FixYa.com
Tags:
Compaq Armada M700 PC Notebook
Compaq m700 problem (by 2 users)
By Bouncy - usenet poster
Hi
My son has a laptop as header and it has started playing up.  It wont boot
either from the battery or on the mains with the battery in place.  Works
fine on mains with battery removed, any suggestions?
thanks
Gary
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by benzholy, posted on Jun 20, 2008
it wont start up
Best Solution
posted on Mar 28, 2008
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
what spec of compaq m700 include the mobo?help me yaa
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 28, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
I had this problem too. The laptop would not start or reboot with the battery in. I could start the laptop and then put the battery in, but would have to take it out when I rebooted or tried to start up later. This was shortly after I'd realized my battery was no longer taking a charge.
I'm not sure what exactly in this fixed it, but this is what I did...
After trying all manner of machinations with no success, I took the battery out and set it aside. It still had a partial charge. These take about a month to discharge on their own. So I let it sit for a month until it should've discharged. It still had a bit of a charge when I plugged it in (I didn't have the patience to wait a month and tried again after about 2 weeks) and the computer did two things it hadn't been doing before - it showed the yellow recharge light before I tried to start up (so I let it charge for a while), then it actually did start up with the battery in it.
Note: my battery actually still holds a charge now, it's not completely dead. I'm not sure if the board recognizes a battery no longer charges and hence won't let you start with it so you don't think you'll be okay in the event of a power failure or unplugging, or if it's just a battery memory issue. Either way, try going without for a couple of weeks and plugging it back in.
Solution #3
posted on Mar 03, 2008
Not Rated (0)
tat4u
Rank:Wiz Wiz
Rating: 82%, 156 votes
check battery terminals in pc .dust and debris can act as conductors thus causing terminals that shouldnt be connected connected and causing a short.you could try as many new batteries as you like but non would work if this is the prob.if you have a small brush that you get for electric shaver;selotape it to a pen(for extention)and use to clean
Solution #4
posted on Aug 09, 2005
Not Rated (0)
Joey2
Joey2 - usenet poster
Rating: 0%, 0 votes
It has to be something to do with the battery, otherwise it wouldn't boot at
all.
Sounds a lot of money, but a new battery might be the only answer.
Remove "nospam" from return address.
Solution #5
Not Rated (0)
Cornish
Cornish - usenet poster
Rating: 0%, 0 votes
Dennis Pogson wrote ...
I recently bought a replacement HP/Compaq battery from "Battery Pro" on UK
EBay.  He is regularly listing M700 batteries for as little as ??29.99.  They
will be 3rd party replacements but I was very pleased with mine - arrived in
two days, and charges perfectly with a good capacity and half the price of
an HP replacement.  A new 3rd party battery pack is probably a better bet
than a genuine "new" original with dubious shelf life.
David
Can you Help with these PC Laptops problems?
PC Laptops
problem in wireless
wireless intenet disconnect... Answer This...
PC Laptops
scroll up/down function
the scroll up/down function in... Answer This...
PC Laptops
Memorystick duo
My Acer Travelmate is supposed... Answer This...
compaq armada m700 wont boot up
everytime i try to boot up my... Answer This...
compaq armada m700
how do i no what to solder and... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
