Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Fridge running but not cooling
My 2 yr old side by side GE fridge is running, but not cooling either the fridge or freezer. There is frost on the back wall of the freezer. Any ideas of what could be the problem or how to fix it?
  • 308 Answers
It sounds like you are having a problem with your defrost cycle. If your unit either does not go into defrost, or you have a defective defrost componet, it will cause your evap. to freeze. Hope this helps
Posted on Sep 09, 2009
Side by side refrigerator stopped cooling. Temp was 55 degrees in fridge when I noticed. Vacuumed back and between coils underneath. Removed lining in freezer and melted heavy frost and ice build-up...
Sounds like the defrost timer/board may be hanging up....
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 24, 2011 | GE GSS22JFMWW Side by Side Refrigerator
@15 yr old GE top freezer fridge. Top freezer
check to see if an internal fan is fitted. This may have stopped/ burnt out. if fan is running try 24 hr defrost.
May 15, 2010 | GE GTS22KBP Top Freezer Refrigerator
Fridge side not cooling. freezer works. 6 yr old side by side
There is a little fan that blows air from the freezer side to cool the fridge side. Pull the plug on the refridgerator for over night, long enough to give it time to defrost if there is any, then plug it back in and see ifthe fan is running. If not then it probably needs to be replaced. If it keeps frosting up and stopping the fan then the defrost timer is probably bad and will need to be replaced.
Nov 14, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer not cooling, fan blowing, fridge also not
If there is no frost , on the inside rear freezer wall ,
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
If there is frost , reply back with complete model number .
Nov 08, 2009 | GE PSS25MGN Side by Side Refrigerator
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
GE Side By side doesn't cool and freexer frosts up
Most common problem on GE's is the defrost heater(s) has gone bad. They are a glass tube and when they go bad the tube will have a burnt or black color to it. A good heater will be clear. I bet that is your problem. Seems to be the problem about 90% of the time on GE not defrosting.
Jun 29, 2008 | GE GSS20IEP Side by Side Refrigerator
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire FRT18HB5DW2 fridge not cooling
Sounds like an air flow problem to the lower unit. Take the sheetmetal or plastic rear cover off the freezer back wall and make sure the coils are frosted up good and even but NOT a block of ice inches thick (air needs to circulate and a blocked coil won't let air move over it efficiently). Make sure the fan is running to move the air around. In the fridge area make sure the air dampers are letting the cold air from the freezer down to the fridge compartment. Depending on what you find will determine the next steps so let us know.
Dec 27, 2006 | Roper RS22AQXKQ Side by Side Refrigerator
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
