No picture, no sound, nothing but flashing light
  • davidlaack Sep 09, 2009
    Sorry about that. JVC model AV36260
  • davidlaack Sep 11, 2009
    Yes. Took to service tech. $175
    Brigadier General:
  • 8,619 Answers
Hi
As you have not provided with the brand and model no#, generally this happens when the set has failed in either the high voltage section or the deflection amplifiers. These are the most common because they draw the most power. It could be other failures as well. Please look very close, when the set shuts down there will be a pattern to the blinks let me know. Also tell me the brand and model no# with the blink patterns so that I can assist you further.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 09, 2009
  • Rylee Smith
    Rylee Smith Sep 09, 2009
    Hi
    Thanks for using FixYa and providing the model number. It seems that the power supply board might have gone bad. Also check any swollen capacitors on power supply board and make sure that the cooling fan is working fine. Please check and replace the power supply board or swollen capacitors. These parts will cost around $200-300 from the JVC. If you have the basic knowledge of TV and can replace it then go ahead otherwise it is recommended that this replacement should be done by a qualified service technician.
    Thanks
    Rylee
    Thanks
    Rylee
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
Flashing red light saying lamp and no picture.
REPLACE LAMP !!!
Buy an Orginal Replacement Lamp.
May 19, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Panasonic TX-32LXD60 won't switch on. Red standby light flashes quickly and then becomes constant. TV Clicks and slight flicker then nothing. Can anyone help please ?
U have sound at all?Yes,than ur LCD INVERTER backlight board it dead.If power LED light keep flashing nothing on,sound or picture.Than the power supply board is dead.Must replaced the power supply board.Tries Websites Shopjimmy.com,Ebay.com to buy these refurbish boards.
Feb 26, 2010 | Panasonic TX32LXD60 32 in. LCD TV
Sony KP-41T65
is there a cadence to the blinking timer light?
Jul 17, 2009 | Sony KP-41T65 41" Rear Projection...
When the power button the red button flashes but nothing else hap
the red light flashing means the set is in auto shut down, could be a power supply problem or a convergence IC problem. tech should first check all diodes and caps in power supply then replace convergence IC's
Jan 11, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Changed bulb, now tv does nothing. . .please help
same problem. TV turns on but no picture or sound. when i press power button on the remote control orange light flashes for about a minute and goes back to red.
TV won't turn on. It iz frustating me a lot ay !
Mar 07, 2008 | Televison & Video
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Can't get the camera to Flash
EXACT same problem. Tonight I tried to take a picture and heard a loud pop sound but I didn't think it was my camera... anyway it took the picture but didn't use the flash. Later, my sister went to take a picture with the flash and it made the same loud pop noise and now the camera wont work if the flash is on.
Jan 19, 2008 | Samsung Digimax S630 Digital Camera
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
