Question about Nakajima AE-740 Typewriter
Is there a 'reset' to factory default or a clear all settings/memory functions for this typewriter? Not sure what has been set, saved or activated. Would like to 'start over' if that is an option. Thank you.
    Genius:
  • 1,218 Answers
Switch the machine OFF.
While holding down the Margin-Release key, switch the power back ON....... The machine will begin to print a "self-test".
It will keep on printing the self-test until you switch the power back OFF. After only 1 line of self-test you can switch the machine OFF.
Wait 5 secs, switch the machine back on, and you will have cleared memory.
Posted on May 28, 2010
What is a 116-386 error code
Resetting to Factory Defaults / Clearing the Memory
You can selectively clear information stored in your machine's memory.
  1. Press Menu on the control panel until Maintenance appears on the top line of the display.
  2. Press the scroll buttons until you see Clear Memory on the the bottom line and pressEnter.
  3. The first available menu item, Paper Setting, displays on the bottom line.
  4. Press the scroll buttons until you see the item you want to clear.
    • Paper Setting: Restore all of the Paper Setting options to the factory default.
    • Copy Setup: Restores all of the Copy Setup options to the factory default.
    • Fax Setup: Restores all of the Fax Setup options to the factory default.
    • Fax Feature: Cancels all of the scheduled fax jobs in the machine's memory.
    • Advanced Fax: Restores all of the Advanced Fax setting options to the factory default.
    • Sound/Volume: Resets the sound and volume settings to the factory default.
    • Machine Setup: Resets all of the system settings, such as the machine ID, date and time, display language and save modes, to the factory default.
    • Set Report: Clears all records of your faxes sent.
    • RCV Report: Clears all records of your faxes received.
    • Phone Book: Clears the speed dial or group dial numbers stored in the memory.
  5. Press Enter. The selected memory is cleared and the display asks you to continue clearing the next item.
  6. Repeat steps 2 and 3 to clear another item.
  7. ORTo return to Standby Mode, press Stop/Clear.
http://www.support.xerox.com/support/enus.html
May 08, 2015 | Office Equipment & Supplies
I ned reset (lsu) for printer dell 1610n
[Clearing the Memory]
You can selectively clear information stored in your multi-function printer's memory.
Press <Menu> on the operator panel until "Maintenance" appears on the top line of the display. 1.
Press the scroll button ( or ) until you see "Clear Setting" on the bottom line and press <Select>. 2.
The first available menu item, "Paper Setting" displays on the bottom line.
Press the scroll button ( or ) until you see the item you want to clear.
Paper Setting: Restores all of the Paper Setting options to the factory default.
Fax Feature: Cancels all of the scheduled fax jobs in the printer's memory.
All Settings: Clears all of the data stored in the memory and resets all of your settings to the
factory default.
Sent Report: Clears all records of your sent faxes.
RCV Report: Clears all records of your received faxes.
3.
Press <Select>. The selected memory is cleared and the display asks you to continue clearing the next
item.
4.
Repeat steps 2 and 3 to clear another item. 5.
OR
To return to Standby mode, press <Return>.
[Page 130]
Dell Laser Multi-Function Printer 1600n User's Guide
ftp://ftp.dell.com/Manuals/all-products/esuprt_printers_main/esuprt_printers/dell-1600n_User's%20Guide_en-us.pdf
Jun 12, 2014 | Dell 1600n All-In-One Laser Printer
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
May 21, 2014 | Xerox 3300MFP/X new 3300mfpx [a51t732]...
553SV Vizio TVand forgot the passcode. Anyway to retrieve it ? Or reset to factory settings
System Info
Display the technical information including model name, version and
revision of firmware, source type, and resolution.
Reset TV Settings
Return all Picture and Audio settings to factory default. A screen will come
up to confirm your selection or to cancel it. Press Left or Right Navigation
buttons to make the selection, and then press OK to accept it.
Note: This does NOT reset the Parental Control Password.
Clear Memory (Factory Default)
Use this function to reset the TV to the default factory settings. The screen
will display a message to confirm that you want to reset the values to
factory settings. Press ? or ? to make the selection, and then press OK to
accept it.
