Question about Whirlpool LGR8648 Gas Dryer
Intermittent ignition intermitent ignition
My dryer just stoped. when i press the start button it makes a noise and then theirs a small burnig smell if i turn the tumbler it works for awile then back to the dryer being stoped again.
Posted on Dec 11, 2007
2007 silverado, check engine light works intermit, also miss fires intermit
Does the CEL "work" intermittently, or it comes on intermittently? If it comes on intermittently, that's telling you that the PCM has identified an issue and there will be a stored diagnostic code that should point you in the correct directly to begin troubleshooting. For example, if there is a stored code of P0304, that means the PCM has determined based on sensors that cylinder #4 has a misfire. You will then need to determine if that misfire is due to a spark plug issue, a coil issue, a coil/plug wire issue, fuel injector issue, compression issue, or vacuum leak.
Nov 06, 2017 | Cars & Trucks
Carb solonoid wire burned , runs intermitent rpm plus backfires on cutoff of ignition
if that wire burned you may have burned other wires
check them all
cut off the end of solenoid so no fuel obstruction, or replace and hook up correctly
Jun 24, 2016 | Garden
2006 KIA.DOOR LOCKS; When you unlock the doors with remote, the doors immediately lock again. With the key, door unlocks and stays unlocked. however, the feature when you turn key to the right two times...
intermittant is spelled intermittent. .... Ah, locking system. ... You will find a broken wire in one of the doors that are used to set the door lock.
Probably the drivers door return wire.
Oct 26, 2013 | 1998 Honda Civic
Car will not crank, intermitantly
Sounds like it may be your starte. Does the starter make any noise when you tyrn the key? Fies it not make noise at all?
Jan 30, 2012 | Cars & Trucks
2000 monte carlo has intermitant start problem. I have been told that I have to replace the ignition switch and lock cylinder. Do I need to reprogram the system once I replace these parts?
I first would test the crankshaft position sensor. If the problem is intermittent that is a good sign. If the motor turns over but just doesn't start. If it is not doing anything, then the ignition switch may need to be replaced with will not have to be reprogrammed as long it is the same year and middle vin number
Jun 08, 2010 | Cars & Trucks
Intermitent spark from igniter on a GSX250S katana
check your pulse generator circuitry first. follow wire harness from side case to first connector take it apart and ohm out the four wires, they should be around 400-450 ohms. on my bike my reading were 136ohms and the other was showing open, i opened up the case to have a look at them and one of the pulse pickups was burnt..i changed it out and it fixed the problem.
Oct 22, 2009 | 1992 Suzuki GSX 250 S Katana
1999 honda civic 1.6L very intermittent no start/stall no codes happened twice in 2 months when cold stalls very intermit when warm in gear
IT SOUNDS LIKE A FUEL PUMP OR A IGNITION PROBLEM A INDICATION OF A IGNITION PROBLEM IS THE TACHOMETER SMETIMES WILL START TO BOUNCE UP AND DOWN. CHECK FOR SPARK WHEN IT DIES IF THERE IS NO SPARK THAN IT IS A IGNITION PROBLEM. TO CHECK THE FUEL PUMP TURN THE KEY OFF THEN TURN FORWARDTO THE ACC POSIION AND LISTEN FOR THE FUEL PUMP TO HUMM IT WILL ONY HUMM FOR 5-10 SECONDS EACH TIME TOU DO THIS. THE REASON IT WORKS INTERMITANTLY IS BECAUSE THEY ARE BOTH ELECTRONIC PARTS AND WHEN THEY WARM UP THEY FRITZ OUT LET ME KNOW WHAT HAPPENS AND GOOD LUCK
Mar 31, 2009 | 1999 Honda Civic
2001 Saturn
Fuel problems are usually fairly consistent and not intermitent, replace fuel and filters anyway if it's near it's service interval. I think this thing is injected, but I doubt there is a problem with injectors ... again most fuel problems (unless it's the fuel pump) don't come and go.
Your username is dieselhuffer, in the states we don't have saturn diesels, so I am assuming your saturn is a gas engine.  I would concentrate on the ignition system,  ignition box, high power coil(s), wires (it's probably not these).  Buy your mechanic friend the Haynes (about $20 from amazon, parts store or haynes.com) manual for your car, and have him go though the ignition system diagnosis portion of the manual.  I'll bet you a pint it's an ignition problem.
The bad news, intermitent problems are hard to find.  The (sort of) good news is, it will probably get worse to the point that the thing won't run at all, making diagnosis much easier.  Hopefully you'll find the problem before you pull out much of your hair.
good luck,
Nov 01, 2008 | 2001 Saturn SL
Whirlpool LGR8648 Gas Dryer Logo
73 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
