Question about GE Spacemaker Washer and Dryer Electric Laundry Center
Ge Spacemaker Laundry the washer knob popped out
The washer knob popped out and it will not go back in its sort of stuck
  • 574 Answers
Take knob off again and look at the stem where the knob goes does it have a round side and a flat side? if so the knob will have the same profile thats the way it goes on
Posted on Sep 09, 2009
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Ge spacemaker laundry dryer does not heat
All dryers have states to control heat GE has a safty stat that is comon problem small round stat at top after removing lid check with ohms meter with wire unpluged if no continuity changed then check venting of dryer inside and out improper venting will cause dryer to over heat
heat element is the next go to same check but must take dryer apart more send model Number we can give you a diagram and location of everthing you will need
Jan 30, 2013 | GE Spacemaker Washer and Dryer Electric...
Very hard to pull out washer knob to start cycle
you must,bring to the repairman, to check what is the prpblem.
check this one.
http://www.washingmachineadvisor.com/1400-spin-washing-machine
Feb 05, 2010 | GE Spacemaker Washer and Dryer Electric...
GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
I have a ge washer model#wssh300g1ww. there is
You either have a bound up (frozen) drain pump, or knowing GE's reputation with washers, the transmission (gearcase) just dug it's own grave. How old is it? Depending on the age, it might have a frozen pulley.
Dec 16, 2009 | GE Spacemaker Washer and Dryer Electric...
GE WSM2480TBAW Spacemaker Laundry, Won't Drain or Spin
you need to remove the slanted panel between the washer and the dryer. There will be 2 screws holding the top of the washer to the cabinet. Locate the screws on the back edge of the washer top along with the 2 brackets that hold the top.
Once the brackets have been removed, the washer top panel will pull toward you and lift off of the cabinet. You will be able to see the lid switch and test it. If you are testing the lid switch for continuity, remamber to activate the switch while testing. If the switch shows an open circuit, replace the switch.
Please let me know if this hhelps you at all or if I can assist you further.
Thanks
Vic
Jul 23, 2009 | GE Spacemaker Washer and Dryer Electric...
A gasket between the front blower housing and air duct?
the foam gasket is suppose to be there but as far as ordering by itself I am not sure if you can but can some foam from your local hardware and put on there
Dec 02, 2008 | GE Spacemaker Washer and Dryer Electric...
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
361 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
