Question about Craftsman Gas Mini - Tiller/Edger
My craftsman 4 cycle edger is dripping gas out the air filter. How do I fix it?
    Sergeant:
  • 302 Answers
This could be caused by the float in the carb sticking
Posted on Sep 10, 2009
How fix a gas line break at gas tank?
Using needle nose pliers slip the split line off the connection and pull out of the gas tank. If there is a filter on the end you need to extract through the gas cap opening. Purchase another gas line either in a repair kit or individual line and cut to fit. If the filter is bad, use a new kit. Insert through the gas cap opening and pull up through the supply line opening. Be sure the connection is clean then slip the new line onto the clean connection.
Sep 12, 2014 | Craftsman WeedWacker Gas Trimmer 29cc...
Managemylife com
1.You have to remove the air filter *** cover.
2.Remove air filter.
3.Remove 2 screws, to remove the rest of air filter ***.
4.Remove the 2 fuel lines with a long nose plier.(Take a photo of
the position of fuel lines or mark fuel lines for reassembly)
5.Unhook the throttle cable.
Now to fix the Carburettor
1.Remove the 4 screws on primer bulp side of the carburettor.
2.Open the carburettor and clean with paint brush and clean fuel.
3.Replace diaframe kit(available from your nearest dealer) and reassemble the trimmer.
Dec 30, 2013 | Craftsman WeedWacker Gas Trimmer 29cc...
Air filter replacement weed eater
on your weed eater there should be a lil bubble looking thing called the primer somewhere around tht should be a black box with a screw of some sort on it take the lid to the black box of and theres your air filter
Aug 17, 2012 | Craftsman WeedWacker Gas Trimmer 29cc...
I have a craftsman 4 cycle engine model 143.814032. I can start the engine and it will run for about 30 seconds and stop. I have check air filter, choke,new gas new plugs . I have taped on the bottom...
Clean your carb for starters. Sounds like you have a fouled carb inside. If this is a trimmer you might need to just buy a carb rebuild kit and start fresh. Good Luck...
Aug 31, 2011 | Craftsman Garden
Looking for the part number of the air filter on craftman edger model # 53685648
On the Sears Parts Direct, they show no air filter. I would recommend taking the filter to a small engine shop so they can match it up or just go to Home Depot and match it up with one of their filters they may have in the lawn and garden. Lowes has a small engine section too, most of their stuff is Briggs and Tecumseh. Here is your parts diagram, with no air filter shown.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Edger-Parts/Model-53685648/0247/1503400?sid=PDVertical
Aug 13, 2011 | Craftsman Gas Mini - Tiller/Edger
I have a Model 29270 REV B00 Craftsman 4 cycle mini-tiller. Can't find a spark plug or air filter. Appreciate some direction.
Craftsman part numbers will help on this search. Typically 3 digits separated by a '.' such as 345.45687
If you can find these, please re-post the question. :)
Sep 25, 2010 | Craftsman Gas Mini - Tiller/Edger
Need gas line sketch for craftsman brush wacker 32.cc
Most 2 cycle engines are basically the same. The primer button has two lines coming from it. Gas is actually s.ucked thru the carb and not pushed thru when you prime it. Take a look at the sketch I provided and hopefully you will get yours running again.58fe8f0.jpg
Apr 26, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman Edger 536-797520 is leaking gas from the air filter
The needle valve is sticking open. The carb needs cleaning and diaphragm replaced. Probably best taken to a shop unless you have experience with diaphragm carburetors. Dwain
May 27, 2009 | Craftsman Gas Mini - Tiller/Edger
Craftsman edger won't start
Does it have a primer bulb? If so, make sure the bulb is not cracked. Also, make sure the fuel lines are not cracked and the fuel supply line reaches the bottom of the tank. Fuel lines, as silly as it sounds, degrade when exposed to gas for long periods of time. If they are cracked it will draw more air than fuel and not allow the engine to run. You can buy replacement fuel line/primer bulb kits for under $10 at practically any hardware store.
May 24, 2009 | Craftsman Gas Mini - Tiller/Edger
Roto tiller won't start - primer bulb
Carburetor needs to be rebuilt or replaced. Replaced would be my choice.
May 23, 2009 | Craftsman Gas Mini - Tiller/Edger
Craftsman Gas Mini - Tiller/Edger Logo
339 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
