Question about OKI B4525 MFP All-In-One Laser Printer
My Oki B4545 printer displays "** PRINTING ** STORED DOCUMENT" on the front LCD. This is causing the printer to remain locked/frozen. We can receive or send faxes and can not print. How can I get rid of this message or reset the machine completely? I have tried working through the menu options to clear any jobs but nothing exists. I have tried unplugging and restarting the printer ... this doesn't work either. I have tried contacting Oki support .... good luck for me with that. No response. Any ideas?
  • oliver297 Sep 09, 2009
    Found a solution to this problem.
    You can either erase all stored documents, faxes, emails etc or you can reset the machine back to factory default.
    If you reset the machine back to factory defaults, you may want to write down or print your configuration settings first. This can be down using the "Companion Settings" software or by checking each configuration setting using the printers on board LCD menu. Having your configuration settings in hand will make it far easier to setup your printer again.
    To perform either option you will first need to do the following using the printers on board buttons. Button presses are pressed in sequence, not at the same time:
    - Press the down arrow, * , # and then OK.
    - Select the "SOS1" option and press OK.
    - Change the left most 0 to a 1. Leave the rest as is. Press OK and then press the Red Button.
    Now you can do one of the following.
    To erase stored documents:
    - Press the down arrow, #, 8
    To reset the printer to factory default:
    - Press the down arrow, #, 9
    If you want to do both options above, you will need to perform one and then repeat the initial steps above to perform the other.
    That's it! It took me a while to track that information down so hopefully someone will find some use for it.
Put A4 in upper tray error
Change the printer properties to use paper from the automatic feeder tray. And, unless you are in Europe, you probably don't want to specify A4 paper. Try "letter" or some other size.
The manual is at this URL. See page 49 http://www.manualslib.com/manual/113847/Oki-B4545-Mfp.html
Apr 25, 2016 | OKI Office Equipment & Supplies
The machine say replace toner and the toner is new
Try un-plugging (electricity) the machine sometimes this will re-set the memory.
Nov 28, 2013 | OKI B4545 All-In-One Printer
Error message: Service Call 980 - Fatal Error
It means a call to OKI will be necessary. Typically, fatal errors are related to internal ROM, or board components that effect the boot process of the printer. When it can't boot - you get this type of message.
Dec 31, 2010 | OKI Electric Industry B4545 Laser Printer
I am trying to find a free download manual for the OKI B4545 MFP. Cannot seem to locate it anywhere.
No problem all the way from Wales UK for you.
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/Oki B4545MFP .pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Hi there
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 23, 2010 | Oki Electric Industry Oki - B4545 MFP...
My Oki B4545 MFP alarm always on
Solution provided by printer manufacturer tech support which worked for me.
1. Open all doors (front & back)
2. Remove tonner
3. Turn off power
4. After 20 secs turn on power
5. Close back door
6. Insert toner
7. Close front door
Fixed now!
Jan 25, 2009 | Oki Electric Industry Oki - B4545 MFP...
OKI MICROLINE 591
You need to set and store paper size, width etc in printers internal menu and on print driver on pc.
See Oki manual for printer settings its written on the front of the machine i think menu and set power on, then print to see settings then read manual...
Jan 04, 2008 | OKI MICROLINE 591 Matrix Printer
OKI B4525 MFP All-In-One Laser Printer Logo
679 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
