Question about Canon PIXMA MP600 all-In-One InkJet Printer
Mp600 error 6A00
Error 6A00 has appeared and it will not go away even after turning it on and off
any ideas gratefully received
Joan
  • 2 more comments
  • Anonymous Dec 24, 2007
    same here
  • Anonymous Jan 09, 2008
    I have this very problem and called Canon since I'm still under a year warranty.
    I was instructed to lift the lids and watch for 30 seconds and tell where the ink supply was positioned - to the left, the middle or the right. Mine did not move. It was to the right.
    I was then instructed to unplug the printer from the power source while the printer was still on, wait 60 seconds and plug back in. The printer was off so I turned it on and the message still appeared.
    It is a printer issue that needs repair... bummer!
    They are sending a replacement and I will send this back.
  • Miggz Feb 12, 2008
    I had a paper jam (2 days ago) and after it was resolved this error appeared and wont go away! Help! Thanks! :-)
  • Anonymous Jan 20, 2009
    error code 6A00 appears with the words error code below it and it is still there even after shutting the printer off and even unplugging it
  • 10 Answers
I have the Canon Pixma iP4000R printer. I had an error code of 6A00 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
I tried the “waste ink counter reset reset” procedure: Power on while holding the stop/reset button and pushing the service button twice, then pushing the stop/rest button 4 times to clear the error, but that didn’t work.
My ink cartridge carrier wasn't moving. I thought I had a paper jam.
I looked at a few blogs about my error on other Canon Pixma models and they kept talking about “sponges”.
The following is what I discovered that cleared my error and now my printer is back to printing!
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like the long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
The "sponges" are located on the right under where the ink cartridge carrier "rests".
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it. The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
I used a pen tip popped both “sponges” out and rinsed them with water and voila they were once again white. I think the rectangular one had so much ink on it it popped itself out of place.
My error is gone and I can print again!
Posted on Dec 30, 2008
As hinted by other users there is an area on the right hand side where the inks rest. this area has a white mobile cover that moves up and down with a spring attached to it. In my case this cover got sticky with remnants of ink. I did not open or unscrewed anything. I just moved the inks all the way to the left to gain access, move this cover up and down a few times, wiped with a slightly wet cloth as much remnant ink I could and thats it. When restarted error is gone.
Posted on Jan 01, 2009
  • 39 Answers
Error 6A00 usually refers to a problem with the purge unit -at the right hand side of the machine, under the ink cartridges when in their home position. If you have had paper jams and removed the paper, sometimes a pice of paper gets torn off and when the printhead homes , drags this paper to the right and blocks purge unit. Open lid when machine is on to free printhead. Unplug printer then using a torch have a look inside for some torn paper (often this will be black as it is soaked in ink).
Posted on Sep 18, 2008
Error 6a00 I checked under the print cartridge home position for any remnants of paper as suggested. There was no paper but there was a build up of ink on some clear plastic strips. I cleaned them off and it resolved my problem. I hope this may work for some others also.
Posted on Jan 20, 2009
I have a Canon MP600R printer. I received an error code 6A00 and the printer stopped working. As suggested I switched off the printer and unplugged. I lifted the lid and moved the cartridges over to the left out of the way. Using a damp cloth I wiped all around where the cartridges normally rest. It was filthy with ink. Put the lid down plugged in and switched on and its fine. Thank you for your excellent advice. Gordon
Posted on Mar 06, 2009
Ditto on Solution #9 As observed by other users there is an area on the right hand side where the inks rest when you open the cover. I had a very small piece of lose paper in this area near the white mobile cover that moves fore and aft with a spring attached. In my case the cover got pushed forward with the remnants of the paper. I did not open or unscrewed anything either. I moved the inks all the way to the left to gain access. I removed all the inks to check for residue on the electronic contacts. I wiped these and replaced the inks. I removed some paper remants on the right side and pushed the cover back -- it seemed to snap in place. I did this all with the system on -- the error LED indicator remaining on. I cycled on and off, and during printer boot up I observed the ink system was moving from side to side as it does when you are doing a printhead alignment. I ran a test print, and it took awhile while the LED indicated "processing." It now works like a champ.
Posted on Apr 26, 2009
Do not toss it yet!
I tried the recomendations made to MONKEYDOG and worked but just for a print or two. Had to do the whole ritual of unplugging, every time I needed to print. I read also on the net about a user that had some help from sombody from a remote computer. So... I thought>>>This can be fixed through software. I turned off the printer, unplugged it from the outlet, AND unplugged the usb cord from the printer. waited for a couple of minutes, plugged the usb and the electric cord, turned on my printer, and opened the printer settings on my pc toolbar, and on the mainteinance tab printed a nozzle check by clicking on the nozzle check tab, every thing looked ok to me on the print, so I went ahead and made a print head alignment by clicking on the Print Head Alignment button. So far 2 days is working fine.
