Question about Viking DEDO205 Stainless Steel Electric Double Oven
Viking VDSC3656 oven relay (PM010129) failed again
Viking VDSC3656 oven relay (PM010129) failed for the third time in three years... we were told to permanently disconnect the maxi-broil as this was causing excessive draw during pre-heat. Is this a design flaw that hasn't been addressed? Are we forced to do without maxi-broil from now on?
    New Friend:
I have the same problem - I am on my 4th unit and 3 different service people - I am told to keep a spare part - there is no fix - NEVER EVER EVER will buy another Viking Product - I tell all who ask -
Posted on Jul 19, 2013
  • 5,603 Answers
Try to find a relay that has higher contact ratings. Grainger hardware might have one that would fit. It sounds like a design problem and requires a bit of re-engineering to fix it permanently!
Posted on Sep 09, 2009
Viking oven locks up while baking. Cannot open oven door to remove food. What could be causing this problem?
Ovens usually lock when it thinks you are running the self-clean process. Unplug for 15 minutes and plug back in, if that fails call in service
Dec 12, 2017 | Viking Ovens
How do you clear Clock/Timer on a 1-year-old Viking Electric oven (Model # VESO1302SS)?
PDF]Viking Use & Care Manual
www.vikingrange.com/MEDIA.../m3500217_F20669.pdf
Viking RangeClocks and Timers ... the potential risk of fire, electric shock, personal injury or damage to the appliance as a result ... NEVER use aluminum foil to cover oven racks or oven bottom. ... Keep area around appliance clear and free from combustible materials, .... 1. Push and hold the "MIN/SEC TIMER" and "BAKE TIME" buttons.
Nov 26, 2015 | Viking Ovens
I'm looking at a used Viking double wall oven in gas-Viking Vgd0271SS.. Does anyone know anything about it?
This is a high end wall oven. Common break downs are oven ignitors, all ovens fo that though. Life span for an igniter is 5 to 10 years. Viking is rare to have problems..
Dec 07, 2014 | Ovens
Jenn air svd46800 oven not working
Good Afternoon,
The control boards in your appliance may have failed. There is a display board, part number 71001799 and relay board part number 12001693. Commonly we see transformers on these relay boards fail with power surges. Luckily, we do test and repair these parts. Remanufacturing these controls will save you the high cost of buying new, and each rebuild will come with a 2 year warranty-- which is three times longer than new. Email me if you have any questions! info@fixyourboard.com
Jun 05, 2017 | Jenn-Air Ovens
Viking Oven
you may have a couple problems here or just one.
1. Check the incoming gas pressure I believe on this oven it requires 7" of water column to operate.
2. check the output gas pressure at the gas valve it should be around 3.5" water column.
Looks like to me that either your utility company might have restricted the supply pressure or you may have a faulty gas valve or the gas valve might just need adjusted.
Hope this helps you
please rate me
Jul 17, 2008 | Ovens
Viking electric range
There is another fuse or circuit breaker inside the range. House fuse is at least 50 amps which would be way too large for 110 volt things. Your instructions will tell you where it is. Frigidaire used to hide it under one of the burners. I don't know where it is on a Viking.
Jun 11, 2008 | Ovens
Viking: VEDO205 Blew my inner glass door
If you can take the door apart then you can fix it. Remove all the retaining screws to access the inner glass.
Dec 11, 2007 | Viking DEDO205 Stainless Steel Electric...
Viking oven won't turn on
I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
Sep 20, 2007 | Viking DEDO205 Stainless Steel Electric...
Viking DEDO205 Stainless Steel Electric Double Oven Logo
670 people viewed this question
Top Viking Ovens Experts
Dan Webster
Dan Webster
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Viking Oven Expert? Answer questions, earn points and help others
