Question about Dewalt DC330K XRP 18v cordless Jig Saw Kit with All - Metal Keyless Blade Change
Blade won't stay in
I bought one 3 weeks ago and it wouldn't hold the blade that came packed in the unit. Just touch wood and it would pop out. Tried different brands of blades with some results. Finishing blades that cut on the down cycle did a fine job, but the up-word cutting blades were very picky. some worked some didn't. Yesterday I tried to find a metal blade that would work and couldn't so I took the unit back and swapped it out for another one. This one seems to work with about 80% of the blades that I have. I would like to see Dewalt come up with a solution because this is a very nice unit when the blade stays in it.
    Sergeant:
  • 384 Answers
That the reason we been using clamping collar for all these years.
Posted on Sep 09, 2009
Bandsaw blades keep popping off,could it be heat related?
Blades slip off the wheels on these saws is because one or both wheels are not turning true to the blade. This can be caused by:
- Missing or worn tires on the wheels. The rubber tires have to be on the wheels and they have to be in good condition.
- Occasionally the screws holding the sprocket on the driven wheel come loose and the wheel will wobble causing the blade to come off.
- Both wheels ride on bearings and shafts that, if seized, worn or broken, will let the wheel wobble enough that the blade won't stay on.
- If the blade is stretched or twisted from use it won't stay on very well.
Aug 06, 2012 | Dewalt DWM120 Heavy Duty Variable Speed...
Toro self propelled mower. blade won't stay tight
Use a block of wood to hold blade stationary while tightening bolt. Ensure threads are cleaned with a wire brush before tightening. Is there a spacer or washer missing?
Jun 26, 2012 | Toro Power Lawn Mower
New Homelite. Cut great for an hour, then the chain wouldn't grip or cut. Chain was loose so I tightened but still doesn't cut- just
The blade is no longer sharp, something not unusual after about an hour of cutting. How long a blade stays sharp depends on what type of wood you're cutting, whether the blade contacted the ground or anything other than wood at any time, and how hard you are working the bar through the wood. If you are cutting hardwood or something like railroad ties the lifespan of the blade is greatly reduced. You can easily sharpen the blade with a hand file or dremel tool with a chain saw blade kit on it or have the blade sharpened. Best practice is to have one or two extra blades so you can change them as they become dull.
Mar 29, 2012 | Homelite Garden
I have a malibu transformer. recently got alot of rain and it tripped the GFI. I reset it, but now the lights stay on all the time, won't turn off for anything other than cutting the power to the...
Bad news.
There must have been a short circuit inside unit that caused GFCI to trip.
Once the ML power pack malfunctions or shorts out, there are no fixes or repair parts.
ML series have 5 year limited warranty.
Good news:
If lights stay on, then work around problem by plugging power pack into cheap on-off timer.
http://www.amazon.com/59366-Appliance-3-Prong-Outlet-Repeats/dp/B001D8VIKE/ref=pd_cp_hi_2
http://www.amazon.com/Woods-59403-Heavy-Duty-Outdoor-Digital/dp/B002KS7EOK
Resources:
Open following link for full troubleshoot rundown, and links for buying trippers and other money-saving tips.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 22, 2011 | Intermatic Malibu 300W Power Pack...
My dad's old craftman table saw will not cut straight. I put a new carbide tipped blade in to try to solve the problem with no luck. the wood is cut narrower in the center and it won't stay tight against...
Your problem could be one or more of... 1- Check to see that the motor mounts are secure and the motor is not moving around. 2- Check the shaft that holds the blade for the same problem if the blade is not directly mounted to the motor. If there is any "give" in the above two ways the blade could be held in place, corrections must be made to secure the blade so that it does not "wander" during the cutting procedure. 3- Be sure the fence you are using to guide your wood is set as parallel as possible to the blade so it does not cause the wood to follow another line once the wood being cut goes beyond the cutting blade. There is most likely an alignment procedure you can run through.
Sep 14, 2010 | Garden
Screen not recognizing pen
The following are instructions for calibrating the Leapster™ handheld.(1) Insert a cartridge, turn the unit on and wait for the sign-in screen to appear.(2) Hold down the Home, Hint and B buttons simultaneously.(3) When the screen changes, press the A button.(4) Using the Stylus, touch the center of the targets.
Jul 03, 2009 | Leapster Learning System
Dewalt DC330K XRP 18v cordless Jig Saw Kit with All - Metal Keyless Blade Change Logo
633 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
