Speakers connectors to mother board thanks - Computers & Internet
    Scholar:
  • 106 Answers
The speaker connector is the light green round one on the back of the computer case.
Posted on Sep 10, 2009
Installing an internal speaker on a Desk top pc mother board do you need to reconfigure your system.
Typically, the speaker is connected with 2 or 3 wires. The connector block should have a pin labled "SPKR" or "Speaker". From there, count three up and find a pin labeled "+5v". These two pins are typically separated by two ground pins.
So, the connection would be: spkr, gnd, gnd, +5v. The ground pins may, or may not be used depending on your design.
Nov 06, 2014 | Computers & Internet
Tip
Software for installing sound in AVS200 speakers
I have AMd sempron computer. Altec Lansing Multimedia computer, speaker system AVS200. I lost my mother board CD which I got from them. My operating system is windows xp. I formatted my computer and reinstalled everything. Since I do not have mother board CD, I can not install sound system. I am not able to here music.
Kindly suggest me where, how to download this and install in my system.
Anticipating for your early reply.
Thanking you
Manmathakumar
on Aug 05, 2008 | Altec Lansing AVS 200 Computer Speakers
Asus p5pe-vm sound problem. driver installed correctly, testing it with skype there's level bar moving on speaker test and mic but no sound i can hear in my speaker
check your SHORT CiRCUiT connector!
etter yet review *********** board's manual for the right connections of PiNs on mother board!
Nov 06, 2010 | ASUS P4S533-MX Motherboard
Connection of inbuolt speakers on motherboard..
Dear User,
Pl Take Your Motherboard Make and model no with its diagram.
(1) Diagram contains inbuilt speaker pin where to connect wire.
(2) Anoter way please see on your motherboard small pin when wire hang. Read Carefully around pin in small latters for speakers pin.
Feb 26, 2010 | MSI K9MM-V Motherboard
When I power up my acer PC I get a beep beep beep
Open your cpu cabinet cover.
Then Refix RAM memory on mother board.
Remove pci cards from mother board if any.
Make sure motherboard is not ground with cabinet.
Reattach ATX power connector to motherboard.
Pull cmos cell from motherboard for 10 minutes then refix it .
Then it work again.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 06, 2009 | Acer (AST135-U-S3100) PC Desktop
Emachine W2646--lights blinking on keyboard,pwr lamp on speaker on,power button on tower YELLOW,NO response! unplugged several hours,now dead,as if unplugged! This happened overnight while shut off...
If you have a Yellow light on power supply, chances are you have blown the power supply.
Even with a PC unplugged in a Bad Storm, I have seen many PC's and Laptops with Supplies shoot.
If you have a little computer savvy, the best thing to do is,
1. Disconnect power.
2. Open unit.
3. Disconnect all Devices from supply.
4. Disconnect 20 04 24 pin power supply connector to mother board.
5. If you have other connectors such as 4-pin 24 Volt acc. you can disconnect that as well.
6. Now plug in the supply. Note... Some supply's have a reset located in the rear of the supply, where it makes its input ( A/C connection. ) If so try the reset. Some supply's also light up or have a service light when sensing input power, some do not.
7. If all looks good and no sparks or flames, re-connect the mother board connection, (only)
Try to power on computer.
Note..... If you still have the Yellow light, Replace the supply.
In some cases, the power supply sees a fault and fold back to a protection mode.
The supply has several Capacitors in which hold a charge and when connected to the mother board retain that charge. Disconnecting the Mother Board 20- 24 pin connector will allow this charge to dissipate.
If all works after reconnecting supply, Your Good To Go.!!!
If not, you may need another Power supply.
Or may have done other damage.
Hope all works out for you.
Try it, it may work...
Readers, please rate your Technician
Thank you.
John Ray
john@johnrraycomputer.com
Jul 15, 2009 | E-Machines eMachines Desktop PC
Computer will not start
first you connect your harddisk data cable to mother board
connect your hard disk powercode using smps
connect smps 24pine connector threw mother board
connect 12v connector threw mother board
connect cpu&external fan connections
also connect the front panel connections on mother board using mother board details
Jun 17, 2009 | ASUS A7N8X Motherboard
Where to hookup front panel (PIII-3754LMR - AMPTRON)
Front Panel Connector The front panel header is where the connectors of hard disk drive activity lights, case speaker, reset button, power on/off button, computer power on light, and key lock, are connected to make them function smoothly. In the past days, users always have difficulty connecting the front panel due to a lack of standard location on the motherboard. Today, AOpen integrated all these disorder but essential front panel connectors into one 20-pin connector for easy usage. Connecting the front panel would no longer be the headache of installing motherboard anymore. Below is a view of this user-friendly front panel connector of AOpen motherboard.
please rate this post.
or donate on madridtelecom@gmail.com
Feb 08, 2009 | Intel Motherboard
One speaker not working
Left/Right balance can be adjusted in the "Sounds and Audio devices" in Control Panel. If the adjustment is not the issue then the soundcard is at fault.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Nov 14, 2008 | Harman Kardon SoundSticks Computer...
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
