Question about Refrigerators
FILTERED WATER AND ICE MAKER DOESN'T WORK.THOUGHT IT WAS THE FILTER AND REPLACED IT.IT STILL DOESN'T WORK.CAN YOU HELP?
  • 34 Answers
Follow the 1/4 inch tube back to the main cold water, if it has the clamp-on type valve then it's most likely plugged up. Close and open the valve a couple of times to clear it. If that doesn't help shut the main cold water off and take the clamp-on valve apart to clear it.
Posted on Sep 11, 2009
Testimonial: "I WILL TRY IT, THANKS"
Built-in side by side. The in-freezer ice maker is not working properly. makes one row of ice every 10-2 hours. i have checked temp, water filter and water line...all is fine. had the ice maker replaced...
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 24, 2011 | Kitchen Ranges
Leaking pure source 2 ice and water filter
Hi-
Three things
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
Hope this help
Thanks for using Fixya!
Jul 14, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerator dispenses ice, but does not dispense water?
Unfortunately, the housing that the water filter fits into is also the housing for the solenoid controlled water valve, and that is the most likely failure item.
Mar 29, 2010 | Whirlpool GS6SHAXMQ Side by Side...
We have a side by side refigerator and it stopped making ice. I thought it may have been a dirty filter because I unscrewed it and there was ice surrounding the filter so I replaced it today. I am getting...
If the ice maker switch is in the on position then It sounds like the electric solenoid valve that controls the water flow to the ice maker has failed. Have it replaced and that should fix it. Hope this helps. Good luck.
Dec 02, 2009 | Frigidaire FRS26H5AS Side by Side...
Water dispenser and ice maker don't work
You have a bad water filter housing. Be sure to turn of the water to the refrigerator before replacing this part. Replace the filter at the same time.
Apr 30, 2017 | Whirlpool GS6NBEXR Side by Side...
Automatic ice maker won't make ice
Turn off water.
Disconnect the line after the filter.
Turn water back on. If there is no water flowing, replace the filter.
If there is water flowing, the feed valve is probably defective.
Aug 02, 2009 | Kenmore Refrigerators
Icemaker in brand new fridge makes ice that tastes like mildew
brand new?OK...first,did you flush the water filter by dispencing 2 pitchers of water through the door.wait,that it.basicly the water in your ice maker is the same water that comes out of your tap.you may find that you dont like the filtered water, there should be a bypass plug that can go in place of the filter.solution wise thats about it.
Jul 24, 2009 | Pds GE Profile Bottom-Freezer Drawer...
Ice maker not working
what filter? drying filter? Water filter? Dust Filter?
Jun 24, 2008 | Frigidaire FRS26R4A Side by Side...
ICE MAKER...NO WATER IN ICE PAN
do you have water thru the door? you may have air in the line. filter incorrectly installed / or a bad water valve
let me know
Apr 04, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
