Question about Kenmore Washing Machines
Washing machine will not spin at all in the spincycle
Washing machine will not spin at all in the spin cycle
    President:
  • 1,937 Answers
Assuming that you have a top load, direct drive, neutral drain machine.
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Also check the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components.
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 16Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, the kit cost us $15.00 which is a lot less than the $170 for a new transmission.
Posted on Sep 21, 2009
Top load washer, spincycle spins drum, wont pump water out of tub, about 10-15 yrs old machine
You need to clear out the drain pump. You do this by tilting the machine back as far as you can so you can access the underneath. You will see the small drain pump. Have a basin ready to catch any water that comes out when remove the pump which is only held in by 1 or 2 screws and twisted out or pulled out. Hope this helps
Feb 23, 2011 | Maytag Centennial MTW5800TW Top Load...
GE GSLS1100 Spacemaker won't spin or drain. Washes fine then makes a rattleling noise during spincycle.
When I first started using my washer when I hooked up the water it would fill the hose and then stop until I started the machine. Now when I hook up the washer to the faucet water starts to fill the machine before I close the lid and before I start the washing process....? The last time I used the machine it didnt drain and I had a flood, is there a problem with it now???
Jan 09, 2011 | GE Spacemaker WSLP1100D Top Load Washer
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Front load Washing Machine vibrates bad on Spincycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Apr 08, 2010 | Frigidaire ATF6000ES Front Load Washer
My thintwin spincycle is not working
Yes, although I would hate to think he meant to. After looking at the diagram of your machine, I can only think of one thing he might have done. Did he say anything about needing a coupler? This connects the motor to the transmission. If he left this off, it would fill and pump out but not agitate or spin you clothes. Here is how to find out. Set machine to wash a load. Don't put any clothes in. Watch the machine. After it fills. It should start to agitate. Listen to see if you here the water is moving around. Then advance the machine or just let it run until it goes into spin. After it starts spinning open the lid. If the tub is spinning you should see it stopping when you look real fast. If it is not sloshing in wash cycle or spinning in spin cycle, you have not got a coupler on it or it broke after he put it back together. The only reason he would have had to remove it is if you needed one and after he removed it he found he didn't have one to replace it with or he just forgot. The coupler is a real common part that goes bad. I myself replace them on most every machine that has them when I open one. I only do this if the customer is there so that I can show them the ware on it so that they will not think I'm just replacing parts to run the bill up. If you would, please let me know what you find out. Thanks
Please rate if helpful.
Aug 02, 2009 | Whirlpool LTE5243D Top Load Stacked...
Amana Front Load Washer moving during spincycle
what is the model # it may be for example, LAT9206BAE
May 08, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Whirlpool washer spincycle
    Most of the time, this is caused by a faulty lid switch.
    Oct 17, 2008 | Whirlpool Washing Machines
    Transmission problem
    it sounds like a GE or Hotpoint washer. if so the transmission is bad and i would replace the machine. transmission is $175+
    Jun 29, 2008 | Washing Machines
    Washing Machines Logo
    65 people viewed this question
    Sal DeAngelo
    fordexpert
    Mike Carew
