Question about HP LaserJet 3100 All-In-One Printer
There is no paper jam in my printer and it keeps saying there is no paper when there is paper in the tray???
  • independe863 Sep 09, 2009
    how do i do that?
    Master:
    Sergeant:
  • 460 Answers
Your printer paper sensor is not working properly. pls clean it. if problem is not solve then checked it by printer service center.
Posted on Sep 09, 2009
Hp Color Laserjet 1600 says Jam in tray 2 bt there is not paper jams
Open the paper feed area and the printer, examine the paper feed path and make sure there isn't a page or piece of paper jammed in the path somewhere.
Aug 21, 2014 | HP Color LaserJet 1600
Keeps saying load paper, paper is in
Are the rollers worn out? If they have a slick appearance, that is your problem. Also examine the tray and see if it is lifting properly.
Sep 30, 2017 | HP Photosmart 3310 All-In-One InkJet...
I have a Brother MFC 420cn and it keep saying paper jam and there is no paper jam help please
->Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 25, 2013 | Brother MFC 420CN All-In-One InkJet...
Printer keeps saying paper jam in tray 2, but there is no paper jam.
Make that the paper tray is physically set for the correct size paper. Make sure that the tray is lifting when it is pushed into the printer. And you want to clean the the feed roller at the front of the tray. Use a lint free cloth dampened with a little alcohol.
From your limited description it sounds like the paper is not feeding.
Oct 19, 2010 | HP LaserJet 4250dtn Printer
Tried to print and it says remove paper jam and press start, tried that several times, put more paper in, powered off and it stil says paper jam...opened it up and no paper i can see thats jammed..
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 06, 2010 | Lexmark Pro X125 All-In-One InkJet Printer
Turned it on and it says paper jam. There is no
Dec 22, 2009 | HP PhotoSmart C4280 Laser Printer
It keeps saying paper jam why? it is not jammed/
Paper jams are reported under two conditions.
1) Paper reaches a sensor and never leaves it.
2) Paper does not reach the sensor in the time allotted.
A simple test is to put a mark on the next page that should be pulled from the paper tray. If the paper is pulled from the tray, you will find it inside the printer. If the paper fails to feed, it will be sitting in the tray where you marked it.
Don
Dec 12, 2009 | Kodak EasyShare Printer Dock Series 3
PAPER JAM PRINTER SAYS PAPER JAM IN INPUT TRAYS BUT PAPER DOES NOT SEEM TO BE JAMMING
Dec 11, 2009 | HP LaserJet 4050 Printer
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
Printer will not catch paper in tray
The rollers need to be clean or replaced.
Feb 04, 2008 | Dell M5200n Laser Printer
HP LaserJet 3100 All-In-One Printer Logo
117 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
