Question about Brother MFC-8840D All-In-One Laser Printer
External wireless print/scan server
Where can I buy an external wireless print/scan server for the  Brother MFC-8840D?
I have a Brother MFC 8840D. The print quality is excellent and appears to be stable (it does not rub off), but once I fold a document and place it into an envelope, the recipient will receive a smeared...
It sounds likea problem with your paper stock. Check the following to make sure you are using a paper type that is compatible with your printer.
Recommended paper
Plain Paper: Xerox Premier 80 gsm
Xerox Business 80 gsm
Mode DATACOPY 80 gsm
IGEPA X-Press 80 gsm
Recycled paper: Xerox Recycled Supreme
Transparency: 3M CG 3300
Labels: Avery laser label L7163
??  Before you buy a large amount of paper, please test some to make sure that the paper is suitable.
??  Use paper that is made for plain-paper copying.
??  Use paper that is 75 to 90 gsm.
??  Use neutral paper. Do not use acidic or alkaline paper.
??  Use long-grain paper.
??  Use paper with a moisture content of approximately 5%.
Caution
Do not use ink jet paper. It may cause a paper jam and damage your MFC.
Choosing acceptable paper
It is recommended that you test paper (especially special sizes and types of paper) on the MFC before purchasing large quantities.
??  Avoid feeding label sheets that are partly used or your MFC will be damaged.
??  Avoid using coated paper, such as vinyl coated paper.
??  Avoid using preprinted or highly textured paper, or paper with an embossed letterhead. For optimum printing, use a recommended type of paper, especially for plain paper and transparencies. For more information on paper specifications, call your nearest authorized sales representative or the place where you purchased your MFC.
??  Use labels or transparencies that are designed for use in laser printers.
??  For the best print quality, we recommend using long-grained paper.
??  If you are using special paper and the paper has problems feeding from the paper tray, try again using the manual feed tray or Multi-purpose tray.
??  You can use recycled paper in this MFC.
The output quality depends on the paper type and paper brand. Visit http://solutions.brother.com and check the latest recommendations for paper that can be used with the MFC-8840D.
Dec 23, 2010 | Brother MFC 8840D All-In-One Laser Printer
GETTING MACHINE ERROR ERROR 78 , PRINTER NAME BROTHER MFC 8840D
Machine Error 78 indicates a mechanical malfunction of the Brother MFC-8840D. 78 represents the error number. You have to contact Brother Customer Service 1-877-BROTHER.
Dec 22, 2010 | Brother MFC-8840D All-In-One Laser Printer
Does the briothers mfc 8840d scan directly to a pdf
well if you got a software disk from brother when you bought the printer if that has a scaning program o it install the disc on your computer and open it, put the paper on the scanner and view the advanced settings on the scan program if it has any otherwise search the settings and find the extension or format that it saves in and change it to what you prefer
Jul 04, 2010 | Brother MFC 8840D All-In-One Laser Printer
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
EVERY TIME I PRINT OR GET A FAX ON MY BROTHER MFC-8840D FAX IT SHUTS MY COMPUTER DOWN
Fax is an operating system setup utility...perharps you have backup file that are corrupt in your operating system so, Repair your operating system and try it again.
Sep 30, 2009 | Brother MFC-8840D All-In-One Laser Printer
Black copies and black scan
sounds like you have a CCD problem or possibly a board. CCD stands for charge coupling device and its what interprets your scan original to convert it to digital form. these machines carry a 3 yr warranty. hopefully, its covered still.
hth,
razors
Jan 08, 2009 | Brother MFC-8840D All-In-One Laser Printer
My brother mfc - 8840D will not scan, please help
if it can copy copy correctly then its not the scanner. most likely you do not have the scanner software installed.
Dec 23, 2008 | Brother MFC-8840D All-In-One Laser Printer
Brother printer mfc 240c
no. you should buy a mfc 440cn / 465cn or better -if wireless- a mfc 865cw
May 15, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC-8840D All-In-One Laser Printer Logo
117 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
