Question about HP Pavilion dv6000z Notebook
Power comes on ,computer don't start - HP Pavilion dv6000z Notebook
  • print-or-die May 11, 2010
    what do you mean.... fails to load Windows.. Turns off... gives an error..?????? CLARIFICATION
    Master:
    Sergeant:
  • 381 Answers
Most likely motherboard issue.
take battery out. hold power button, which will drain the remaining power. then use the ac adapter to power up the laptop.
if still no power, it could be either the dc jack or the motherbaord itself?....or the ac adapter itself.
Posted on Sep 09, 2009
My computer went in hibration and wont come back on
If it is not coming back to normal position then i don't think it is because of Hibration. Do this
Disconnect the power cord and pull out the battery. Then press down the power button for a least 30 seconds. Then reinsert the battery and reconnect the power cord and start the laptop normally.
This could Fix your Problem.
Aug 02, 2012 | Toshiba Satellite M35X-S311 Notebook
Bios boot screen comes up
Bios Boot Screen? OK, You don't boot from the Bios, the Bios has settings to let you control where to boot from the Hard Drive, the DvD/CD drive, the USB Port or a LAN (Local Area Network). So, what exactly is your screen showing when you press the Power Button to boot it?
Apr 07, 2012 | Toshiba satellite c660
Poweredge SC 1420 won't come on, it keeps blinking an orange light on the power button and the lights below the power button the first 3 indicator lights are orange. I tried unplugging and plugging it...
hi,
I have several of these and most often there power supplies blow. since they come by default with only one powser supply. the system won't start
I would start there as most other problems will generate beeps.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 17, 2011 | Dell PowerEdge SC1420 (SC1420MIN) Server
Monitor says it its going into power saver mode. Amber light stays lit on front of computer. I disconnected the cord from pc to monitor and then the display says no vga connected. Help!!!!!!
The power saving mode is engaged when no signal comes from the pc - the pc is either stopped (start it) or it's defective.
If you can't start the pc then you will have to dismantle it and test the components, starting with the video card. If you don't know how to do that then take it to a repair shop - don't make the problem bigger by messing around with it.
Jul 06, 2011 | Dell Inspiron 545 (884116037743) PC...
Power supply not coming to mother board. how can i find weather its will work or not? how can i troubleshoot ? hoping the detailed information regarding this.....
If your computer does absolutely nothing when you power it up - the fans don't turn on, no lights turn on and the the monitor screen stays dark, some component inside your personal computer has failed. Unfortunately, there are no visible fuses that you can replace. There's a good chance the power supply has failed however you need a PC power supply tester to test it. However, there are other components in your computer which could have failed and cause the computer to do nothing when you power it up. If you have the required tools, test equipment and understand how these components work you can test them and determined which component has failed. Otherwise, you need to have a computer technician determine what your problem is.
I'm sorry that I can't help you more, but repairing computers is similar to repairing automobiles . If my car will "turn over" when I turn the key on but will not start, I could replace the fuel filter, fuel pump, coil, ignition computer etc. until I found the problem, but I don't have the parts/tools, I don't know how to test automotive problems and I don't want to waste money and possibly cause more damage by just guessing. I take the car to my mechanic for repair.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Jun 28, 2011 | Mercury Computers & Internet
Scan tool will not connect to PCM, car has no spark, engine rolls over but wont start
Does your 'service engine soon' (sometimes a check engine) light stay on if you turn the key to 'run' but don't start it? If this light comes on then the computer is getting power. The no spark could be caused by a bad cam or crank sensor. Since the computer on Dodge vehicles uses both sensors for spark, you can't really tell which one is the issue unless you can connect a scan tool. The scan tool is powered by the port you plug it into, which gets its' power from the cigarette lighter fuse.
Jun 21, 2011 | 1997 Dodge Avenger
After power failure my GW712 wont work, the lights come on but the start up beeps don't sound and the touch pad don't do anything, also there is a whirring sound coming from the control panel.
Hi - that sounds nasty - its possible the display or the control module has failed as a result of the power failure.
I suggest the motor control module be the 1st unit to be replaced, don't think you can get around this one.
Jun 21, 2011 | Fisher and Paykel GWL11 Top Load Washer
Hi can you help me
Yes, I"m sure some Fixya expert can help you if you describe
your problem. Please use complete sentences - like "When I turn my computer on the power light comes on and the fans start but the monitor screen remains dark." Not something like " Don't work"
Tnx
Apr 21, 2011 | HP KQ495AA Pavilion A6500F Desktop PC
Auto restart
if your computer auto re start. put little bit cool past on the in side of heat sink. if this problim not gone. chang your power supplay.
May 29, 2010 | Intel Motherboard
Model 333cs How do you get to set up.
computers are all different for entering setup. f1 f2 f10 or f11... sometimes it's just the delete key that you hit .... do that as soon as you turn on the power... one should work
May 23, 2009 | E-Machines eMachines Desktop PC
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
