Question about Amana ACE208 Convection/Microwave Oven
We have an Amana Ace 208 in our NFP office; nobody seems to know how it works and we can't find a manual. Any clue where to look? Best regards, Zan
Www.acpsolutions.com under literature tab.
Posted on Nov 11, 2010
Is there something else I can do before purchasing a convection motor for the Amana ACE 14 convection express combo oven. The convection motor hums and turns very slowly but will not spin when turned
Well, running that slow makes it a serious fire hazard, it needs the air circulating to spread and dissipate the heat. Other than having a pro look at it, I would take it apart and clean all the moving parts, esp. the fan motor/drive and fan blades. Dust, fibers, lint etc. can build up very quickly when near an intake port. If the surface of any component is oily it makes the build-up even worse. I've saved a ton of money by doing this, the latest example being a dishwasher that was going to be thrown away. I cleaned and re-assembled it and it worked great, they are using it to this day. The same thing applies to computers, laptops aren't too bad, but towers are a different story. If you haven't opened up your computer lately, or ever, you should do so. I think you'd be surprised. Hope this helped. Grim
Feb 13, 2015 | Amana ACE14 - Convection / Microwave, All...
Spec sheet for the Amana HDC18 and HDC 21. Straight 208 vac 3 wire? Control transformer included or do I have to supply a neutral?
The service manual is at our site here.
Jan 15, 2010 | Amana HDC18 Microwave Oven
I have purchased a RV with a comb. amana radar range and need a manual to know how to operate it can you help the model no is AMV6177AAV? I don;t know how to operste it at all
Hello MJ hartman,
Here's a link that will take you to a free downloadable copy of your Owner's Manual for the AMV6177AA Series combination Microwave/Convection (over the range) oven.
http://shop.amana.com/assets/pdfs/literature/amv6177aa.pdf
I also have a folder on my computer that I've labeled "Household Appliances and Equipment" into which I save an electronic copy of all Owner's Manuals and Guides for all the appliances we have, just so they're readily available without having to spend hours searching the web for them, again.
I hope you find this Very Helpful and best regards!
Dec 14, 2009 | Maytag Microwave Ovens
Ace 208 comes up with "hot" in display amana tech say not possible no code like this
Hello I´ve repaired a couple of ACE208 with hot message in the display. The problem is in the convection fan located on the back of the oven cavity, turn the oven on and quickly open the door and look inside to see if the fan is spinning (slowing down, the fan stopps when you open the door but you can see it slowing down) if it is not spinning the supporting screws of the fan sometimes loosen up causing the fan to hit the oven walls preventing the fan to spin freely -probably before the problem started to happen you could hear a loud noise- the fan can´t move the air throgh the warming elements causing them to overheat hence the hot message. The fan motor rarely fails so all you need to do is remove the stainless steel cover and the back black cover and tighten the mounting screws of the convection fan and clean it if it´s dirty. Hope this helps, both the ovens with hot message I have repaired get the green tag just by doing this or replacing the motor, I have no knowledge of other problems that may cause this.
Dec 02, 2009 | Amana ACE208 Convection/Microwave Oven
I have a amana ald10t microwave that is not working
Try appliancerepair.com. I've had good luck there. You can also cruise the web with a google search of 'amana ald10t microwave parts', and look at the websites offered for what you need.
Best regards, --W/D--
Aug 07, 2009 | Amana ALD10T Microwave Oven
Call engineer and E-10 on display on amana commercial URFS518S Micro wave oven could you please tell what the fault is and how i can cure it. Regards.
E10:
An attempt has been made to program the oven for more time than allowed.
1. Press STOP/RESET pad.
NOTE: Maximum cooking time is 60 minutes except when cooking with full
power (100%). In case of full power (100%), maximum cooking time is 20
minutes.
If that doesn't work, leave it unplugged for maybe an hour then try again.
An owner's manual that may work for you is here.
Oct 21, 2008 | Amana Microwave Ovens
I cant seem to program my microwave amana CRC10T2
You can find the service manual here and it has operation instructions, too.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 30, 2008 | Amana Microwave Ovens
Volume control
no there is no way to adjust the alert they come already factory set.good luck
Apr 16, 2007 | Amana ACE208 Convection/Microwave Oven
Amana ACE208 Convection/Microwave Oven Logo
156 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
