Question about Garden
Where can i get a flywheel for a ryobi pbc 3020 petrol strimmer?
3 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: Ryobi PBC 3046YE strimmer starts but cuts out when speed control
A lack of acceleration in these units is most likely a fuel delivery related issue. It may possibly be time for a diaghram kit or carb rebuild kit to be installed in your carburetor. Ethanol in the gas deteriorates the parts that accomplish the acceleration procedure and may need to be replaced as they don't function anymore.
Many other things can affect these little machines as well such as clogged air filters, clogged crank case vent, clogged mufflers/exhaust ports./ spark arrestor screens...but more often than not, your problem is a carburetor issue.
Please look at the troubleshooting section on this Zama site PDF file
http://zamacarb.com/pdfs/TechGuide_2007.pdf
Posted on Jul 10, 2010
SOURCE: ryobi strimmer
i can not take the cover off to put the line back in
Posted on Oct 02, 2010
How to fit a trigger spring on a Ryobi Trimmer model PBC-3020
I have to go on general experience with my knowledge of Rybobi on this one. The handle of the unit where the spring is should have several screws in recessed holes. If you remove those the handle should split in two. When you do this make sure you are careful when separating it. There are usually some small parts that have specific places and you want to see how they seat back in there as you reassemble.
Aug 15, 2014 | Ryobi Garden
Ryobi rlt 30 cesa petrol strimmer will not start
Keith you have got to make sure the gap is right between the coil and the magnetic flywheel. Use a buisness card to set the gap and make sure the coil is on the right way.
May 14, 2014 | Garden
Purchased a gardentec petrol strimmer a while back from netto store...where can i get a spool replacment to fit my strimmer.
try Lowes or any Agway, and if that dowsn't work, try checking on line with your type of trimmer.
Apr 22, 2012 | Garden
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
I've lost the user manual for my Ryobi 25cc RPT 2543c strimmer. Can you please advise where the dip stick is to check the oil. Can't seem to find it.
Ryobi RPT 2543c This is a 2 stroke engine, so no dipstick. You mix oil with the petrol (ratio 50:1) or 200ml of two stroke oil per litre of petrol, and that's how the engine is lubricated. Hope this helps, arvidis@btopenworld.com
Apr 19, 2011 | Ryobi Garden
Petrol strimmer overheating
The fins on the flywheel moving air aided by the machine's covers along with sufficient oil in the gas mix keep the machine cool. You have a problem with one of these. Also, make sure there is no debris on or around the aluminum fins on the engine cylinder and make SURE you are using the right amount of 2-stroke oil in your gas/oil mix. 40:1 should be about right, that is 3.2 Oz/Gallon Gas. A little more oil than that won't hurt anything but less than that can cause your problem. Post back if needed.
Oct 17, 2010 | Ryobi Garden
Jul 09, 2010 | Ryobi Garden
Ryobi strimmer
Jun 02, 2010 | Homelite Mighty Lite Lawn Trimmer
RLT30HT 30CC PETROL STRIMMER difficult to start
The plug that I have in my 720r is a Champion RDJ7Y. Can I suggest that you pull the old plug out and look to see which one you have? Also when you buy the new replacement it should already be gapped for what you need.
Jul 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a rhobi strimmer only 2 years old wont start
I presume this is a petrol one. The fuel can dry in the carby and stop the unit from starting. Use fresh petrol.
I am not sure about the ryoby unit, but if there is a air filter, take it out and dip it in petrol, then try to start with the normal proceedure in the manual.
Jun 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
