Question about Compaq Deskpro EN PC Desktop
Compaq cd drive to fast
I went in to divice manger and changed ide in the secondary to pio and still fast set ide and secondary to pio. In the ide advance settings there is no umda code any help would be great
  • skip mutz Dec 10, 2007
    When we play a music cd it plays to fast. use windows pro
    I think it windows meda player. Its's a freind of mine. How would I get the right audio driver for it. Where do I check to see what sound program it uses.
    I ran a new media player for windows 2000. Still to fast. I wonder is that it is a business machine the drive will always run fast
  • 36 Answers
The speed of a CD is not related to the communications speed, so you should set those parameters back, to the fastest available, because data stored on a CD is generally always digital, except for an analog AudioCD. I don't know what seems too fast, but if it is music playback, then it is probably a problem with an audio codec, only a very slight chance of a bad or wrong CD driver, that has mis-identified the CD drive.
If I knew more about what you are experiencing, I could advise further.
Posted on Dec 10, 2007
  • Rob Jacobson Dec 11, 2007
    Just a suggestion, and the instructions may not be correct for your operating system, but try this:
    Go into the Device Manager, and expand the Sound item, then double-click on line entry for your audio device, then click the Driver tab, then the Update Driver... button. Click Next, then Search for Suitable... and another Next (I think), then uncheck every thing but the Windows Update item, and proceed. Getting a driver update from the Windows Update site has fixed the speed problem for some people.
Toshiba Satellite A105 PC Notebook, DVD/CD Drive. The Drive is reading the DVD but not the CD. How do I change the settings for the drive to read both
You can't just change it from pio to udma. Go to Control Panel, System,Hardware,Device Manager, then expand IDE ATA/ATAPI, then right click on Primary IDE and select uninstall. Do the same for secondary IDE. Then just reboot your system, and it will autodetect all IDE devices. After that when you check, you should not have any devices in PIO, and your burner should work correctly. If not, stick it in a hyperbaric chamber for 2 days and see if that helps. smile.gif __________________
Jul 12, 2009 | Toshiba Satellite A105 Notebook
When i put my 8 gb sd memory card into the computer drive it will not pop up. and when i click on the drive it says "could not function because of an i/o error"
  1. Click the Start button
  2. Right click My Computer
  3. Select Manage from the resulting menu
  4. In the Computer Management window, select Device Manager
  5. In the right pane, click to expand IDE ATA/ATAPI controllers
  6. Identify your CD/DVD drive in the expanded menu and right click the appropriate drive
  7. Select Properties
  8. In the Properties windowsmag-glass_10x10.gif, click the Advanced Settings tab
  9. In the Transfer Mode box that represents your CD/DVD drive (typically Device 1); open the dropdown menu and select PIO Only
  10. Click ok and exit all windows
If this does not resolve your issue, then you will need to go back using the above procedure and change the Device 1 in step #9 back to "DMA if available". Then, change Device 0 to "PIO Only" in the Transfer Mode box.
For reference, the Device 0 is the Primary IDE Channel and the Device 1 is the secondary IDE Channel.
After you change your settings, make sure you restart your system so that the computer recognizes the changes you have made. After you reboot, check the settings to make sure they are in effect. If they are, your device should now work properly.
Jun 29, 2009 | SanDisk 8GB microSDHC Memory Card with...
DMA
You can download a software fix for it:
http://winhlp.com/node/10
It's called resetdma.vbs ,download it and then install it.
The site also has some tips if the software doesn't help you.
May 14, 2009 | Compaq Presario Notebook
Still needed solution of problem
Go to Control Panel - click on System - Click on Hardware - Click on Device Manager - click on IDE ATA/ATAPI Controller.
Then right click on Primary IDE Chanel - then click on Properties - Then Advance Settings - For the Device 0 in Transfer Mode select DMA if available. Then Click OK.
You can also select DMA for Device 1 too
Feb 09, 2009 | Compaq Presario Notebook
Need Solution of a problem
try this. go to BIOS, from your main page choice sata1 and press enter then press DMA MODE and chanege to UDMA5 press enter F10 save and exit
Feb 07, 2009 | Compaq Presario Notebook
Drive is not accessible. I/O Device Error
Method 1: Change the transfer mode for your CD drive in IDE Channel Properties
1. Click Start, right-click My Computer, and then click Manage.
2. Under Computer Management (Local), click Device Manager.
3. On the right side, expand IDE ATA/ATAPI controllers.
4. Right-click the channel where your CD drive is connected, and then click Properties. Typically, this channel is Secondary IDE Channel.
