Question about Whirlpool Dishwashers
Water is collecting at the base of the dishwasher after the washing cycle
  • 5,603 Answers
Either the door seal is bad or the seal for the pump is bad or a possible leak of the drain hose (not probable)..
Check the door seal by taping some dry paper right below the door and see if it gets wet BEFORE opening the door.
Posted on Sep 09, 2009
LG Dishwasher water flow is weak coming out of the lower spray arm. No water coming out of the upper spray arm. I changed the water inlet valve, and there isn't any difference.
There is a possibility the water pressure itself is low from the kitchen line or the dishwasher is set at incorrect water pressure setting and does not collect enough water based on the flow time of inlet valve. If you hear the wash motor cut in then there is not enough water in the base to start pumping it to through the arms.
Apr 11, 2014 | LG 24 in. LD-12BS6 Stainless Steel...
Bosch Dishwasher drain mechanism starts itself a few hours after a completed cycle and won't stop. I reset the dishwasher, but it remains unusable for a few days. If I turn on the dishwasher, th
this could mean there is water leak and it collects at the base of the dishwasher leading to moisture detection circuit tripping. when you leave it for a few days the water dries up and trip is removed. check door seals for leak most likely at the base of the door. turn power off when working on dishwasher.
Jul 18, 2012 | Bosch Dishwashers
WATER WILL NOT PUMP OUT OF MACHINE
Here are some solutions for GE built dishwasher when water will not pump out of machine:
During the wash and rinse modes of the cycle, soiled water falls down the back of the tub and into the filter area. The water comes through the filter and back into the tub. During the wash and rinse periods all ( we hope! ) the water will pass through the filter. The soil will settle into the collection chamber and is held there. When the dishwasher goes into the pump out mode the water in the sump is pumped through the collection chamber. This closes the piston valve to the inside of the tub. The pump flushes the collection chamber of all the food soil and pumps it down the drain. A check valve is located in the drain line port. This valve allows the water to flow in the drain direction only and prevents the water from coming back into the tub. The drain line check valve must close in the back flow direction or the piston valve in the collection chamber may not reopen into the tub after the pump out is complete. Water should "fall" through the filter and go back into the tub....the heavier food particles go down into the chamber and are collected.
Jun 10, 2011 | GE 24 in. GSD3960LSS Stainless Steel...
I have got DWN 38 L Bendix dishwasher, problem is that during the wash cycle water starts to come under the washer. To ,me it looks like it can't take the water out.
If water is collecting under the dishwasher then there could be a few reasons.
1. door gasket is leaking - check for defect and replace if required
2. the wash or drain pump could be leaking water. Seals are not sitting properly or drain hose is cracked.
Feb 15, 2011 | Tricity Bendix 24 in. DH104 Free-Standing...
Drain pump running when unit starts but no water to appliance
The machine probably has water in the base (not visibly in the machine, but in the base where the conponents are). Pull the machine out, sit the front on a large towel and holding the back of the d/w pull it towards you. Any water trapped in the base will drain out. It may be a fair amount as the flood safety switch will activate on approx 1.5 ltrs. Once you've cleared the water run a prewash or quickwash to check d/w. Hope this helps.
Jul 05, 2010 | Bosch SHU5315UC Dishwasher
Dishwasher stopped draining after cycle
Some water always remains in the bottom of the DW (al least with most DW) but here is some help....
GE dishwashers will have a sump entrance screen ( #4 ) that should be removed and checked for any gookus, see 1 or 2 screws on the cover top, which is behind the lower spray arm. Almost all ( some newer GE dishwashers have a separate drain pump and motor - but for our purpose, we will talk about the most common GE dishwashers ) GE dishwashers have a drain solenoid ( #1 ) that can fail and stop the draining. If the solenoid cannot pull in the silver plunger, the drain port will not open to allow the motor and pump assembly to drain the water out. The solenoid can be ohmed with an ohm meter for continuity, or tested to see if it is receiving 110-120 volts AC. Many GE dishwashers have a self clean filter ( #3 ) inside at the back. The draining water must pass through a plunger in the self clean filter body. This can get clogged up, or the plunger may twist and distort and not allow the draining water to get past. The filter can be removed from the inside and the plunger will twist out of the self cleaning body for testing/checking. Next obstacle for the draining water in the back flush valve ( #2 ). This valve can twist or distort and block the water flow as well. The drain port will need to be accessed to check this flapper valve, the drain port will untwist from the self clean filter body. All hoses in-between the items mentioned above and the drain hose itself all the way to the house plumbing should be checked for restrictions.
Some extra filter, draining tips and pictures....
Here is a link for you to check out...I have all this info in my data base but since it is in PDF format it does not translate well to this format...
http://www.applianceaid.com/gedishdrain.html
I hope this helps...good luck and ggod day...please rate my effort......thanks....The Fang.
Mar 14, 2009 | GE Nautilus 24" Built-in Dishwasher
Wash cycle will not start
it is likely that you have a water leak causing the dishwasher to go into flood mode. to find this out tip the dishwasher sideways and see if water seeps out of the base if it does it will need to be sourced.
Mar 11, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Bosch SHU9915UC Dishwasher - wash cycle won't happen
hi there your dishwasher has gone into flood protection mode ie. water has leaked into the base and activated the float switch.
to try and locate the leak tip your d/w back to drain the water from the base then remove both side panels and start a program to see if you can see where the water is leaking from, being careful not to touch anything while the d/w is running as live parts are exposed
hope this is of some help
Dec 15, 2007 | Bosch SHU9915UC Dishwasher
Dishwasher not resetting before new cycle
I have had the same problem. The issue is with the dip tray + overflow detector under the machine. What happened is the dip tray is full of water and the overflow detects this condition and prevents the machine from starting.
It looks like there is no water present in the machine but the drip tray, located underneath, is full. Give the machine a good shake and you should see water.
I solved it easily: just get a mop, lift the machine's front so that it tilts backwards and collect the water as it escapes the drip tray towards the back of the machine. The tray can collect quite a bit of water so you're likely to need a few tilts until it's empty.
In my case, the underlying case had been a previous mistake - we didn't allow the machine to finish completely and water had remained on it. Somehow the water had found its way to the tray. Other causes my be another appliance sharing the same waste pipe and pushing water down the dishwasher's waste system.
Mar 23, 2006 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwashers Logo
48 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
