Question about Garden
I have a ryobi electric strimmer and one of the spool catches has broken off, which leaves the spool hanging out of the holder, where can I get a replacement here in the republic of Ireland, make and model to follow
scrodamoon
  • 659 Answers
SOURCE: Strimmer Line
rotate the starter pulley by hand. You should feel the spring getting tight. Once the pulley is slightly tensioned, usually 5-10 turns, release the pulley and let is pull the string onto the pulley. You may have to add some tension to get all the rope to wind on the pulley.
Posted on Oct 04, 2008
  • 22 Answers
SOURCE: Strimmer line replacement
what model do you have?
Posted on Apr 03, 2009
  • 6 Answers
SOURCE: Changing head on ryobi rlt3725 strimmer electric
make sure all the screws are out you might have missed one. if you have them all out then VERY GENTLY pry it off, the gasket is probably just stick, if you still can't get it off go back and search for that last screw you forgot.
try getting on the mfg web site and look at the break down. to see what it shows make sure on doesn't come thu from the other side.
Posted on Jun 14, 2009
SOURCE: Manual - Ryobi RLT30CES strimmer
Try this one:
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Cheers
Nigel
Posted on Sep 10, 2009
Testimonial: "Thanks. Got it."
  • 6 Answers
SOURCE: Can't figure out how to replace the trimmer line
Throw the trimmer spool in the garbage and get a Gator head. It will be the best $20.00 you ever spent.
Posted on Mar 31, 2010
My string keeps going back into and catching underneath the spool. How can I stop this?
Trimmer cord can become brittle and break off prematurely, the material can absorb water and become more flexible, so you should store any new cord in a bucket of water to keep it flexible,
May 29, 2018 | Ryobi Garden
How do I remove spool holder from drive shaft?
Depends on make and model. Most electric strimmers have a removeable cover over the spool. This cover has 2 pressable tabs that releases the cover that then lifts off exposing the spool. Some spolls are clipped into this cover, others sit on the drive shaft from the motor. In both cass the spool should lift off / out. Make a note of the direction that the cutting line is wrapped around the spool so that you can re wrap it correctly with new line. Hope this helps
Sep 15, 2016 | Garden
How to replace the spool head
Once you remove the spool cap and the spool, you cannot remove the head from the motor. It is not a replacement part.
Ryobi P2002 Cordless String Trimmer Parts
Aug 31, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Purchased a gardentec petrol strimmer a while back from netto store...where can i get a spool replacment to fit my strimmer.
try Lowes or any Agway, and if that dowsn't work, try checking on line with your type of trimmer.
Apr 22, 2012 | Garden
How can i strimmer wire on a ryobi plt 3043ye
Hi alice louise
Try this method
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 02, 2011 | Ryobi 15" Electric Factory Reconditioned...
Strimmer Line
Oct 04, 2008 | Garden
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
