Question about GE Refrigerators
Fan does not come on in refrigerator. Removed and tested fan and it works. Freezer get cold.
  • 3 more comments
  • neljer Sep 09, 2009
    Not being familiar with this q&a system, I failed to list the
    model. This is an older GE refrigerator, model TBF18AEC, so no main board (1970's I think). Any suggestions...?
    two door, upper freezer
    The fan in question is the one in the freezer section for dissipation of cold air. The freezer freezes ice quickly.
    Thanks.
    Sorry for the delay. I had to check in at work.
    The fan does not work, no matter the switch position. There is no voltage at the fan connections.
    The cabinet interior lights do work when the door is opened.
    I did unplug the unit when removing and reinstalling the fan motor.
    Back to work...
  • neljer Sep 10, 2009
    Yes, we are talking about the fan in the freezer that blows cold air into the refrigerator cabinet through a vent or damper. Opening the door and pushing "both" door buttons does not actuate the fan. Turning the fan by hand with the buttons pressed didn't work either. I removed the fan itself and tested it. It does work, just not in the unit.
    This is an oldie, a GE model TBF18AEC, so no boards or electronics, not that I could see... (serial # GE591043)
    Thanks
    Some observations:
    The cooling coils for the freezer are in the bottom of the freezer compartment - no ice build up on the evaporator coils.
    The temp in the lower "refrigerator" compartment runs about 48-50 degrees, not cool enough, but surprising considering the fan doesn't work.
    The compressor seems to run continuously.
    The front edge of the "partition" between the freezer and the refrigerator compartment is noticeably warm (not hot to the touch but warm) when the unit is plugged in, cool when it is unplugged.
    Any thoughrts?
    Meanwhile, I will locate and check out the defrost timer...
    Thanks!
  • 4,070 Answers
So you have a fan in the fridge side or are you talking about the fan in the freezer. With the model number I can be sure but if the fan is not running and the compressor is running you may have a motherboard or electronic control which tells the fan when to run. The fan in the freezer normally blows air into the fridge through a vent or damper.
The fan may not run when the door is open so make sure the door switch is pushed. When the unit is in the defrost cycle the fan will be off.
see where model number is here http://www.appliancepartspros.com/modelnumber_locator.aspx
Posted on Sep 10, 2009
  • Charles T Nevin
    Charles T Nevin Sep 10, 2009
    No voltage at the fan.
    Is the defrost system working or do you have a lot of ice build up on the evaporator coils behind the back cover inside the freezer. Since the fan won't run in the defrost mode I'm thinking the defrost timer could be stuck in the defrost mode not letting the fan run. But this would also mean that the defrost heater wasn't on or you would notice the heat and the compressor wouldn't run to cool the freezer.
    It's possible the timer is blocking the voltage to the fan but is still running. If you can bypass the timer you can test this theory. You can locate and test the timer here> How to check stuff>
    http://www.acmehowto.com/howto/appliance...
    I will continue to think on this problem. Good luck.
  • Charles T Nevin
    It seems you may have another fan problem. The condenser fan underneath with the compressor should also be running with the compressor. It can be the cause of the warm walls.
    A light frosting on the coils in the freezer is normal. If there is no sign of any frost there could be a problem with the freon level or the compressor.
    President:
  • 1,188 Answers
Keep the refrigerator door open for more than three minutes and see if the fan turns on.
If the fan does not start after 5 or more minutes then the main board is probably faulty.
You will need to replace the fan motor and the main board. This is because the old fan motor has damaged the main board.
Look behind the refrigerator and you should see a metal plate about two feet from the floor, remove it to access the main board. Remember to unplug the refrigerator before attempting to replace the main board or the fan motor.
Posted on Sep 09, 2009
  • Adnan Bhatti
    Adnan Bhatti Sep 09, 2009
    Please provide the refrigerator appearance and type: whether it is two-door, one-door, bottom-freezer or other.
