Question about Farmall Tractor A-i,av,super A ,super Av Radiator
Working on farmall super a tractor distributer had been pulled so trying to reinstall but can't find timing marks
  • jamieei May 11, 2010
    there are usually dots near the teeth and there somethings will only be a beveled tooth (like on the rotor gears of my A mangeto). Are you looking for timing marks for the distributor gear or the engine? If its the engine, there is a line on the flywheel that will aline with a pointer on the clutch cover (flat plate on the front of the transmission). Sometimes, well often the mark is hard to find on the flywheel. sometimes there is a white mark on there for you. a hand crank helps a lot as well.
    President:
  • 986 Answers
Remove valve cover,bring #1 cylinder top dead center,make sure both push rods are loose,put you dist in and were ever your rotor is pointed that will be your number one wire.then you will have to adjust you timing when started by ear,I hope this helps you
Posted on Sep 10, 2009
Have a farmall super c when the guy repainted it he power washer the old grease and dirt out from the fly wheel now after i start it i cant get it into gear
worked on a farm-all not too long ago and soundslike he may have knocked something into the yokes or knocked something loose. pull the inspection plate off the front of the trans housing and see if it is jambed or loose up in there.
Sep 14, 2010 | Farmall Tractor A-i,av,super A ,super Av...
Farmall a tractor runs but makes a popping sound thru the intake pipe. The tractor hasn't been run for many years.
Possibly a timing issue. Check the timing first. Also check the compression to verify both are within spec
May 04, 2010 | Farmall Tractor A-i,av,super A ,super Av...
Which cylinder is #1 on a Farmall Super C....toward the radiator or toward the steering wheel.....
The radiator. All in line engines always have the #1 cyl closest to the harmonic balancer / belt pulley.
Apr 11, 2010 | Farmall Tractor A-i,av,super A ,super Av...
How hard is to install a coil in a 1950 super a farmall
The super a uses a delco distributer along with a stand alone canister coil like those used in most older mid 70 cars, so all you should need is to pick up one from a junk yard or go to TSC and pick up a new one
Nov 20, 2009 | Farmall Tractor A-i,av,super A ,super Av...
Farmall Tractor A-i,av,super A ,super Av Radiator Logo
1,480 people viewed this question
Top Farmall Garden Experts
Dennis Key
Dennis Key
john h
Colin Stickland
Colin Stickland
Are you a Farmall Garden Expert? Answer questions, earn points and help others
