Question about Frigidaire Refrigerators
Frigidaire frs24zrh refrigerator not cool enough
I have a frs24zrh side by side refrigerator. Noticed both freezer and fridge side not cooling enough. I defrosted and cleaned everything. Took inside panel off to look at coils. I had to melt block of ice on top of coils. Put everything back together, and set controls to normal. Fridge is only 50 degrees. Freezer is 42 degrees. Could this be thermostat?
  • thorze Jan 04, 2008
    I have the Frigidaire frs26zshb2 and I have the exact same problem, although it has since gotten worse. I thought I narrowed it down to the cold control thermostat and replaced it today. That hasn;t fixed the problem. I am going to check the compressor agian and the capacitor.
    Any advice would be greatly appreciated
    Thanks
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
Posted on Sep 26, 2008
Refrigerator wont cool but freezer does
The problem is the Ice Dam inside your Freezer. You have to defrost the Freezer (making sure to completely dry the Bottom of the Freezer and more importantly the DRAIN TUBE)...
Jul 20, 2014 | Frigidaire FRS6R4E Side by Side...
I have a frigidaire gallery side by side refrigerator. The freezer side seems to be working but the refrigerator is not cooling
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 13, 2011 | Frigidaire Refrigerators
Freezer side working fine - fridge side simply not cold enough even at highest setting
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 17, 2010 | Frigidaire FRS3R5EMB Side by Side...
Fridge & freezer are cooling on bottom but not
when you open the freezer door do you hear the fan blowing?sounds like the air isn't moving,there's also a damper on the fridge side,the door opens to let the cold air in and then closes,make sure the door is opening,you can take the cover off and put an ice cube on the twirled up metal part to close it and put your hand on it to open it to see if it's working
Mar 21, 2010 | Frigidaire FRS26H5AS Side by Side...
Fridge & Freezer not cooling
i think you have a bad compressor pull it out and take off the back panel and feel the compressor if it is hot and making a bad sound it might be an over load relay
Dec 11, 2008 | Frigidaire PHS67EHS Side by Side...
FRS24zrh Side by Side Fridge was not cool enough then freezer started warming up, defrosted everything, vacuumed underneath, worked fine for about 12 hours and now seems to be warming again
I had the same sort of problem. Found that the freezer would not completely defrost on each defrost cycle. Replaced the defrost thermostat and solved the problem.
Hope this helps.
Jul 23, 2008 | Frigidaire Refrigerators
Refrigerators Logo
569 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
