Question about Canon ImageRunner 2030I Black and White Copier
Scanner will not process and send data to (network) computer.
The printer works fine.
    Scholar:
  • 92 Answers
1)check directory of smb file from the send mode func
2)check your login password from your pc and the computer name must syncronise with the machine login password.
Posted on Sep 12, 2009
Printer not communicating with computer...software and driver updated and working properly.. keep getting network error code 101-5096
Your printer is not communicating with the computer correctly. Reinstall the driver of the printer. It should work fine after the reinstallation process. But be sure to uninstall the driver before you reinstall it. You should not overwrite the installation because the problem will still come back.
I hope this helps.
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Mar 03, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
The HP Officejet 8500 asks me to "select computer" when I attempt to scan.
The reason for this is that your printer can't just scan to itself, as it does not have any memory or hard drive space to store the scanned page(s).
You will find it is much easier/better if you run the scanner from a computer using a program that can process the scanned image, eg: Photoshop, PaintshopPro, etc...
That way the printer knows where to send the scanned data.
Hope that helps.
Martin
Mar 25, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I have a Kyocera CS 3035 and am having an issue with the scanner. I can sign into the scanner via IP address but when I try to scan to PC, the scanner gives me a communication error. I have done the...
you need to make sure the scanner file utility is running in the taskbar at the bottom right hand corner..do you hvae the utiltiy installed yet..it's off the cd..
Jan 24, 2010 | Copystar - CS-3035 Printer
HP d135 All-in-One it keeps giving me a scanner error - battery. Where is the battery located?
Scanner, put your scanner settings to "Skip preview and send directly to photo view center". If I set this option then I don't get the error. Its only when I use preview and then accept that I get the error. It may be that the usb port sends the data too fast or the data to tell the scanner to crop is corrupted in the scanner memory and the only way to clear it is to turn on and off. What if you sent the accept function through a network card that plugs into the back of the scanner, does it still get corrupted? Or what happens if you use an older slower usb port to send the data. I did everything, clean the glass, change battery. But this is the only thing that worked. Respond and tell me what happens with your printer. Thanks.
Dec 28, 2009 | HP OfficeJet D135 All-In-One InkJet...
Im trying to scan and the canon says: "set the pc to start scan"...? Nothing pops up on the computer, what do i need to do?
I'm using an MG5220 and got this same message. Here's how I fixed it.
On the printer control panel press the soft key to select the scan function. Then hit the soft key to select Save/Forward. Then select Foward scanned data to a PC. On the next screen make sure to select the appropriate PC. In my case I'm connected wireless but the selection was set to USB connection and that's why I was getting the error noted above. When I picked the PC that is connected wirelessly everything worked fine again.
Jul 12, 2009 | Canon PIXMA MX850 Multifunction Printer
Canon IR scan problem
Read the Manual (comes with Tool). If you don't have the Tool download it from the Canon site. Go to the copier and press the System/Options button next to Copy/Mailbox/Fax. Press Online. Then try scanning. Go back to copier and press Offline so can photocopy again.
May 27, 2009 | Canon imageRUNNER 2200
Scanner stopped working
check the windows firewall or antivirus.may be blocking the scanner
Apr 29, 2009 | Office Equipment & Supplies
When trying to scan, 7210 doesn't see/recognize networked computers
From each computer, you need to run the HP Director. When opened, click on SETTINGS, then SCAN TO settings to configure. This way it will transfer data to the scanner so that when at the scanner, that computer will be in the list of places to send a scan job.
Jul 25, 2008 | HP Officejet 7210 All-In-One InkJet...
Imagerunner 5000s scanning problem
run the network scangear utility from the start menu. Click "discover scanner", when the discovery is finished select your copier and then click apply.
May 28, 2008 | Canon imageRUNNER 5000 Copier
Canon ImageRunner 2030I Black and White Copier Logo
209 people viewed this question
old marine
old marine
