Question about Yamaha Music
One white key is sluggish and doesn't come up as fast as the res
Yamaha p 120 keyboard, one white key doesnt come back up as fast as the rest of the kleyboard. How can i get it fixed?
  • Yamaha Master
  • 5,603 Answers
Look for any drag of the key to the case or adjacent keys. Beyond that, the silicone rubber contact dome probably is damaged and needs replacing. Unit has to be opened and serviced. Parts are pprobably available from YamahaAmerica in CA.
Posted on Sep 09, 2009
Yamaha Piaggero NP12 all "A" and "Eflat" keys are dead.
If all A & Eb are dead it would point to either a bad connection between the keyboard circuit and the motherboard ( ribbon cable ) or possible diode problems on the keyboard PCB.
Initially open up and check connections are all tight and correct.
Did this just happen or has the keyboard been opened up?
Nov 27, 2016 | Yamaha Music
Where and how can I buy a replacement keyboard for Yamaha CVP 305M? Thanks, Michael
There is a well documented problem that occurs with the keybed on some of these models due to a manufacturing fault. Take a look at the keys that are sticking. Is the gap on either side of the key the same ? If not then the key normally leans slightly to the left rubbing on the adjacent key causing the sluggish action. The fixing tab at the back of the key breaks causing the spring pressure to push sideways.
You can just replace the offending key but the problem will eventually return. You could replace the whole keybed but this is a very expensive fix.
Keys are around £ 15.00 each.
Replacement keybeds around £ 450.00
Visit www.beckettsmusic.co.uk
Search for VU101 via the search box.
Feb 23, 2015 | Yamaha Full-Size Keyboard
Yamaha motif xs6 after touch problem
needs first aid by cleaning it first,,if it doesnt work faulty board that serves the keys. (mks)
Aug 26, 2014 | Yamaha MOTIF XS6 Keyboard
Install PSR E413DRIVER
What driver do you want to install?
Jan 14, 2014 | Yamaha PSR-E413 Portable Keyboard
No power, when i press the power button then the multi display just flash and the other leds but speaker sounds power on
1-Click and phone orders do not apply. ... Casio CTK-2300 61-Key Premium Portable Keyboard Package with Headphones, ...Yamaha PA130 120 Volt Keyboard ACPower Adaptor by Yamaha... Suite makes practicing your favorite songs more easythan ever before. ..... There's a problem loading this menu right now.
Sep 13, 2013 | Yamaha Portable Keyboard
Dead keys yamaha psr e413 keyboard
Dead keys on Yamaha PSR e413 keyboard: Flip keyboard upside down, remove cover screws (use marked cardboard template to remember where they came out), spray suspect key-contacts with fast-drying contact cleaner, (usually a PCB with a matrix of contacts under keys), re-assemble base cover, wiggle faulty keys as far as possible to 'scrub' any dirt or oxidization. If this cleaning trick doesn't work, get a pro to check it.
Dec 08, 2012 | Yamaha PSRE413 Keyboard
Yamaha P-120 Piano: Graded Hammer (NOT key) dysfunction?
My opinion is you should take the instrument to a yamaha authorized service center.. It's doubtful this will be user serviceable, particularly if the problem isn't on all the keys, and the service center will have access to the parts needed as well as more information from Yamaha than they will share with an end user.
Mar 15, 2017 | Yamaha Music
Yamaha PSR 510 -- one of the white keys broke out. Need HELP!
I figured it out. Once the whole 61-key section is unscrewed (I believe its just one screw at the end and it simply lifts off) you have to take a flat head screwdriver and stick it in the top edge of the key rows and twist to force the little tabs out of the slots. Be careful because this is not easy and some of the little tabs might break off - it may not be crucial for the keys to snap back in, though. The first few black keys and the tab above are all one solid piece of plastic. All of the keys are grouped in groups of 3-5 or so as one piece. White keys are layered under the black keys so you must release black key groups to access the white key groups. Once you have forced a key group lose from its snap attachment you must also free the keys from underneath to fully lift the keys off the unit. You have to BREAK the hook shapes found on the underside of the keys (they rest up against the orange rubber lining.) Take wire cutters and snap off all the tips in the key group you wish to remove. Depress a key and watch the movement underneath if you have trouble seeing what I'm talking about - you will see the hooks - think of it as the bottom of the key because that is what it is. The piece you break off should be very small - just enough to remove the hook shape enabling you to lift the keys right out. This will not cause the keyboard to be unusable. It will only make it possible to bend the key up once everything is reassembled. It is the only way I see to free the keys and gain access to the action underneath. As for that...
The action underneath is made up of a pair of rubber cups that when pushed make contact with metal sensors. These rubber cups can tear causing them to fail to pop back up to rest position. I am trying crazy glue to see if this will repair the tear. If not then I will try double-sided tape so that the plastic key will pull the rubber cup back up with it (I hope) when released. Good luck. It is a great keyboard. Very sad to see it discontinued.
This is regarding the Yamaha PSR-510.
Feb 10, 2009 | Yamaha Full-Size Keyboard
Music Logo
60 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
