Question about HP Officejet J5780 All-In-One InkJet Printer
It says the status is offline, how do i get it online again?
5 Suggested Answers
SOURCE: blinking lights & offline-use printer offline
hi! how can i align my printer cartridge?
Posted on May 30, 2008
dominusnex
  • 15 Answers
SOURCE: HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Posted on Dec 14, 2008
SOURCE: how to switch from "offline" status to "online" status
I had the same problem with a Brother MFC-6490CW AIO printer. Here is how I resolved it:
Open the printers folder.
Right-click on the Brother printer and display the Properties page
Select the Ports tab.
In my system (Vista Premium), the selected port was a WSD port (whatever that means). Further down the list, there was a TCP/IP port that was obviously created by the Brother installation software. I selected the Brother-created TCP/IP port (which deselected the WSD port), applied the changes, and suddenly my printer was online. No idea what the difference between these two ports is, but I'll stick with the TCP/IP port until further notice.
Posted on Mar 02, 2009
I was also facing the same Problem, I solved it by following these steps
First I noted down the IP address from the Printer, Menu > Network > Wlan > Tcp/IP
then on my pc
1.Point to Printers and faxes 2.add new printer 3.a welcome window appeared click next --select local printer attached to this computer do not check automatically detect............. then click "Next" 4. Point to Create a New port then select HP Tcp/IP Port 5. a Welcome page appears again click Next 6. Now is the time to Write the IP address you noted earlier from the Printer also check Always print to this.......... 7. now by clicking ok or Next it will take some time to load another window 8. Now at the bottom left of this window you will find two options i selected the "custom" option, another window appeared click ok and wait for few seconds, when that disappear click Next Click finish and wait.......... 9. Here You go another window appeared Point to the Manufacturer Brother and then select the model MFC6490 10.Click Next and Point to KEEP THE EXISTING.......... or whatever option you like.. Now its easy follow the on screen steps untill you are asked to PRINT A TEST PAGE
NOW YOU ARE CONNECTED AND ONLINE AND ENJOY....
BUT HAY THE OTHER DAY I FOUND THE SAME PROBLEM "YOUR PRINTER IS OFFLINE" DON'T WORRY, i SOLVED THAT TOO 1--GET TO PRINTERS AND FAXES 2--SELECT THE PRINTER WHICH IS ALREADY INSTALLED AND SAYING " OFFLINE " 3--RIGHT CLICK AND POINT TO "USE PRINT ONLINE" THERE YOU ON FLY AGAIN!!!!!!!!!!!
THANKS MUHAMMAD IMTIAZ KHAN
Posted on Mar 22, 2011
Why the offline message
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Read More....
How to Fix an Offline Printer eHow and HP Printer Support
Thanks,
Jul 16, 2014 | HP Officejet Pro L7780 Printer
Printer offline wont print cant get back online
Step 1:
b. Click Printer.
Step 2:
If still you are facing issues, then update the printer driver. This should fix the problem.
For further precise instructions, please let me know the Operating Systems installed on the Computer.
Hope this helps..
Jan 12, 2014 | Canon PIXMA MX712 Wireless Inkjet Office...
Why is is showing me offline?
Hello and Welcome to Fixya!
Actually your status on Facebook is as "Offline" that's why it is showing you offline,
To become online you have to make your status as "online"
For this sign in your Facebook account, when your home page will open, On the left side down on the page there will be written that "you are currently offline to chat with your friends "Go online". Click on it and your status will become online.
To demonstrate it physically here given is a Picture which will surely help you out
I hope this solution helps you
Any more confusion, queries or for further assistance, I am here to help.
Thank you and Keep Visiting FixYa
May 05, 2011 | Facebook Social Network
Why cant i chat on fb
Hello thanks for using fixya
Actually may be your status on Facebook is as "Offline", that's why you are not able to chat
You have to make your status as "online"
If it not works the try to change your browser and the sign in again to Facebook, I hope it will work
For further assistance, I am here to help.
Concerned: Uxair Shah
Mar 23, 2011 | Facebook Social Network
My status says offline and I am trying to change it to online to make a video call and it remains on offline status
Skype has been having trouble all day. https://twitter.com/skype says Skype is now gradually returning to normal - we expect it may take several hours for everyone to be able to sign in again, howeverabout 6 hours ago via CoTweet
Dec 23, 2010 | Skype IM
Cannot change offline to online, what have I do and how can I make my Lexmark to online?
I usualy remove the printer and add it again, with the same port, driver and everything. It will show up as ready afterwards, offline status will dissappear.
Oct 27, 2010 | Office Equipment & Supplies
Printer status remain offline how do i set it online again - all cables plugged in can see the printer in the network with status offline
make sure the lan cable is properly connected and you are able to acces the printer ip.
Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 26, 2010 | Toshiba e-Studio 202L Copier
Nothing happens when i tried to print from my computer the status is offline what is wrong
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
Sep 02, 2008 | HP DeskJet F380 All-In-One Printer
Printer light keeps blinking and status stays offline even it is READY
UNINSTALL AND REINSTALL THE DRIVER SOFTWARE BRO...................
IT MAY LEAD U 2 A SOLUTION.........
TRY IT
Nov 14, 2007 | HP Deskjet D2360 InkJet Printer
HP Officejet J5780 All-In-One InkJet Printer Logo
98 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
