Question about Refrigerators
ED5SHEXKQ01 is 7 years old. Stopped cooling. Fan is running.
Whirlpool ED5SHEXKQ01 is only 7 years old. Stopped cooling. Fan at bottom is running. I hear a click every couple of minutes. I'm assuming this sound has something to do with the compressor trying to turn on.
  • 725 Answers
It could be your compressor trying to kick in. Or it could be your defrost system trying to start or stop. The least expensive thing to start is to replace the start kit on the compressor. Call or email us and we'll be sure to get the right part to you asap. You need to turn it off NOW before you burn the other parts up and don't turn it back on until you install new parts.
Posted on Sep 09, 2009
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
Neff fridge/freezer has stopped cooling
pull the unit from the wall, remove the bottom back panel , see if the small fan is working ,if the fan is , there's probally alot of dust back there,unplug the fridg. and vacuum the area real good,use a flash light to make sure you get it all, if the fan is not working and the compressor is running the fan is the problem ,the fan keeps the compressor and coils cool so the freon can cool down so the unit works like it should,if the freon is hot ,the air the fridg.will be blowing will be hot. this should fix your problem, and YES its worth fixing.alittle p.m.saves alot of $$$$$$$$$
Dec 03, 2013 | Neff Freezers
Hello, We have a Whirlpool Gold bottom freezer
I don't know about Whirlpool refrigerator freezers, but my Amana has a temperature control in the freezer that regulates the overall cooling, and then the control in the refrigerator compartment controls how much of the total cooling is sent to the refrigerator section. My advice would be to lower the temperature setting of the freezer, and see if the temperature lowers in the refrigerator as well. Also, you can go to the Whirlpool website and they can help you further.
Aug 02, 2013 | Refrigerators
Water in bottom try more than can be evaporated by fan pan overflowing Model Gs6nbexrs00 Serial ss2448296 4 1/2 years old
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check the door seals...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Gold GD5SHAXLQ02- Serial number SP3131657 just stopped cooling. Neither the fridge and freezer seems to be cooling. This unitl is about 7 years old.
Hi!!
Check
temp. control knobs,
Small fan in freezer
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure the air duct going to the fridge is clear. Once this is done, restart unit.
If evaporator is not covered w/ice, then you may have a freon leak, Call a Service Center to get a repair estimate.
Don't forget to rate this post!! Good Luck
Aug 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Doesn't cool as much as it should -- freezer, on
Does this model have a condenser fan that blows air over the condenser coil(coil on the bottom of the unit)? If it does then does the fan run?The fan has to circulate air over the coil to remove the heat from it. If the fan doesn't run then the compressor will overheat and cycle off then on on the internal thermal limit inside the compressor and the system will never come close to cooling as it should.
Nov 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Sideby side whirlpool- 3 years old- ice maker stopped working 3 weeks ago. today everything in freezer is melting
Verify condenser fan is running. Check evaporator coils for frost. IM will quit if freezer does not go below 5 degrees. The cooling was slowly dieing and finally warmed enough to defrost the food.
Eric
Jul 16, 2009 | Refrigerators
Freezer / Refrigerator not cooling
When the fans are running the compressor should also be running. If the compressor is hot but not running you have a compressor problem. If the compressor is running check for frost on back wall of the freezer compartment which would indicate a defrost system problem. At five years old have you cleaned the condenser where the heat is transferred to the outside air in the room?
Nov 19, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Fan no compressor will run
I have AD75USTO. Whirlpool  was running yesterday. Today it sound like its starting but will not boot up fan will not kick on. Does it need resetting or what. Only a year old only used for one summer?
Feb 04, 2008 | Whirlpool AD40USR Dehumidifier
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