5. On the Advanced Settings tab, in the Transfer Mode box for the device that represents your CD drive, click PIO Only. Typically, this device is Device 0. Then, click OK.
If the issue is not resolved after you change the transfer mode for the secondary IDE channel device 0, your CD drive may not be located there. Use the same procedure to change the transfer mode back to DMA if available. Then, repeat these steps to change the transfer mode for IDE devices in the following order until the issue is resolved:
• Primary IDE channel, device 1
• Secondary IDE channel, device 1
Note Primary IDE channel, device 0 is connected to your boot disk. This is the hard disk that typically contains your operating system.
OR
Make sure that all cables are connected correctly
If you have another cable, try to use it. For USB devices, try to use another USB port. If it is internal dirve is there then Reseat it that means remove it and reinstal that
Then Set the BIOS as Default for that restart the system and before windows screen it gives the instructions how to boot in setup once you are in setup, on the bottom it says press F9 or F10 to set as default; different BIOS have different options so do the as the on screen instructons says.
OR
Try to access the media or device on another computer; try it on your friend or family computer
if it is not working contact your H/W Vendor
Aug 14, 2008 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Sony VAIO laptop; DVD-R not reading disks
Check the status of the device in Device Manager to make sure that the device driver is working correctly. (If you need help doing that please ask.)
If no joy then:
Change the transfer mode for your CD drive in IDE Channel Properties loadTOCNode(2, 'resolution'); loadTOCNode(2, 'resolution'); 1. Click Start, right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. On the right side, expand IDE ATA/ATAPI controllers. 4. Right-click the channel where your CD drive is connected, and then click Properties. Typically, this channel is Secondary IDE Channel. 5. On the Advanced Settings tab, in the Transfer Mode box for the device that represents your CD drive, click PIO Only. Typically, this device is Device 0. Then, click OK. If the issue is not resolved after you change the transfer mode for the secondary IDE channel device 0, your CD drive may not be located there. Use the same procedure to change the transfer mode back to DMA if available. Then, repeat these steps to change the transfer mode for IDE devices in the following order until the issue is resolved: • Primary IDE channel, device 1 • Secondary IDE channel, device 1Note Primary IDE channel, device 0 is connected to your boot disk. This is the hard disk that typically contains your operating system.
Jul 05, 2008 | Computers & Internet
Dvd Audio Garbled
Right click on My Computer, choose Properties, Hardware Tab, Device Manager. Expand the IDE ATA/ATAPI controllers, choose Secondary IDE Channel (Double Click) Advanced Settings. Current transfer mode should be highest level of DMA (if it is PIO mode that is likely your problem).
If it is PIO mode, click the driver tab and make sure the driver provider is Microsoft. If not, make sure you have the driver available. If the provider is Microsoft close out of the Secondary IDE Channel Properties window, right click on the Secondary IDE Channel in Device Manager, and choose uninstall.
Reboot the computer, then open device manager again, highlight IDE ATA/ATAPI controllers, right click and choose Scan for Hardware Changes. It will find the Secondary IDE Channel and reinstall it. The transfer mode should be DMA. Your CD/DVD will play like normal.
Jun 02, 2008 | Computers & Internet
My dvd-ram has light but dosen't work and i recieve the message I/0 errore device
Try the following:
1. Click on Start
8. In the Properties windows, click the Advanced Settings tab
9. In the Transfer Mode box that represents your CD/DVD drive (typically Device 1), open the drop down menu and select PIO Only
10. Click OK and exit all windows.
Device 0: Primary IDE Channel
Device 1: Secondary IDE Channel
Apr 17, 2008 | Computers & Internet
Compaq D510 sff Dma problem
Those might have been your specs but if you have updated windows some of your drivers autamatically change. Try rolling back the drivers or updating them again. The drivers change frequently when windows hot fixes are dowenn loaded your setting that you had and are trying to set it at are the ones when the system was new.
Dec 17, 2007 | Compaq Business d530 (PB185US) PC Desktop
Compaq Deskpro EN PC Desktop Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
