Question about The First Years American Red Cross Soothing Baby Scale
American Red Cross Soothing Baby Scale not registering correct weight. Tried everything and it is on a flat, hard surface. Sometimes it registers 3 lbs and other times 4 lbs when baby is over 8 lbs.
Weight does not register
The scale is low on battery. That's the most likely answer.
Dec 05, 2013 | Ohaus ES50R ES Low-Profile Bench Scale
I have two Taylor Lithium scales and neither one of them will turn on. I have replaced the batteries, still they will not turn on. I have done a "reboot" as suggested on FixYa, but without...
The scale may need to be initialized. This process is necessary because the scale was moved during the shipping process. Initializing the scale "re-seats" the internal parts allowing the scale to find the correct "zero." Here is how to initialize your scale:
- Place the scale back on a hard surface floor.
- With one foot only, place just enough weight on the scale for the display shows zero's or dashes. Once you see zeros or dashes remove your foot.
- Wait for the scale to turn off again.
- Step up onto the scale for a weight.
Or, your scale may be on an uneven surface or on carpet. Be sure to place your scale on a hard, flat surface to get an accurate weighing. Are you sure that the place the new battery with the "+" sign up into the battery compartment?
Keep us updated.
Jul 15, 2011 | Taylor 5599 440 Pound Tempered Glass Body...
My health o meter bathroom scale is giving me several different weights suddenly. I have replaced the battery and that did not fix the problem. Suggestions?
You need to make sure your scale is on a hard flat surface to keep a consistant reading. If that does not correct the problem I would call the manufacturer and look into a replacement.
Nov 13, 2010 | Home
How do you switch the unit of measurment from kg to lbs?
When you first turn the scale on and you see all the units of measure across the top of the display, keep hitting the "on" button until the unit of measure you want is displayed.
Apr 16, 2010 | The First Years American Red Cross...
I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
  • Error 0: Initialization
  • Error 1: Instability (scale is on an uneven surface ex: carpet)
  • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
  • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
  • Error 4: Body fat is out of range
  • Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 15, 2010 | Health & Beauty
Nothing will display on the read out
Jan 03, 2010 | Taylor Dgtl Body Fat Scale
Negative weight on Salter Stainless Steel Kitchen Scale
make sure the battery your getting is a good one longlastig and if that doesnt work then how nout the motor
Aug 21, 2009 | Salter 2001 electronic kitchen scale
How to calibrate a taylor scale 5571
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight,to calibrate, or some other unusual error.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department.You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jun 13, 2009 | Taylor Body Fat Analyzer & Scale, Model...
I have a Tanita scale. It will not register weight.
Sounds like somehow it was calibrated to your weight as zero instead of 0. I would contact manufacturer here is the contact info.
http://www.tanita.com/en/contact-us/
Mar 16, 2009 | Health & Beauty
The First Years American Red Cross Soothing Baby Scale Logo
115 people viewed this question
Top The First Years Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a The First Years Health and Beauty Expert? Answer questions, earn points and help others