Guided Setup
Use this function to return to the Initial Setup menu. Use this function if you
want to have a guided setup when you move your TV. Refer to Chapter 3 for more information.
Note: Previously scanned channels will be removed.
Aug 16, 2011 | Vizio P2 42 in. HD-Ready Plasma Television
How can I reset chip samsung scx 4200 all in one laser printer. kumar
I am presuming you want to reset all the systems settings to the factory defaults. Try this:
Clearing memory
1 Press Menu until Maintenance appears on the top line of the display.
2 Press the scroll button ( or ) until Clear Settings appears and press OK.
3 Press the scroll button ( or ) to select the item you want to clear.
• Paper Setting: Resets all of the Paper Setting options to the factory default.
• Copy Setup: Resets all of the Copy Setup options to the factory default.
• All Settings: Resets all of your settings to the factory default.
• Machine Setup: Resets all of the system settings, such as the display language and save
mode, to the factory default.
4 Press OK to confirm clearing. The selected setting is cleared.
5 Repeat steps 3 through 4 to clear another setting.
6 Press Stop/Clear to return to Standby mode.
Nov 30, 2010 | Samsung SCX 4200 All-In-One Laser Printer
MEMORY FULL ON SHARP UX-460
In addition to clearing memory this *will reset unit to factory defaults.
*****all of your programmed settings will be erased.
First power down the fax by unplugging, then power on.
After the power is turned on and "WAIT A MOMENT" is displayed, press & hold the STOP key.....until a normal display message shows.
*The above step allows the memory to be cleared! If this step is skipped clearing memory to factory defaults, (below) may not always work.
Press the "function" key followed by ALL of the following
9 * 8 # 7
wait until "diag mode" is showing.
Then press start button, followed by either * or #
until "memory clear" message is displayed.
then press start. If stressful "memory cleared" is shown.
proceed to re-program your fax machine settings.
Oct 20, 2010 | Office Equipment & Supplies
How to clear a tab setting. Have tried Code Tab set (Clear) and this does not work.
Refer to the op. manual if you still have it... if not you can download one FREE at www.nadist.com .
As a last resort you can try a complete clear...this will reset machine back to factory defaults and clear memory tho.... so if you want to try it... Switch the machine OFF. Then while holding down the MARGIN RELEASE key switch the power back ON.
The unit will begin printing a pre-programmed test page, let it run for half a line and then switch the machine back OFF. Wait 5~10 seconds then switch the unit back On and the machine will be back to Factory defaults.
Jun 30, 2010 | Nakajima AE-740 Typewriter
How to restore to factory default settings ricoh
enter service mode then execute these service programs I would do an sp print
5990- 2 out first just in case
5801 Memory Clear
Resets software counters and returns modes and settings to their defaults.
All clear: Clears all data
Engine clear: Clears the printer engine settings
SCS: Clears the systems settings
PRT: Clears user mode system settings
NCS: Network control systems - Clears the items listed in the “Host Interface”
section of the Configuration page.
DCS: Delivery control system (e-mail settings)
MIRS: E-mail addresses
5801 1 Memory all clear
5801 2 Engine memory clear
Resets the following user tool settings:
Maintenance menu: Main scan registration, sub scan registration, image
density, curl control
Resets the settings of the following SPs: 1003, 1104, 1105, 1902, 1910, 2001,
2112, 2113, 2201, 2213, 2301, 2910, 3921, 3922, 3923, 3924, 5930
5801 3 SCS memory clear
Paper Input menu: Paper type, paper size, tray lock,
System menu: Energy saver timer
Resets the settings of the following SPs: 5009, 5812
Also resets the user code counters.
Nov 10, 2009 | Ricoh Aficio SP C410DN Laser Printer
Lexmark t420 all leds are on
What this light sequence means:
• The printer is processing a request to cancel the current print
job.
• The printer is resetting to the user default settings. Any active
print jobs are canceled. A user default setting is one you select
and save which is different from the factory default setting. A
user default setting remains in effect until you make another
selection and apply it or until you restore factory default settings.
What you can do:
Wait for the message to clear. It clears when the printer finishes
processing the cancellation request or when it resets to the user
default settings.
Oct 24, 2007 | Brother HL 1430 Laser Printer
Nakajima AE-740 Typewriter Logo
226 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
