Question about HP OfficeJet 4215 All-In-One InkJet Printer
Can the HP OJ 4215 receive faxes directly to the PC rather than being printed? I have all the software installed, but no option to receive to the PC. Any help would be useful.
Wont print in color it only prints black and gray
  1. Click on start and go to printers and faxes
  2. Right-click on the icon for hp officejet 4215 printer and go to printing preferences
  3. Click on the color tab
  4. There are two options print in color and print in grayscale. Choose print in color
  5. That should solve the problem
Jun 27, 2011 | HP Officejet 4215 All-in-One Color Photo...
It will no longer scan and will not receive Fax. It will still copy and print
Kindly install the scanner software for printer..You just re install the driver software cd it will automatically install the missing components.
Which is contains the hp director software. Which shows the scanning option For normal scanning you can choose the option of Scanners and Cameras wizard in control panel. But it is better if you have software disk of printer because it contains more option.
for fax
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Feb 26, 2010 | HP OfficeJet 6210 All-In-One InkJet...
HP officejet 4215 to print instead of fax
if you are using windows then go to control panel and go to printers(windows vista) or printers and faxes (windows xp) and then select the correct printer icon out of the two icons.. there will be two icons (for eg . officejet 4215 and officejet 4215 fax.. ) choose the one which doesnt says fax .
Oct 20, 2009 | HP OfficeJet 4215 All-In-One InkJet...
How do i retrieve fax report from hp 4215 all in one
1 Press Setup.
2 Press 1, then press 1.
This selects Print Report and then selects Automatic Reports Setup.
3 Press ! to scroll through the following report types:
– Every Error: prints whenever there is any kind of fax error (default).
– Send Error: prints whenever there is a transmission error.
– Receive Error: prints whenever there is a receiving error.
– Every Fax: confirms every time a fax is sent or received.
– Send Only: prints every time a fax is sent.
– Off: does not print fax reports.
Note: If you select Send Only, you will also receive error reports if there is
any kind of error generated.
4 Press OK to select a report
More information? you can download manual here
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
Sep 05, 2008 | HP Officejet 4215v All-in-One Printer
Faxing
LEXMARK Z612 NOT PRINTING THE PAPER(PAGES) COMES OUT WITHOUT ANYTHING
Jul 06, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Receive fax to pc
We cannot receive faxes directly to the PC. We will receive the faxes only to the printer.
Apr 03, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Fax problem
Hi Pjdeegan,
Please click on the web link given below and perform the steps as given in the web page
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02151&cc=us&lc=en&dlc=en&product=351106
Please perform the steps carefully and you can get more help on
http://welcome.hp.com/country/us/en/contact/chat_1.html
Mar 09, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Hp officejet 4215
Hello sonyamac,
You can download the software directly from the manufacturer and install it without the CD. Go to www.hp.com/, find and click Software & Driver Downloads, select Download drivers and software, type officejet 4215 in the box and press enter. Select which officejet matches yours: 4215, 4215v or 4215xi (you can find that info on a label attached around your printer. Sometimes the model is only described as CXXXXA format. If that is all you got, go back to the prior page and type that model instead of officejet 4215. You should reach a page where you select which operating system you are using, click on it and on the next page you can select which software you want to download. After saving your download, just open the program, follow the installation instructions and you should be ready to print in no time. Hope this helps.
cancerags
Dec 26, 2007 | HP Officejet 4215 All-in-One Color Photo...
HP software will not install
this error tell us that you are not logged in with full admin rights on your computer to install software and driver package, and it also sounds like you are trying to start software install using the "run command"
There is nothing wrong with printer but you do seem to be having trouble loading the required software and driver package on your p.c.
Are you also using new Vista software/driver package for your HP OJ 4215 cause the one that came with it maybe XP.
Go to HP and download correct package, AND log on as administrator with FULL priveledges, your username (normal login) may not, from the looks of this.
link to hp software download for HP OJ 4215
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&product=351106&lang=en&
"it obviously needs a fix--tell me what it is"
Nov 05, 2007 | HP OfficeJet 4215 All-In-One InkJet...
HP OfficeJet 4215 All-In-One InkJet Printer Logo
27 people viewed this question
Seeker5211
Seeker5211
