Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
Drainage problems the water drains out the air gap
  • 92 Answers
I believe there should be a flap that closes the vent during the wash and opens while drying. this is inside the door the motor is possibly bad
Posted on Feb 10, 2008
Kitchenaide dishwasher drains sometimes
You also might have a blockage in your air gap. Your air gap sits on your sink. You generally have the dishwasher drain line going into the air gap and then the other side of the air gap is a hose that attaches to the garbage disposal. If plastic items like stickers from vegetables and fruit go through your pump they can accumulate in the end of the air gap and cause no drain situations.If you do not have an air gap and your drain line is going directly into your garbage disposal then you need to make sure that the drain line sits higher than the dishwasher tub and has a loop in it. This will avoid any water backing back into the dishwasher when you are using your sink. You will need to take the cap off the air gap and look inside.
Apr 06, 2015 | KitchenAid Dishwashers
There are two hoses coming from my Bosch SHE45M06UC dishwasher. One is obviously the drain coming from the back of the unit, and the other is attached to the side looped and not connected to anything. I...
Many people realize the dishwasher connects to a little hose on the sink, it is called an air gap. However, many people wonder " The air gap is there to prevent the water from being siphoned out of the dishwasher. When water flows through the drain hose, it creates a suction on the water still in the dishwasher. The air gap, makes a hole for air to get in. That way, the water only leaves the dishwasher when it supposed to, when it is pumped out. Another benefit of an air gap is that if the drain hose becomes clogged, the dishwasher can still pump out the water. Instead of flowing through the hose, as it should, it can flow out the air gap and into the sink.
The dishwasher's drain line usually connects to an air gap mounted at the countertop level on the sink. The drain line continues from the air gap to either the garbage disposer or directly to the sink drain. If the drainage hose between the air gap and the drain is partially or completely blocked, wat
Aug 28, 2008 | Bosch Dishwashers
Well I do have a problem with the drainage, the pipeline will over flow whenwwashing machine is draining water out but I have ran a snake down it and didn't seem to find a clog. But the water splashes out...
There must be enough air allowed into the drainage pipe in order for the water to go down...Apparently there is not enough air entering into the drainage line to allow the water to flow quickly...Check the vent pipe on this drainage line. If these are new machines you may have to increase the diameter of the pipe so that displacement can occur as fast as the water is flowing.
Feb 25, 2015 | Washing Machines
Dishwasher Whirlpool quiet partner 2 will not drain
Check your drainage hose going to the kitchen sink. It should be routed up to an air gap on kitchen sink, or ran to the highest point as possible under the kitchen sink counter and then slope down into the disposer or branch wye tailpiece on your drainage piping depending on what your drainage configuration is. Not going up to the highest point, or an air gap, before draining into your drainage piping allows the water inside the dishwasher hose to drain back into the unit.
Feb 21, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
After starting the dishwasher with time 56 min, the time goes down to 55 min and after that time remains 55 min. After few min there it showed 0E in the display bar and it stopped working. Is that...
1. If the drain hose is kinked, water will not drain properly. Kinks will also catch food debris as it passes, clogging drain hose. Straighten any kinks or bends in the hose. Make certain that drain hose does not exceed 10 feet for proper drainage.
2. Check the drain air gap anytime the dishwasher is not draining properly. if the air gap is clogged the unit will not drain. The air gap is not part of the dishwasher. It is located on the sink and attached through the drain hose and garbage disposal. Not all homes are required to have an air gap installed.
3. Food residue or particles can prevent proper draining of dishwasher. Remove bottom rack and check unit for food debris or items that may have fallen into the bottom of the unit. Remove any items or food debris that may be preventing proper drainage.
4. If the unit is not leveled properly, OE Error may occur. Use a level to check sides and top of unit. if the unit is not level, adjust the leveling legs in the front and back (use leveling kit). Also check the mounting brackets. If one is tightened more than the other, it will offset the cabinet.
May 02, 2011 | LG Dishwashers
The auto drainage isn't working properly
You will need to check the drain hose to make sure that you don't have a partial blockage. If you have an air gap check that to make sure it is not partially stopped up. If you don't have an air gap check to make sure your drain hose is not lower than your sink drain allowing water from the sink to drain back into the dishwasher.
Jul 14, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Sink dishwater intrusion
Hello- Find drain hose from dishwasher under sink. Should have gooseneck ~ in hose run to keep water from getting back into dwshr. Does full sink drained all at once push water into tub? Sometimes stuff not disposalled yet blocks drainage. Older motors can tend to become weak with age, not pumping as much water out of tub as it used to.Anyway- Hope this helps- ED
Mar 01, 2010 | GE Dishwashers
Washing machine inlet/drain problem
You may have a simple problem known as "siphoning". Have you checked your installation/ In particular, the drain hose? the following link explains how to check and correct a siphoning problem with a washer:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Usually when a washer drains as it tries to fill, its a drainage problem of some type. You may have a simple problem that is easily remedied. You may not require anything, but pulling the drain hose up out of the standpipe and repositioning it to ensure there is a proper air gap for drainage. I hope this helps you.
Aug 14, 2008 | Washing Machines
Dishwasher doesn't drain
how do you check to see if the pump is pumping? The drain is not clogged or blocked and the line is not kinked. The garbage disposal is not clogged either.
Oct 06, 2007 | Dishwashers
Washer wont fill, keeps draining
If you do not allow an air gap for proper drainage on your drain line, the water will siphon out of the washer as it tries to fill. Double check to make sure: 1. You do not have the washer drain hose placed too far down into the standpipe. 2. You do not have the top of the standpipe sealed off. Placing the hose too far into the standpipe may cause the drain line to be sitting in water in the drain trap, leaving no air gap. Sealing off the top of the standpipe will have the same affect. Remember, you need an air gap for proper drainage. Only place the hose about 3 to 4 inches into the standpipe and the fit should not be tight. That is, there should be an air gap around the drain hose as it sits inside the standpipe. Double check and let me know if this helps.
Sep 10, 2007 | Roper RAS8445KQ Top Load Washer
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
73 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
