Question about Yard Machines 24a 452g729 5.5 Hp Chipper Shredder
How to sharpen blades on a Yard Machine 6.5 chipper
I bought this chipper shredder used and it won't chip branches. I assume the blades are dull and need sharpening. I have no manual so not sure where to start without disassembling the entire unit.
  • Ed Lee
    Ed Lee May 02, 2014
    First, disconnect the spark plug wire. Next, remove the feed chute. Now you can rotate the chipper flywheel by hand, (clockwise) and access the blade holders. The blades are held on with Allen screws and the can be hard to get off. A heat gun or propane torch may help. Once you get the blade off I recommend you take them to a pro these blades need to be balanced to each other. When you reassemble the blades to the flywheel be sure to use Locktight or others thread locking compound.
  • 486 Answers
Posted on Nov 08, 2009
Sharping the blades
I dont think you need to remove the fly wheel to sharpen blades. Remove the housing an the blades are visible an removed that way. Not a hard job at all.
Mar 24, 2014 | Central Machinery 5-1/2 Horsepower Chipper...
Sharpening blades on a troy bilt super tomahawk chipper shredder
the chipping blade use a knife sharpening hone the shredder side you can flip some over
Dec 11, 2011 | Garden
Need owners manual for 2001 yard machine chipper schredder model #24A464B131
I have a operator's manual for 24a 463b129 5.5 hp. I also have an operator's manual for the engine (Tecumseh). I purchased the chipper new from Home Depot back in 2002. I think you will be disappointed at the lack of information. If still interested, e-mail me your e-mail address, and I can send you a PDF copy of these manuals. (wchan@bushbros.com)
Mar 27, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Replace flails on 5.5 Yard Machine
Go to www.ordertree.com. The flailblade is p/n 719-0329, The shredder blade is p/n 942-0571, The chipper blade is p/n 981-0490.
Replace them you have to take casing off the unit to get to them.
Jan 22, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
I have a craftsman chipper / shredder and it doesn't do a very good job - is there a piece to change or a blade to sharpen?
The blade(s) should have usually two bolts on them depending how many blades you have. Mine only has one blade held on with two bolts and that is only on the side that cuts the larger branches up to two inches in diameter and should be sharpened on a grinding wheel because it has a specific angle to it. The other side that chips smaller branches and twigs it a type of flailer, meaning pieces of metal just swinging around to mash up the sticks and do not need sharpening.
Nov 24, 2009 | Troy-Bilt Chipper Shredder
I have a yard machinne 6.5hp chipper/shredder -
Oct 08, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Chipper Maintenance
Maintenance (excluding the power plant) Your primary maintenance concern with chippers and shredders is their knives. You can re-sharpen chipper knives, whereas you can reverse shredder flail-type knives when dull but you can not re-sharpen them. You must sharpen chipper knives with special sharpening equipment because they are made of high-carbon steel. Maintaining sharp knives can lengthen their life and the life of the machine by keeping power requirements low. An over-dulled or chipped chipper knife will need extensive sharpening, which will remove a large portion of the blade. This obviously will shorten its life. As soon as a blade is slightly dull, you should sharpen it to minimize the amount of blade-material that you remove. All knives need sharpening at the same time to keep them in balance-even if only one is worn or chipped. Also, you must use matched sets to keep the knife the same distance from the anvil for proper chipping and feeding. After removing the knives, clean the area where they are fastened with a wire brush to make sure they will align correctly. Be sure to torque the knife bolts to their proper specifications. You will need to examine the anvil and be sure it maintains a good, square edge. Occasionally, you may need to remove and sharpen it.
Aug 27, 2008 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Wood Chipper how to
Great input tina783. I have just one thing to add. Try to shred the branches within a reasonable amount of time. I found out that with my shredder, if I put older, dried up branches in, it tends to take a lot more time, as well as tosses chips back out at you. With newly cut branches, this wasn't nearly as much as an issue.
Aug 27, 2008 | AMANA TOOL 658060 PRESTIGE FINE DADO SET...
Yard Machines 24a 452g729 5.5 Hp Chipper Shredder Logo
2,531 people viewed this question
Top Yard Machines Heavy Machinery Experts
Roland W VanLue
Roland W VanLue
rjivaro
donald boissonneault
Are you a Yard Machines Heavy Machinery Expert? Answer questions, earn points and help others
