Brother mfc 845cw at first did not recognize new cartridge. now it says no black ink even though it is a new cartridge.
    Master:
    Sergeant:
  • 460 Answers
Pls refix this catridge after shaking.
Posted on Sep 09, 2009
Why does it only print red and blue, no black or yellow?
call the brother 1-800 number this might be covered by warranty
Dec 21, 2015 | Brother MFC-845CW multi-function...
Unable to clean 50 (brother MFC-845CW
Hi, to clean up brother MFC-845CW
Open the printer
Remove the ink cartridges from the print head.
Use cotton swabs dipped in hot water to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab.
Once finished, allow to dry and replace the cartridges
Try to print something now
You can also use the manual for help.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002117/Mini3_MfcLcdW_UsaEngUsr_D.pdf
Jun 14, 2011 | Brother MFC-845CW InkJet Printer
My Brother MFC 440CN will not recognize a Brother
The usual obvious fix is to buy a new catridge, insert, power off machine, then switch back on to reset any sensors. But if the circuitry on the machine itself is faulty it wont fix it.
I used to own an MFC 260C. It had a perfectly good full ink catridge in it, that was working fine, until...it suddenly did not recognise the cartridge anymore.
I pulled the machine apart and found that 2 of the 4 sensors on the cct board at the back of the cartridge housing were loose. These sensors pass light through the exposed part of the cartridge to see if ink is there. So if these are faulty, you will never clear the "No Cartridge" or "Ink Empty..." or "Near Empty Ink ..." messages on the MFC260C and prbably other similar printers in the MFC range.
Why did they fail? Because the soldering on these sensors was poor quality.
I would never buy another Brother machine because of this, also because they design the machine to be totally useless unless all the ink ccartridges are full. Shame on you Brother, and kiss my *** for the $160 pile of junk I bought off you that was only on its second batch of cartridges (ie very little use)
Jan 23, 2010 | Brother Office Equipment & Supplies
MFC-420CN refuses to recognize or use black ink
The print head is clogged.Try powerful cleaning:
Press menu, then start black copy, then four times arrow-up quickly after another.Machine will be in maintenance mode
(all lights will flash).
Press 7-6-4 and OK (or start-black-copy).
When finished press 7-6-3 then start black copy,
printer will do a power purge.
Leave maintenance mode by pressing 9-9.
If this not help better think about new printer, because cost of repairing this one is profitable.
Nov 25, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother Mfc-845cw and Mfc-465cn both stopped printing Black about the same time. Using Non brother Ink. Tried cleaning, replacing carts, unpluging maching. how can I fix this.
the black ink that was used in the refilled cartridges was probably to thick for the nozzels on the head, you can try buying the original cartridges and then cleaning again, or check with the store you got these cartridges from as some of them offer a warranty
Nov 20, 2009 | Brother MFC-465CN InkJet Printer
Brother MFC 240C has error message ''NO BLACK CARTRIDGE'' even though new cartridge is installed.
I learned this one from a Brother tech, and it usually works:
  1. Put your machine where you can easily reach the power plug.
  2. Lay a few layers of paper on the desk beside it to protect the desk from ink.
  3. With the machine plugged in, remove all four inks. Stand them upright on those papers you laid down.
  4. Close the top.
  5. Unplug the machine and wait 15 seconds before plugging it back in.
  6. Of course, the machine will complain that there is no ink installed. It should tell you which color it want you to install first. Raise the top and install all inks, in the order it asks.
  7. Lower the top when all the inks are in, and the machine should return to normal.
These machines detect ink by shining a light through a clear rib in the cartridge. What you've done resets the machine's threshold between light and dark, so it recognizes full cartridges again.
If it doesn't work, try it once more, and you might still get lucky. otherwise, you may have a defective cartridge, or you may need a new main board$$$.
Nov 08, 2009 | Brother MFC 240C All-In-One InkJet Printer
Mfc 845 will not with black ink. The ink cartridge is new. Will print in color. I ran it thru the cleaning cycle. Only prints the top half of sentences.
This sounds like an alignment issue. Please refer to this support artilcle and follow the instructions given there to align the cartridge. You may have to reseat the cartridge, by carefully following these instructions. Make sure the lock release lever is firmly engaged. (clicks).
Otherwise, you have as mentioned cleaned the print head, though you could try cleaning again if the alignment doesn't correct the error. For other support help, please see here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Oct 09, 2009 | Brother MFC-845CW InkJet Printer
Black print won't work on Brother MFC-845CW
Open the case,i don't sure were the cartridge is located but i think is easy to you to find it.When you found it, wipe the botton part of your cartridge use soft clothe for cleaning.Look at mannual to locate the cartridge.
May 19, 2009 | Brother Multi-Function Center MFC-240C...
How can I print in " Black ink only " NO COLOR ?
go to control panel
printers and faxes than right click on the driver for the printer and click on properties ...
and you will find the option to print in gray scale
Dec 23, 2008 | Canon PIXMA MP150 All-In-One InkJet...
"No Cartridge" error on Brother MFC-845cw
Something that has worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
Jan 04, 2008 | Brother MFC-845CW multi-function...
103 people viewed this question
jasbo
jasbo
