocked with carbon
Apr 14, 2013 | Husqvarna 30cc Gas Backpack Blower
My 29cc 4 cycle craftsman gas trimmer loses power when I increase the throttle
While Holding the Engine at Full Throttle, Adjust the High Air Mixture Screw In Until the Engine Revs Properly.
Jul 01, 2011 | Craftsman 29cc 4Cycle Straight Shaft...
Engine rpm's increase without increaseing throttle,on start up. Not consistent. Goes back to normal quickly before driving. Happens ocasionally during driving. Fuel economy not affected.
if its petrol the throttle body may be in need of a clean and resetting or it may have a small air leak if its a diesel its worth checking the fuel filter they can get contaminated with oil if you find this the injector seals will also need replacing and the fuel tank and pipes cleaned out
May 02, 2010 | 2002 Volkswagen Jetta TDI
Mar 31, 2010 | Poulan Featherlite Gas Blower, with Low...
Wont start
I believe your carburetor needs to be rebuilt. The carb has very thin rubber diaphragms that meter in the fuel when throttle is increased. If diaphragms are hard, it won't allow enough fuel to satisfy the increased demand. The kit is fairly easy to install. If you need parts, email desertairrepair@aol.com.
Feb 10, 2010 | Garden
It starts but will not fully throttle even with the throttle pressed all the way down
you have two screws and the side of the carb. these twy screws adjust the high and low gas flow. at full throttle you can turn the (H) screw counter clockwise to increase the speed 1/8 turn at a time if there is no change you will have to rebuild the carb
Aug 12, 2009 | Echo Garden
Loss of power leaf blower - gas
Mar 30, 2009 | ECHO, Inc. PB-251C Handheld Blower
Blower wont run at full throttle
Good Luck
Dec 07, 2008 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Garden Logo
96 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