    Are you mentioning the fan which is inside the refrigerator for dissipation of cold air or the one near the compressor? I need these details to provide you further help.
  • Adnan Bhatti
    Are you sure that the fan does not turn on inside the refrigerator? It only turns on when you close the door. Open the door and close the door latch switch by hand (simulating a closed door).
    Next (with the door latch pressed) try turning the fan blades.
    If the fan turns on then the problem is with the defroster.
    Let me know if you can turn it on then I can tell you how to proceed to repair the defroster.
    Also please reply if you are sure the fan does not turn on.
GB2SHDXPS01 FAN RUNS CONSTANT, FREEZER ICES UP
Buy a used fridge on ebay, they are very cheap.
Dec 21, 2013 | Whirlpool GB2SHDXP Bottom Freezer...
Why is my refrigerator not cold?
Hello Is the freezer cold? If the freezer is cold but the refrigerator is not you could have a problem with the evaporator fan motor which blows the cold air into the refrigerator. By opening the freezer you can assure if the fan is working or not by listening and feeling for air blowing around. If the fan were working you would next check the damper door located in the rear of the refrigerator side which is a small door that opens and closes letting cold air into the unit and then closeing when the unit is cold enough. If the door is not opening you would check the door itself for any ice build ups on the door as well. In order to check the evaporator fan motor you would go into the freezer at the rear wall of the freezer you would remove the screws holding the panel in place. When you removed this panel if you seen any ice build up this is termed as a defrost issue and all ice would have to be defrosted useing a hair dryer. If you do have this defrost issue message me back and I will instruct how to diagnose and test to solve which part is causing your unit to have a defrost issue. I await your reply.
Thank you
Rick
Nov 28, 2011 | Refrigerators
The fan is not working to circulate the cold air from the freezer to the fridge
may be a bad fan motor . will have to be removed to test . and some models the fan does not come on if freezer is not cold enough .. . best to ck the fan under neath and clean the bottom coils . it may get colder and work. and if not remove the fan and replace it .. if older than five yrs it a good idea to just replace it . mm hope this helps feed back pls ..
Feb 01, 2011 | Refrigerators
Freezer cold and working fine, fridge not getting very cold. Have defrosted freezer, removed freezer back cover fan all working o.k. Jim
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 24, 2010 | Amana ATB2135HR Top Freezer Refrigerator
Freezer is cold, refrigerator is warm. sounds
check the fan from the freezer side if its not running /possible frozen or jammed will cause the refridge side to be warm the fan blows the freezer air into the fridge side to cool their is also a damper or duct control which can build up if no blockage or debris test fan for power if power than test fan it self if not running than repair or replace as necessary
Apr 09, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
Freezer circulating fan not working
Buy a pet cow, and all your problems will be solved!! :)
Jul 11, 2009 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Amana ARB2214CB refrigerator fan not working?
the fan is locted in the freezer and it blows up to the ref and it sounds like the fan quit working and needs replace to check it the be for sure take the back panel off and with the ref running test the leads to the motor and make sure you have 110 volts if you do it is a bad motor
Jul 07, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Freezer is cold but bottom of refrigerator is not
Replace the fan - it's called the evaporator fan. It circulates cold air evenly in the freezer and blows cold air into the refrigerator section. Its failure would cause the symptoms you describe. Good luck with the repair.
Jan 10, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Maytag mfd2561he bottom freezer
I had the same problem. I removed the rear panel of the freezer (4 screws), removed ice maker, and found the evaporator fan that blows cold air from the freezer to the refrigerator was bad. I removed old fan and began calling around for the replacement part. Turns out the original encased fan motor went bad because the motor was encased and condensation caused the motor to go bad. The new motor came with brackets and new unenclosed motor. Took 1 screw driver and about 1-2 hours of work. Make sure power and water is off before working on unit.
May 14, 2007 | Maytag MFD2561HE Bottom Freezer French...
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
