Question about HP 48gx Calculator
HP48GX Calculator "On" button works intermittently
The On button on my calculator only works some times. I thought it might be some sort of contamination so I peeled back the top metal sheet to look inside. That sheet is the one with all of the purple and teal button labels. Underneath are the buttons themselves. When I pulled up the On button, I saw the silver button underneath it. Everything appears clean. I can press the silver button with a pencil and feel it click, but the calculator doesn't always respond. When I press the On button down against the silver button, I get the same click and intermittent response.
Any ideas?
  • Anonymous Mar 18, 2014
    What is the button I press to calculate 10 to the power of 6?
    President:
  • 1,188 Answers
The calculator battery may be weak. Replace 3 AAA cells and check if it works.
It is possible that sweat from your or someone else's hands hand leaked inside and dried up leaving a salt residue between the connections.
Remove the screws on the back panel to dismantle your calculator then use a piece of paper to clean the contacts between the top and bottom connector.
If you cannot get this done then take it to a watch repair shop. The person there can assist you.
Posted on Sep 09, 2009
    Brigadier General:
  • HP Master
  • 3,614 Answers
HI,,
Eventually there was a electronic failure on the board, yes the switch was fine but there was a short circuit on the connections from the switch to the electronic board, or a problem on the battery terminals to electronic board.
This may need a professional to check and look on the problem, the circuit board has to be test with a multimeter, to identify the parts has failed.
Hope this initial info/idea helps
HP48GX does not turn on
no sry get a new one
May 23, 2010 | HP 48gx Calculator
Hp48gx was dropped, now difficult to turn on if at
Warning
In the keyboard test (below), make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the beginning of the post and skip to the last part For Repairs )
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the diagnostic tests.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Release the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterward you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a high pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.-
For repairs
You can also try this site. They do repairs on most models, except the newer ones.
May 10, 2010 | HP 48gx Calculator
Change batary lost desplay of charecrers
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
The following procedure valid for the 48G should work for the HP48GX.
Self test.
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
System Halt
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
Hope it helps.
Aug 10, 2009 | HP 48gx Calculator
The calculator is dead. Batteries are OK.model
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Aug 05, 2009 | HP 48gx Calculator
Hp48gx is autistic
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Jul 16, 2009 | HP 48gx Calculator
The calculator is intermittent: Most of the time
Not knowing what to do, I tried anything that could possibly help:
I installed fresh batteries and I pushed the reset button on the back of the calculator (Sharp EL-546L) and finally, it work all right after more than 5 years I own the calculator and where it did work correctly for 5 minutes. I tried the reset button in the past (long time ago) and it didn't work. This time it worked because, maybe, I've used fresh batteries.
Marcello
Jun 03, 2009 | Sharp EL-738 Scientific Calculator
Hp48gx got wet and wont communicate wit sokkia surveying equip?
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
For repairs
There is an HP customer self repair (CSR) which you can contact. On the site it is sais that the service is available for products under warranty or on contract. but you have nothing to lose by contacting them. Here is the link to the web site
Feb 23, 2009 | HP 48gx Calculator
I HAVE A HP-48GX THAT WANT TURN ON.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Feb 05, 2009 | HP 48gx Calculator
HP 48GX problem
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Sep 03, 2008 | HP 48gx Calculator
ON switch
.The selft tests will show you what is wrong, and if the calculator requires repairs.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Jul 01, 2008 | HP 48gx Calculator
HP 48gx Calculator Logo
161 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
