Question about LG Washing Machines
Washing smells when washed in my lg wm-14391-tdk
SOURCE: LG WM-1280 DD front loading washing machine
Be sure the unit is level, not just stable,with the four feet touching the floor. If the unit is not level the centrifugal force of the spin cycle will be distributed unevenly, causing more pressure to be exerted in one corner then the other. this causes the unit to slighty lift in the opposite corner, thus shaking or vibrating. Many people citing this problem have their washers in an upstairs laundry room. Some of these houses may lack the needed support to sustain these washers without the floor flexing. the quality of the building is a factor.
Posted on Nov 30, 2006
SOURCE: Front Loading LG Washing Machine leaves smelly sludge in wash tub
I have a front loading machine also and am not willing to have to constantly clean out the machine -- the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution. MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts. They are not very cheap but they work great -- I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain. YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health! I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon.
Posted on Aug 23, 2007
SOURCE: my washing machine does'nt start
Had that problem before. CL means child lock. You need to press the wash and rinse buttons together to unlock.
Posted on Apr 03, 2008
SOURCE: LG WM 14316FD washing machine
An UE Error Code is indicative of a “Unbalanced Error”. This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. I found this answer on the lg web site.
Posted on Dec 14, 2008
SOURCE: lg washing machine wm-1460fhd door locked wont
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
Posted on Jun 16, 2009
Terrible smell in front loading LG washer
Try a small amount of soda crystals put it in the soap draw about half the amount you would normally use of regular soap powder and put it on the hottest wash it will break down any gunk or loose limescale which could be causing the smell.
Thank you
Jun 17, 2010 | LG WM-2277HW Front Load Washer
Sticky smelly sour clothes that were just washed in the horrible LG washer. Never recommend this crappy appliance. How do you get this company to be responsible? I got an extended warranty thru GE that...
You have to leave your door and detergent compartment open after every wash. Try using Tide washing cleaner for the machine to get the smell out first, then follow the steps above.
Jan 30, 2010 | LG WM-2277HW Front Load Washer
Diesel smell in washing machine
I recommend to take vinegar 100ml and keep the temperature of 65 degree and start the normal program most of your problem will be solved after doing this
Jan 08, 2010 | LG WM-1832C Front Load Washer
Mildew smell in towels
are you using liquid detergent? if so, change to powder. liquid detergent used for a long period causes a smell.
try putting on the hottest wash with no clothes in to get rid of the smell
Aug 05, 2008 | LG WM-1485FHD Front Load Washer
Clothes smell musty
Clean th filter in the front of tha machine. Than take an OLD towel and run a hot wash with chlorox.
After that you run it again with vinegar and that should relief your problem.
i have an LG too.
Jun 21, 2008 | LG WM-2077C Front Load Washer
Sour smell on towel after washing them
That is comon with LG.
Clean out the filter in the front.
Than take an OLD towel.
Wash with chlorox first a hot load. After that do the same but than with vinegar and that should take care of the SOUR problem
I have an LG too.
Jun 19, 2008 | LG WM-2277HW Front Load Washer
LG washing machine smelly drum
try the hotest wash not on a quick wash and put a hand full of soda crystas in the drum. you can buy these at most supermarkets.
Feb 15, 2008 | LG WM-1480FHD Front Load Washer
Washing Machines Logo
60 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
