Question about Lands Phones
I have a door entry system in my office model number on phone hand set is A1 phone IEH/ICD there are Three phones on the circuit. I moved one of them which has door 1 and door 2 indcator lights and connected and extended all cables to new location. I reconnected as they were and now only door 1 opens any suggestions please. It is DEFINATLY connected as it was
  • 5,603 Answers
Bad splice ! If you used either the "beans" or wirenuts they can fail to connect rather easily.
Posted on Sep 09, 2009
Hi I have a Panasonic KX-T7667 Telephone and it rings for intercom calls, but for external line calls it won't ring, I just get the flashing lights for the phone line. I have tried the volume...
Solid lights mean it's not programmed in the ICD group. Depending on the issue of your system cabinet, ICD ring group pilot numbers begin with 600 or 601 and grow to as many as you need. Each phone that rings has to be a member of the group and you can program it to not ring, ring immediately, or a delay of up to 6 rings. In my office system ICD group members are assigned in system program 620.and the ringing is programmed in 621. It's not entirely friendly to change it by hand as the tables are assigned by group and position, but it can be done.
It's an installer function and requires the system password or permission to change it.
Carl
Jun 19, 2011 | Lands Phones
Tip
Nuvi 255W Delete Phone Numbers
Garmin Nuvi 255W Delete Phone Numbers
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 265WT, 275
Would you like to erase the phonebook entries on your Garmin Nuvi 255W, left over from when you bluetooth paired with your cell phone?
I can help you delete the phone numbers on your Garmin Nuvi 255W.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 255W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 255W WebUpdater to replace its firmware / system software.
I hope that helps.
____________________________________________
Backup your Nuvi 255W Favorites here.
Download Nuvi 255W Manuals here.
Download Garmin Nuvi 255W WebUpdater here.
Garmin Nuvi 255W Hard Reset here.
on Apr 23, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 265WT Delete Phone Numbers
Garmin Nuvi 265WT Delete Phone Numbers
Would you like to erase the phonebook entries on your Garmin Nuvi 265WT, left over from when you bluetooth paired with your cell phone?
I can help you delete the phone numbers on your Garmin Nuvi 265WT.
Follow these three steps to take to get your Nuvi 265WT running like new:
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
Change Nuvi 265WT Home Phone Number here.
Download Nuvi 265WT Manuals here.
Download Garmin Nuvi 265WT WebUpdater here.
Garmin Nuvi 265WT Hard Reset here.
on Apr 23, 2010 | Garmin n?vi 265WT Car GPS Receiver
2006 F-150 no manual.. does this model have a garage door opener built-in ?
It is not standard equipment.
Here is what the manual says (copied and pasted from owners manual)
HOMELINK WIRELESS CONTROL SYSTEM
(IF EQUIPPED )
The HomeLink Wireless Control
System, located on the driver's visor,
provides a convenient way to
replace up to three hand-held
transmitters with a single built-in
device. This feature will learn the
radio frequency codes of most
transmitters to operate garage
doors, entry gate operators, security systems, entry door locks, and
home or office lighting
Feb 27, 2011 | Ford F-150 Cars & Trucks
We have a KX-T7630 Panasonic phone system and we need to attach a caller id that diplays at least 20 calls; are they all compatible or do I need to buy a specific one?
It doesn't work that way. First of all, you install a caller-id card in your system, then the installer programs a call log button on a phone. This can log all calls into an ICD group and you get a maximum of 100 records per ICD group and a minimum of 480 records per system in a TDA-50. Those numbers change for ICD groups and increase on a TDA/TDE 100 or larger system.
Unless you understand and have access to system programming, it's a dealer program function.
Carl
Nov 13, 2010 | Panasonic KX-T7630 Corded Phone
Ring to other phones other than the switch board
When the system was installed, if you or your installer programmed it properly you set up ICD groups. Each extension that you want to ring goes into the members of the group and you can specify how the phones ring. It will also blink the buttons on incoming calls and you can pick up the call from anywhere by just pressing the button.
The programming manual is pretty specific on how to set ICD groups up. Your 5 fing delay is fairly long, so other factors need to be considered regarding intercept and No Answer call forwarding.
It's beyond the scope of a free forum to give specific programming help.
Carl
Oct 13, 2009 | Panasonic KX-T7633 Corded Phone
Call forwarding
The 50 command is for call forwarding of an individual phone, not the incoming calls. There are several conditions that have to be met to make forwarding work. First, you need your ICD group extension. It's generally 600, but we use 100 or 199 or 200 sometimes. The command is in the back of the Operations Manual (OM) and it is in the form of (assuming 600) *71416009+number#. *7140600 cancels.
http://www.public.carl.airpost.net/TDA/200_TDA_OM_06-121.pdf
Here's a copy of the manual, just in case you don't have one. Page 192 shows the sequence. You might also look at *710 command on the same page for setting forwarding. It is quicker than the 50 commands and sets the status of your FWD/DND button.
Carl
May 11, 2009 | Panasonic KX-T7630 Corded Phone
How to do check my missed call log
A Panasonic TDx system has 2 types of call logs, one personal for the set, and one for the ICD group.
Pick a spare button, press PROG, the button, and dial 54 STORE.
If you had incoming: 00x on your display, that button will light and you can now press it to see who called. Your Navigator UP/DONW key will step you forward or backward through the log. The LEFT/RIGHT key will display the 4 lines of the display if you're not using a 7636 phone.
If you want to see incoming calls to a particular ICD group, pick another button, and dial 54 plus the ICD group number. For example, I used 100 as my ICD group (now 600 by default). I have 2 buttons, one logs my extension calls, one displays the system calls.
Carl
Mar 09, 2009 | Panasonic KX-T7630 Corded Phone
Office Moves/Swaps
pretty new to this myself but ive moved a few numbers around from the server room.
ours is set up with the proper ext numbers on the extensions around the office and in the server room i have those numbers on a hub with another hub with ext numbers for the phones.
you will have to unplug the correct ext cable and plug it back into the new ext number for the office its going to
sorry if this is no good or not what your looking for, pretty new to this and if it does help then excellent
May 02, 2008 | NorStar M7310 Corded Phone
Lands Phones Logo
42 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