Posted on Jan 23, 2008
  • unequalled Jan 29, 2008
    Ok, the error 6A00 came back after the fifth day. and fixed again with ink. I opened the printer to take a look at the printer cartridges,... Let me tell you that I do not use original ink and i have noticed that the REPLACEMENT for the small black cartridge is not recognized by the printer,... so I take the chip from the ORIGINAL black small cartridge and install it on the new full REPLACEMENT cartridge. (If you do not have an original small black cartidge chip, you must buy a original small cartridge to get one...you might as well wear the ink first).That worked ok, but then the printer refused to print when the Black larger cartridge was empty, even if the smaller one was full. The problem was that when you buy a replacement pack you do not get a large black cartridge. Now, the Large black cartridge had to be full forever to print. It is not supposed to do that, as the smaller Cartridge should take over, when the larger Cartridge is finished, But You know, the printer starts asking you these questions about if it is ok to print with non original cartridge, etc. and you just have to say yes, and this messes you up a little bit. All this meant that I had to also buy a large black cartridge everytime it emptied!!! NO-NO-NO!!! ...I said. So what I do, is I fill up the large cartidge with a suringe and bottle of black ink from a stratitec kit I had, ...I just have be sure to do not fill more than the cushion will absorb. You should not let (see) the ink move freely in any empty space, in any of the 2 compartments of the cartridge. Just soak the cushion good, slowly with the suringe, you do not need the needle, as the opening to the cushion is the size of a penny. I use new suringe every time to prevent dry ink to stop the printer. I install the large cartridge again, and pull out and click back in all the other the cartridges that are not blinking, to make them blink again. close your printer, This should take you just a few minutes, be sure to use gloves, and use some platic or newspaper to work on top of it. and you are ready to go again printing as I am. The printer is not going to warn you now about low ink. so now you know that when you start having problems again with your printing, go check your ink levels hope it helps. unequalled
I don't know if this will help but i have had this problem
all i did was take all the ink cartridge out and put them back VERY fimly which seems to have fixed it
Posted on Dec 03, 2008
    New Friend:
Same problem, same solution...move print heads to left, pushed L shaped plastic back, took out two 'plastic' pads and washed them and replaced them. Printer now works. I had to run the clean heads and deep clean heads maintenance tools to get the nozzles cleaned up.
Posted on Feb 16, 2013
Error code 6A00, moved the print head to the left by hand and witha light saw the L shaped cover talked about in other posts and cleaned that and under the cover that moves with a old tooth brush with alchol, wipped it dry and, and it now works, we'll see how long.
Posted on Mar 28, 2012
    Problem Solver:
  • 5 Answers
I had error 60AA on my Pixma MP600. I used a torch to see if there was any paper, there was none. I used a pen to push down the cleaning pads, and to my surprise the pads moved down and were 'released' from the ink goop sticky lock they were in. Now works fine.
Posted on Jan 14, 2012
Move the print head a few times from left to right and back again, I did that and now have a working printer again, without error code
Posted on Feb 25, 2011
MP600 is the worst printer ever. You can't even use the scanner if you have some problem with the printer (and you WILL have MANY problems, guaranteed!).
Posted on Mar 03, 2008
Its a position error.
The printer needs repair.
Posted on Dec 19, 2007
I also had this problem after a paperjam, I moved the Cartdridges to the left and checked for any ripped paper then pushed it back in place to the right then pulled out the power cord and left if for a min or so and plugged it back in and now works fine.
Good luck
Simon
Posted on Feb 18, 2009
Turned printer on and it comes up with Error Code 6A00
AP position error will trigger the 6A00 error code. An error occurred in the AP motor during purging operation. As per service manual, you will need to replace the sheet feed unit, logic board assy and purge unit.
Feb 22, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Error code 6A00
I HAVE A CANON MP600 ALL IN ONE PRINTER. SCANNER etc., AND I HAVE AN ERROR CODE OF 6A00 COME UP! both green and amber lights flashing and will not allow me to print... can you please help
Aug 23, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Erreur 6A00
Hello my friend,try to turn off your printer,unplug the power cord for few minutes.After that plug the power cord back to your printer and then turn on your printer.If the error still appears you have to get your printer for service.
Feb 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Cannon Mp600. I have an error code 6A00
Try
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Jan 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Have the canon mp600 and like others it has the 6A00 error that won't go away. It had a paper jam and paper was pulled out- can't see if a fragment is left. May try the shaking technique- other solutions?...
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 18, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Mp600 error 6A00: After you check for loose paper
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Apr 26, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code 6a00 on my cannon mp600 what does it mean
simply move the cartridge back and forth a few times
Feb 03, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP600 error code U043
You will need to call our technical support line on 0845 20 20 118
Dec 24, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon 6A00 error problem
If you look inside the printer on the right hand side you will see the head cleaning mechanism.
The 6A00 error means that this head cleaning mechanism is jammed. If you push the cleaning pad down gently with a cotton bud or blunt end of a penci it will fall into its normal position and may reset after you turn the power on.
If it doesn't then you have options.
If you are still under warranty then contact canon otherwise you may need to strip the printer covers off and clean all of the ink build up away from the mechanism and possibly need to replace the return springs that return the carriage to its home position.
I have had this problem a few times and the release worked for the first 4 months but then i had to strip it down, clean the mechanism and replace the spring with a similar one.
Jul 08, 2008 | Canon PIXMA MP600 all-In-One InkJet...
MP600
when i turn on my mp600 canon printer i get the same error code 6A00! i cannot do anything with the printer, please help!
Apr 08, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
12,493 people viewed this question
old marine
old marine
