Question about Acer AL1916W 19" LCD Monitor
Floating box there is a rectangular grey box floating around on my screen with the words "Input Not Supported"
    Master:
    Sergeant:
  • 381 Answers
Erm......reduce your graphic card output.
Posted on Sep 09, 2009
Floating gray box that says input not supported
When do you see the grey box? When you are playing a game? If so, try changing the resolution on your screen through the Control Panel...personalization...the resolution scale. You may need a lower resolution in order for the game to be played. I used to get a box that said "signal out of range". It wouldn't go away until I lowered the resolution in order to play that particular game. You can always change it back to your original resolution. Did you have a message in the grey box.
Mar 20, 2012 | E-Machines eMachines Desktop PC
Input not supported - floating gray message Win 7
You haven't specified what monitor you use but the gray message is most likely due to your screen not being able to handle the high resolution. Try setting it to a resolution below 1600 x 1200.
Best wishes,
Graemevm
Dec 15, 2009 | ZT Group Cisnet PC Desktop
My laptop got broke, i'm using a small flatscreen monitor plugged into the back. a screen says "ATTENTION INPUT NOT SUPPORTED" just keeps floating around the screen. i don't know how to fix it
Start in safe mode and change the resolution to 1024x768 and 60Hz refresh rate. Restart and reset the resolution at the native of your display and 60Hz refresh.
Oct 28, 2009 | Acer AL1916W 19" LCD Monitor
Input not supported
IT sounds like the monitor got fried.. sometimes if the monitor is in the on position as the power comes back, the monitor gets an unexpected sure which can sometime damage the circuitry. You may be out of luck. You're only other option is to try using the monitor on another computer to see if it's just a weird connection issue.
Dec 19, 2008 | Acer AL1916W 19" LCD Monitor
FLOATING BOX WITH ATTENTION INPUT NOT SUPPORTED
Your monitor has several different video inputs.
Go to the configuration settings on your monitor and select the video input that matches the video cable from your computer.
Nov 12, 2008 | Computers & Internet
Input not Supported
Run in safe mode and try to change the screen resolution to 800x600 and reset your machine.
Oct 27, 2008 | Acer V193w LCD Monitor
INPUT NOT SUPPORTED
Start your Windows in Safe Mode (pressing F8) during boot process and adjust your Display Settings to a lower resolution.... say 1024 x 768. Once fixed, you can play around again increasing the resolution a notch at a time. Fix ya!
Aug 28, 2008 | AOC A15X221 15 in. LCD Television
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
FLOATING BLOCK
hi, it means, u need to change the input mode i.e pal/ntsc/vga..etc or whatever options avilable in the LCD menu..let me know
Dec 28, 2007 | Rosewill 19" 12MS DVI R911E LCD Monitor
Hi receiving input not supported
This message shows that you are not setting the resolution correctly.
When you are in Windows, click on - Control panel - Display - Setting - Screen Resolution (set yo 1280 x 1024). then click ok.
Your floating box will gone.
I got the same problem and got the solution from rma@rosewill.com.
Hope this will help you.
Ringo
Dec 13, 2007 | Rosewill 19" 12MS DVI R911E LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
215 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
